AirKevin wrote:I would think you could use the speed brakes to slow down.
TWA772LR wrote:Hold down the clutch and let it coast if manual. Drop down a gear and take your hand off the throttle if automatic.
WesternDC6B wrote:TWA772LR wrote:Hold down the clutch and let it coast if manual. Drop down a gear and take your hand off the throttle if automatic.
I find opening the window and holding the palm of my hand into the wind also helps.
GalaxyFlyer wrote:AirKevin wrote:I would think you could use the speed brakes to slow down.
Yes, those, too. But good airmanship tries to avoid them.
convair880mfan wrote:I imagine any pilot could answer this. At the bottom of the initial descent portion of a flight and when the wings are still clean and the power is at flight idle, how do you slow the aircraft down? Does an aircraft slow when it is leveled off? Raise the nose? I think someone told me that dumping the gear and lowered flaps slows a plane down but that this is not a sign of good airmanship. Are some airliners easier to slow than others at the bottom of the initial descent?
I think I read on another Forum, with regards to the Boeing 727, that if one could see the landing field over the nose of the aircraft, regardless of one's current altitude, that one could land on it. Not sure what was meant by that. I am guessing that this means that if one could see the runway, no matter how high one was in a 27 that one could descend and slow and land on it. If it is true, is that true of all airliners?
Avgeek21 wrote:GalaxyFlyer wrote:AirKevin wrote:I would think you could use the speed brakes to slow down.
Absolute nonsense. If needed, use them. This old cliche of ‘lever of shame and bad airmanship’ is nonsense. You can’t plan or foresee everything. I’d rather use speedbrakes than flaps to slow down. That’s also our company policy too as flaps are not meant to replace the speedbrakes. And with speedbrakes you are flexible in a way as you can vary your deceleration rate to fit what you need. You fo’t always need full speedbrakes. By extending flaps you are ‘locked’ in that config and deceleration rate.
Starlionblue wrote:You can always use the gear.
IFlyVeryLittle wrote:Generally speaking, is it correct to say that flaps are for flying slower than cruise but not for actually slowing down?
bhill wrote:Welp, I remember a flight from Ft. Benning to Ft. Irwin on a C-141...All the pilot had to do was to open the deflector baffles on the doors for troops to jump out of.....airplane slowed down real quick...got kinda bumpy too!!.
mxaxai wrote:Do any aircraft prohibit simultaneous use of speed brakes and flaps? In my experience, the speed brakes usually get stowed before flaps are extended but I'm not sure if this is required or just a choice by the crews.
GalaxyFlyer wrote:It’s rare you need both and probably more drag and quick energy loss than is advisable.
GalaxyFlyer wrote:mxaxai wrote:Do any aircraft prohibit simultaneous use of speed brakes and flaps? In my experience, the speed brakes usually get stowed before flaps are extended but I'm not sure if this is required or just a choice by the crews.
B727 didn’t allow the combination of flaps and speed brakes, most newer types do with some restrictions. It’s rare you need both and probably more drag and quick energy loss than is advisable.
zeke wrote:With a car it is mainly the friction of the wheels on the road.
vikkyvik wrote:zeke wrote:With a car it is mainly the friction of the wheels on the road.
Do you mean friction in the wheel bearings?
Also I think aerodynamic drag on a car is probably the main stopping factor if you're coasting.
kalvado wrote:Wheel friction likely comes from tire and road deformation. At low speed that would be the dominant energy loss, I assume.
vikkyvik wrote:
Perhaps true. Oddly, can't find many authoritative articles on the subject.
TheSonntag wrote:Can you "slip" airliners? The C172 is bad at it, but for microlights it is great (left rudder, right aileron, and down you go).
