convair880mfan
Which airliners have ram air turbines. Which power hydraulics and which provide electricity?
Thu Sep 30, 2021 1:06 am
I know the Boeing 767 has a RAT and I think the Lockheed L-1011 Tristar had one too. Don't know what utilities they powered. I don't think the Boeing 707, 727 or early 737's had them. In the dark about the 747,757,777,787. And am clueless about Airbus products and other airliner types like regional jets. Does anyone know?
I imagine pilots and mechanics know. They probably also know if RAT type machines provide hydraulic and/or electric backup.
Thanks in advance for any information.
Re: Which airliners have ram air turbines. Which power hydraulics and which provide electricity?
Thu Sep 30, 2021 1:26 am
A330/A340 - RAT powers the green hydraulic system only. Emergency electrical generation through the emergency generator, powered by the green system. RAT is housed in the third flap track fairing on the right wing.
A350 - RAT drives the emergency electrical generator only. Emergency hydraulic power through self-contained surface actuators. RAT housed in the right-hand side wing-body fairing, aft of the wing.
GalaxyFlyer
Thu Sep 30, 2021 1:50 am
CRJ has a air-driven generator, a RAT by another name, it powers the emergency bus which, in turn, powers an AC hydraulic pump. Right hand under the co-pilot’s foot. All other Challenger 600 types and Globals are the same. The 747 didn’t have a RAT until the -8.
tb727
Thu Sep 30, 2021 1:51 am
A320 series has a RAT. The RAT powers the blue hydraulic system and can power an emergency generator which is turned by hydraulic power.
It is on the belly just forward of the main gear well on the left side.
And the 727 did not have one.
convair880mfan
Thu Sep 30, 2021 2:14 am
I don't know if Wikipedia can be counted on, but according to them the Vickers VC-10 had a RAT and the A-380 has the largest RAT propeller in the world.
I imagine that if the 727 didn't have one, that the 707 didn't have one. Anyone know about other Boeing jetliners?
Thanks for all responses so far!
AirKevin
Thu Sep 30, 2021 2:23 am
The 747-8 is the only 747 that has one. The 757, 777, and 787 have one.
JustAnFO
Thu Sep 30, 2021 3:36 am
MD-11 has an ADG (McD-speak for a RAT) that provides electric power by default when deployed, and can also supply limited hydraulic power if needed.
707, 727, 737 – no RAT.
757 – it has a RAT which powers the center hydraulic system, which supplies the primary flight controls, if the left and right hydraulic systems fail. I believe the 767 has a similar system, but I haven’t been trained on that type.
fr8mech
Thu Sep 30, 2021 3:48 am
The B767 and The B757 have a RAT that drives the center hydraulic system to provide power for the flight controls.
The RAT on the A300 provides power to the yellow hydraulic system for the flight controls.
The MD11 has an Air Driven Generator that provides AC power to the #1 auxiliary hydraulic pump or the emergency busses, depending on flight crew selection.
The B747-8 has a RAT that powers selected flight controls through the #3 system.
Thu Sep 30, 2021 4:16 am
A380 - RAT drives the emergency electrical generator only. Emergency hydraulic power through self-contained surface actuators. RAT housed in first flap track fairing on the left wing. As mentioned above, it is the largest RAT prop in the world, at 163cm in diameter.
Redbellyguppy
Thu Sep 30, 2021 8:18 am
737 has cables going to flight controls, actuated by a person. These people powered generators consume cheap coffee and garbage airport food.
Thu Sep 30, 2021 8:31 am
The muscle-powered actuators...
What about emergency electric generation? Windmilling engines, only batteries, or a dozen hamsters running inside a ball?
battlegroup62
Thu Sep 30, 2021 9:02 am
Perhaps they'll start using piezoelectric generators in the pilot's seat cushions. Plenty of power when there is an emergency due to pucker.
Thu Sep 30, 2021 10:26 am
:rotfl: :rotfl: :rotfl:
celestar345
Thu Sep 30, 2021 10:58 am
For 767 (I assume same for 757) the RAT drives the center hydraulic, and the hydraulic motor generator gives out electricity from hydraulic power.
Woodreau
Thu Sep 30, 2021 11:57 am
Since all of the other planes are covered to finish out the regional jets
The EMB-145 does not have a RAT. No hydraulics other than what is in the accumulators The elevator is manually controlled with no hydraulics in normal conditions. The ailerons and rudder are hydraulic with control via pulleys and cables when hydraulics are lost. no emergency electrical generation other than the batteries. After the batteries die you have no electrical power. So you have that long 30 minutes I think I don’t remember- to get the plane on the ground before you lose the flight displays and lose the ability to trim the stabilizer. You can try to start the APU but if it fails to start then you now have less time to get on the ground.
EMB-175 does have one.
I have flown a CRJ-700 when it was only powered by the ADG. It sounds like someone started a lawnmower in the flight deck. Lose both FMSes and autopilots. The cabin depressurizes and the only functioning seat really is the captain seat. He has the only set of flight instruments that still work and you only have VHF1 and TXDR 1. Asked for radar vectors I don’t remember the interphone working or maybe it did but it was hard to hear the other pilot over the RAT propeller noise. Flaps and slats operate at half speed. Manual landing gear deployment and after landing you lose the last two remaining screens as the RAT stops generating power when the airspeed drops.
JustAnFO
Thu Sep 30, 2021 12:37 pm
Armstrong power!
Only the main ship’s battery, which is certified to make one APU start attempt, and then provide 30 minutes of power to the captain’s instruments, one comm radio, and one nav radio.
An aux battery was a customer option on the 737 NGs, which I believe doubled that time to 60 minutes.
GalaxyFlyer
Thu Sep 30, 2021 1:35 pm
Not sure why the cabin depressurization, sure didn’t on the Challengers or Globals and if I’ve done one drop test, I’ve done two dozen. Yes, very noisy.
Tristarsteve
Thu Sep 30, 2021 4:42 pm
Our B737-400 had a second battery at the rear of the e and e bay.
The Vickers VC10 had two RATs, One electric and one hydraulic!
convair880mfan
Thu Sep 30, 2021 5:58 pm
Thanks so very much for all that information. I think that provides almost a complete picture except for the DC-10 and some now retired British types like the BAC-111 and so on. Thanks again.
SteelChair
Thu Sep 30, 2021 10:09 pm
One of the greatest misconceptions in aviation. 737 has cables to the hydraulic fight flight control actuators, with manual reversion in some instances.
fr8mech
Fri Oct 01, 2021 12:00 am
No, on both the B757 and B767 the flight controls are powered directly by the RAT.
Our B767's do have a Hydraulic Motor Generator (HMG) and does run off the center system, but it only activates if there is a complete loss of AC power. It powers the capt's flight instruments and selected other users on the aircraft. The HMG can not carry the center hydraulic pumps.
SteelChair
Fri Oct 01, 2021 1:41 pm
And the 777 has only one RAT, but it has both an electrical generator and a hydraulic pump on it.
fr8mech
Fri Oct 01, 2021 5:41 pm
My apologies. I misread your post. As you can see from my reply, you’re correct.
I thought you meant the RAT provided power to the HMG so that the center pumps could be powered…which really makes no sense. Need to stop posting before I’ve had my 4th cup of coffee.
Redbellyguppy
Sat Oct 02, 2021 5:50 am
While factually correct that’s not nearly as funny.
celestar345
Sat Oct 02, 2021 11:56 pm
The problem with 767 is that with so much variations and configurations you won't know what aircraft would have some special capabilities...
I still remember for one 767 AD modification Boeing actually didn't give out wiring routing diagram because it would just cause endless nightmare...
CrewBunk
Sun Oct 03, 2021 2:24 pm
That’s a good point.
The first batch of our 767-200s were non ER. As they did not have HMGs installed, I understand they never could be ERs. Later 767-200s (still non-ERs), were built from the factory plumbed and wired for an ER conversion and eventually were.
But those first 767s were relegated to domestic only flying. If I understand comments from some of the experts on here, it was impossible to convert them.
fr8mech
Sun Oct 03, 2021 3:05 pm
Oh, I wouldn’t say impossible. I’d say way too cost prohibitive to even consider it.
CrewBunk
Sun Oct 03, 2021 5:04 pm
Well, I supposed you could take the airframe apart, right back to a million separate parts and rebuild it …. at a cost of several times that of a new airframe, but both Boeing and Air Canada Technical Services (that does D Checks on 767s) both said “impossible”. They even said it couldn’t be done during a D Check.
Understand, these are frames designed and built during the early 1980s when Erops Twin flying was a pipe dream at best. They were AC FINs 601-606, plus the two purchased from PWA, 671 and 672. FINs 607 and later were built from the factory with the “possibility” of being an ER, but were not converted till much later.
fr8mech
Sun Oct 03, 2021 6:34 pm
I’m not going to argue the semantics of “impossible” and “cost-prohibitive”, but you can certainly install new an HMG, the associated plumbing, valves and control circuitry, plus redo the electrical architecture of the aircraft to accommodate an installation that meets the intent of an HMG and and it’s associated wiring. The components may not be in the same place, and the overall weight and complexity may be higher, but I’m sure it can be done. But, why would you?
CrewBunk
Sun Oct 03, 2021 7:17 pm
Well it raised a very interesting discussion on another thread. I asked the question of what is it about those early build 767s that made it “impossible”. As you may know, we have some very well versed Boeing employees on here and they brought up some interesting points.
One even sent me a cost study of doing such a conversion. I imagine at some point, more than a couple airlines with these early builds were curious.
As I said, it would take bringing the airframe right to bare bones. And, it would have to be exactly as built at the factory as new build ERs. This is important as any variation would require a whole new set of testing and licensing. Almost starting from scratch as both the FAA and Transport Canada are very careful about EROPS operations. (Not to mention Boeing).
The study was done about 15 years ago and the cost was estimated at around $50M including testing and licensing. Then ….. you end up with a -200ER. Not really the ideal airframe for long international operations.
The last configuration AC had was 169 passengers in an FJY cabin. Hard to pay off $50M with so few passengers.
So as you say, it really comes down to semantics. “Impossible”? I suppose anything is possible. “Cost prohibitive” ? Maybe not if profit was neither your aim nor goal.
bigb
Tue Oct 05, 2021 9:22 am
CRJs have them to provide limited electrical power. The 747-8s have them to power Hydraulic System 3 only.
celestar345
Sat Oct 16, 2021 2:46 am
If you have too much money and nowhere to spend, yes it's definitely doable - I am sure Boeing will be more than happy to take on a project and give you a totally rip off price tag!
A good example is what Collins did to the KC-46 tanker, definitely doable to the mainline 767 but whether it's worth the expense is another story.
Users browsing this forum: ILUV767 and 17 guests
