N1120A wrote:In the US, aircraft type ratings are controlled almost as much by airline contracts as they are by actual regulation. For some maniacal reason, Delta still maintains a separate pilot group for the 767-400.
N1120A wrote:Unlike the 757/767 and the A330/A340, the aircraft you mention are different airplanes on different certificates. The question becomes how much will the local regulator allow in terms of differences. For example, I know that at least some Air Canada pilots are certified to fly both the 787 and 777, but do need to maintain two type ratings. The rating course, however, is shorter when already rated on one, due to flight deck similarities.
N1120A wrote:For example, I know that at least some Air Canada pilots are certified to fly both the 787 and 777, but do need to maintain two type ratings.
Starlionblue wrote:N1120A wrote:Unlike the 757/767 and the A330/A340, the aircraft you mention are different airplanes on different certificates. The question becomes how much will the local regulator allow in terms of differences. For example, I know that at least some Air Canada pilots are certified to fly both the 787 and 777, but do need to maintain two type ratings. The rating course, however, is shorter when already rated on one, due to flight deck similarities.
Your results may vary depending on location.
In my jurisdiction, A330 and A350 are considered the same type in terms of licensing. My type rating used to be "A330", but after we got the A350 and I did the course my rating has been "A330/A350". However, if you fly the A32x and the A330, they are considered separate types.
Funnily enough, the A330 and A340, which are basically the same aircraft, don't have a common type rating. Licensing seems to be in a different world from type certification.![]()
I believe the UAE considers 777 and 787 as the same type in terms of licensing.
N1120A wrote:
Hong Kong also seems to think single pilot operation is acceptable on 300 passenger aircraft, another idiotic move.
N1120A wrote:Starlionblue wrote:N1120A wrote:Unlike the 757/767 and the A330/A340, the aircraft you mention are different airplanes on different certificates. The question becomes how much will the local regulator allow in terms of differences. For example, I know that at least some Air Canada pilots are certified to fly both the 787 and 777, but do need to maintain two type ratings. The rating course, however, is shorter when already rated on one, due to flight deck similarities.
