flyer408
Boeing 707 non-standard second roof antenna
Tue Aug 03, 2021 7:36 pm
Usually all Boeing 707s were equipped with one roof antenna placed on the forward fuselage - so far, so good:
But this Pan Am Clipper (pic taken in 1975) obviously has got a non-standard second one:
Can anybody please tell me what this one was good for, and if it was installed already before delivery or somewhen later? Thank you!
fr8mech
Re: Boeing 707 non-standard second roof antenna
Tue Aug 03, 2021 9:07 pm
Those are VHF antennas. The Global only has 2 VHF systems installed, unless there’s a third antenna obscured by the #3 engine. The Pan Am has 3 systems installed.
When was the third installed? No idea. Back in the day, a third VHF system was probably an option. We didn’t put a third on our DC8’s until the ACARS system was installed.
blacksoviet
Fri Aug 06, 2021 5:59 pm
Could analog television stations be received onboard a private aircraft with one of these antennas?
fr8mech
Fri Aug 06, 2021 6:29 pm
If I remember my schooling, the VHF TV band was pretty low on the VHF spectrum. So, maybe?
I do know that if the control heads could tune to the FM radio band, you’d be able to listen to that, but the VOR/ILS control heads only went down to 108mhz…voice starts at 118mhz…I think. Been a long time.
flyer408
Fri Aug 06, 2021 7:08 pm
Thank you very much for the explanation. I understand that this antenna could as well be fitted at the bottom of the fuselage?
DL_Mech
Fri Aug 06, 2021 7:13 pm
FWIW, TWA had a separate TV antenna on the vertical stabilizer for television reception. I found this on accident while searching the manuals of a customer 767-231.
As a passenger, I remember watching local NYC TV on an TWA L-1011 while on delay at LGA.
fr8mech
Fri Aug 06, 2021 7:15 pm
Yes, you frequently see them on the bottom.
In fact, in both pictures you posted, there are VHF antennas below the R1 door.
Max Q
Sat Aug 07, 2021 4:35 am
Often it’s set up to use an upper VHF antenna on the ground and a lower antenna while airborne, controlled through the air / ground switch
BoeingGuy
Sat Aug 07, 2021 5:19 am
IIRC, a third VHF system was an option in the early days of the non-ER 767s. Three VHF systems eventually became baseline on the 767. AA 767s had the center VHF dedicated to ACARS, with no ability to select voice - again per my hazy memory.
akoma
Mon Aug 09, 2021 7:33 pm
The VHF Comm systems are pretty simple. One single coax cable goes from the back of the VHF transceiver all the way to the antenna. No air/ground antenna switching required.
Usually VHF #1 & #3 (if installed) are connected to the top antennas and VHF #2 goes to the bottom antenna, but this can vary depending on airline requirements & aircraft manufacturer.
Aaron747
Tue Aug 10, 2021 11:45 am
What’s also cool is many carriers’ domestic versions did not have the HF antenna on the tail.
akoma
Tue Aug 10, 2021 4:55 pm
[quote=" What’s also cool is many carriers’ domestic versions did not have the HF antenna on the tail. [/quote]
Where I'm from, the 707s all had 2 HF systems installed, besides 2 VHF comm systems. Some of the 707s were ex Braniff, some ex Qantas, some new.
There was one relatively big lightning arrestor & 2 HF antenna tuner units up at the top of the tail. It was not much fun replacing those items up there, and they did fail quite often.
N47
Fri Aug 13, 2021 4:46 am
If you are low enough and like you said if u can tune it to the station you certinaly can.I know for certain adf receivers can pick up am stations i have seen it first hand although it was during flight tests at about 1,000 ft agl. I believe most FM in the us is between 89-107 MHz just shy of the loc band. In fact, the faa everyonce in a while runs into cases where fm stations bleed over into loc bands and cause interference. Then either the emi is identified and delt with or the loc gets another frequency assignment.
Another difference between voice amd nav are polarization. Voice is vertical, nav (loc/gs) are horizontal. In fact all antennas that stick out close to perpendicular to the aircraft (usually blade antennas) are vertically polarized (vhf voice, dme etc). Flush mounted antennas (gps) tend to be horizontal (yes gps is corcularly polarized but the e-field vectors are in the horizontal).
As for the antenna in the photo: Judging by the size and shape i would say its some sort of vhf comm probably arcas or backup.
flyer408
Fri Aug 20, 2021 7:52 pm
Many thanks for these interesting insights!
