alasizon wrote:Happens all the time in North America, far less common elsewhere.
Majority of the time in the US is either due to ramp error (bringing in the wrong aircraft) or gate changes after the initial gate assignment was communicated in-range.
blacksoviet wrote:alasizon wrote:Happens all the time in North America, far less common elsewhere.
Who decides which flights get assigned to a gate? Is it the airline or the airport owner?
Do airlines allow competitors to borrow their gates in an emergency?
alasizon wrote:blacksoviet wrote:alasizon wrote:Happens all the time in North America, far less common elsewhere.
All varies by airport. At most airports now, certain carriers have their own leased gates that they control and have exclusive access over and then there is a small contingent of common use gates that the airport controls.
As far as borrowing gates, it all depends on the setup in the given airport and who the two carriers are. Most airlines are hesitant from a safety perspective from borrowing gates they've never used, never fit tested and never verified work properly with their procedures.
dfwjim1 wrote:Is at all common for aircraft to arrive at an incorrect gate due to air and/or ground crew error? I am thinking it might be a thing at larger/busier airports.
e38 wrote:alasizon wrote:Happens all the time in North America
No it doesn't.
alasizon wrote:e38 wrote:alasizon wrote:Happens all the time in North America
No it doesn't.
I can assure you it does. Just going off internal reports this week, we had 18 aircraft into the wrong gate, seven of which were crew caused (turned into the wrong gate and we chose to keep them there since they couldn't turn out again safely) and the rest ramp caused (all identified the wrong tail but right A/C type and crew chose the gate with the ramp crew). Part of the issue locally is inbound aircraft don't check in with ramp control or company radio, ground handles them from the runway to the gate (ramp control and ground communicate via Aerobahn).
Across the hall, Southwest had 8 this week that I know of (all turned into the wrong alleyway). That's just one airport and I was on a team a few years back designed to help another station that was having 15-20 per day due to on the ground/almost on the ground gate changes
blacksoviet wrote:alasizon wrote:e38 wrote:
No it doesn't.
Does it really matter if the wrong tail number goes to the gate if the aircraft type is the same?
Avgeek21 wrote:I made that mistake once on a 737. No idea why but I turned into the wrong gate at home base. Mistook 07L for 07R. By the time I realized I couldn’t get out anymore as there was a company on either side. Embarrassing; yes. Big deal; no. Informed ATC and our ground handling and made an air safety report stating it was my error. Airfield ops came to take my statement and that was it. Never heard anything ever again. Trust me, I’m paranoid now of turning into the wrong gate. Lol.
blacksoviet wrote:Avgeek21 wrote:I made that mistake once on a 737. No idea why but I turned into the wrong gate at home base. Mistook 07L for 07R. By the time I realized I couldn’t get out anymore as there was a company on either side. Embarrassing; yes. Big deal; no. Informed ATC and our ground handling and made an air safety report stating it was my error. Airfield ops came to take my statement and that was it. Never heard anything ever again. Trust me, I’m paranoid now of turning into the wrong gate. Lol.
Why did you inform ATC? Do they really care what gate you are at?
CrimsonNL wrote:Happens occasionally at AMS, most often at the "regional" stands that are not connected to the terminal, or on the cargo ramp. Some positions are a bit difficult to observe from the tower so ATC don't always notice it. Sometimes it's a crew error. Sometimes the ground handlers are a bunch of morons and they show up and switch on the guidance system at the wrong stand. You can imagine a flight crew docking at the wrong stand when it's the only one "lit up" in the middle of the night.
Just the other day we had an A319 park at the wrong gate. A second flight of the airline was coming in just a few minutes later at the adjacent position, but the first aircraft parked at the wrong stand where the ramp guys were waiting for the second aircraft. Their handling agent is awful so they probably didn't even notice they were offloading the wrong aircraft. It was only discovered when the second aircraft arrived and mentioned that their assigned position was taken.
Drucocu wrote:
Just a quick slightly off topic guess. Menzies?
No it doesn't.
dfwjim1 (topic author), certainly it happens once in a while, but it is very rare.
Both air and ground crews understand that getting the right aircraft to the right gate is important to the integrity of the company's schedule and the operation of the airport and work hard to make it so.
In the United States, most airlines have their own gates at most of the airports they serve--either owned or leased. At my company, on the preflight paperwork I receive before the flight (e-flight plan), the expected arrival gate is annotated so I know the projected arrival gate at my destination even before departure from the origin airport. Furthermore, when we send the "in-range" message at least 30 minutes prior to arrival, the arrival gate is also listed. The expected taxi plan from exiting the runway to the parking gate/stand is part of the arrival briefing between the pilots. Should the gate change after that time, we get an ACARS alert after landing so there is time to review the change once clear of the runway and stopped on a taxiway before proceeding to the assigned gate.
At airports where we use "common-use" gates, we contact either ground control, ramp control, apron control (Canada), "gate management," or other airport operations frequency for gate assignment. The frequency and agency is listed in our airport operation pages of our manuals.
Even at airports where we use common use gates, in general the gates are in the same location of the terminal so even if not specifically assigned prior to arrival, we have a pretty good idea where we will be parking.
With regard to your last sentence, "I am thinking it might be a thing at large/busier airports."
Jim, based upon the amount of ground activity that goes on at busy airport--aircraft movements, vehicular traffic, radio chatter, personnel on the ramp, perhaps crossing active runways to get to the gate, etc--most crews seem to have a "heightened" sense of awareness and are very attentive to their gate assignment and parking procedures.
e38
Hah! No more guessing for you. In their defense though, all the local competition is just as bad.
