1337Delta764
In-seat outlets and GFCI Testers
Mon Sep 13, 2021 6:19 pm
As far as I know, in-seat outlets onboard aircraft are GFCI protected to prevent shocks from spilled beverages.
Theoretically, can someone bring onboard a GFCI tester and knock out the onboard outlets? I'd hate to be the unlucky one. Or does an aircraft GFCI circuit work differently from one in a building?
DL_Mech
Re: In-seat outlets and GFCI Testers
Tue Sep 14, 2021 7:44 pm
Each seat should have its own power supply, so you would only take out your own seat row. I believe this is done to minimize wire size/ amount of wires with 120v.
kalvado
Wed Sep 15, 2021 8:13 pm
What is the power system voltage generally? 28 V or something else?
I remember it used to be 400 Hz to reduce transformer size and weight, probably not a big deal anymore with all DC-DC converters today
DL_Mech
Wed Sep 15, 2021 8:24 pm
Traditional airplanes have 28v dc and 115v ac 400 hz (for smaller wire size). However, newer planes such as the A220 have mostly dc wiring running throughout with dc-ac conversion taking place inside the black boxes. I don’t know the reason for this new convention. Ideas?
kalvado
Wed Sep 15, 2021 9:13 pm
DC distribution should be a bit easier - definitely less crosstalk in electronics, simpler battery integration. With modern semiconductor converters making conversions small and light, motor-generators are forgotten as a nightmare and one can choose distribution without thinking about the cost of conversion.
On a very separate - but similar - note, I heard some ideas of DC-only residential grid. We'll see. Never thought I would say that, but changing architecture with a new jet type is easier than changing ancient residential standard.
celestar345
Thu Sep 16, 2021 8:17 am
For most outlets I have worked on if any fault occurs it will only take out the outlet in that particular seat - other outlets in the same row are not affected despite supplied from the same converter box. And the converter box takes power from one phase of the 3-phase 115V 400hz, the wiring rotates so the power loading across the cabin should be more evenly distributed on the three phases AC.
The outlets are pretty well built - although some do fail over time most of them takes a lot of abuse without fail. So if yours fail and you really need the outlet your next seat neighbor's should be working.
Users browsing this forum: jetmech, QAT and 12 guests
