Starlionblue wrote:There is no mechanism to stop the low-pressure spool from spinning. As FlapOperator says, unless it is seized somehow due to damage, it will spin.
There is indeed drag, but nowhere near that of an unfeathered propeller.
Tristarsteve wrote:You don't want the fan to stop turning. Spinning in the breeze is much better.
Many years ago I was doing some engineering things with a Tristar simulator, and afterwards we went flying in it, and the simulator engineer simulated a seized fan. Loads of vibration and very noisy. Not recommended!
kalvado wrote:Are we talking about spinning unfeathered prop, or immobile?
As far as I understand, most designs have no clutch between engine and prop (is ATR-42 hotel mode unique?) - is that the cause of the difference, that unfeathered prop has to work a piston engine?
FlapOperator wrote:kalvado wrote:Are we talking about spinning unfeathered prop, or immobile?
Here is the difference between a free turbine design like a PT-6 and direct drive turboprops. Direct drive doesn't have a clutch per se, but there is lots of inertia in the engine that keeps the prop from moving once the blades are feathered. In a PT-6 design (King Air 200s/1900s) the ram air can often create some very gentle rotation, but often once the prop stops, it stops and hangs there (speaking as a person who might held the world record in King Air 200 single engine flight time, at one point.)
Aircellist wrote:FlapOperator wrote:kalvado wrote:Are we talking about spinning unfeathered prop, or immobile?
Would you mind telling the story? Please
FlapOperator wrote:Aircellist wrote:FlapOperator wrote:
Aircellist wrote:FlapOperator wrote:Aircellist wrote:
Thank you very much. I imagined an incredible accident. Reality is much simpler, much more down to Earth, if I may say so (hopefully, in a very controlled way)…
Your story shows that musicians and pilots have that thing in common: training…
