BN727227Ultra
No-wind conditions at parallel runway airports:
Thu Jan 13, 2022 1:48 am
On a mild, calm day at STL (late-1960s), I saw four consecutive aircraft take off in four directions (6, 24, 12R, 30L).
On a calm day present-day--ATL for the sake of discussion, can there be different flows on different runways, or still all-east or all-west like on a 'normal' day? Or does that mess things up too badly?
adipasqu
Re: No-wind conditions at parallel runway airports:
Thu Jan 13, 2022 3:02 am
At LAX (4 parallel runways), their night ops will land aircraft to the east on the North complex while departures are to the west on the South complex for noise abatement reasons assuming weather/winds cooperate. During the day you would never do this as it will kill the arrival rate since you couldn't do simultaneous parallel approaches to both complexes. In general, to get the most efficient use of airspace and runways, you want all traffic going the same direction. This is a big reason O'Hare has reconfigured its airfield from essentially 3 sets of intersecting runways to a now mostly all parallel setup save for the two crosswind runways.
Thu Jan 13, 2022 3:35 am
Your example is from late 60s. Much less traffic compared to today (pre-Covid), so that stuff is possible. Nowadays, traffic volumes mean you'll typically just see unidirectional traffic at busier times.
In many places, e.g. HKG, HND, and BKK, a certain direction is preferred, typically due to noise abatement, so if winds are light that's what you get by default.
BN727227Ultra
Fri Jan 14, 2022 2:39 pm
Thanks, both of you!
N1120A
Fri Jan 14, 2022 11:33 pm
Noise and other environmental concerns pretty much run the preferred format of flow, as does airspace. LAX is a key example of both. The airport is right on the coast and basically at one end of an airspace that includes a bunch of other airports, so it makes sense to go the way they do.
Cubsrule
Sun Jan 16, 2022 6:32 pm
In a few places, counter-flow operations happen for other operational reasons. SAN in low visibility is a good example. 27 departures are almost universal, but 9 has an ILS and 27 does not so when the marine layer sets in they land and depart over the ocean.
futureatp
Tue Jan 18, 2022 5:05 pm
I've seen this happen at KPHX several times. Every now and then during night ops and then also right around the 12:00 hour.
Typical calm wind Phoenix ops are, departures arrivals heading to the East and then a switch over to the west. I never did ask as to the exact reason why.. Almost as if there is a slight prevailing wind away from the angle of the sun there. Switchover happened during a break in US Airways arrival departure banks (showing how long ago it has been since I've seen this). Every now and then I'd catch a departure and arrival opposite direction of each other. Two NW 757s come to mind as aircraft I've seen heading the opposite direction of each other.
Night time I would imagine just for convenience as nothing much is going on after the red-eyes departed.
rjsampson
Wed Jan 19, 2022 6:34 pm
Which brings me to another question about SAN, during no-wind conditions. Let's say the traffic is light. 27 departures are still going to be standard, but for Eastbound flights, could a pilot request a RWY 9 departure, to save considerable fuel rather than, say flying the the fuel-consuming ZZOOO departure (for example)?
Expanding that question: Where traffic and weather permits, is it common for pilots to request departures other than the active departure runway to gain favorable fuel-savings? If not, why?
GalaxyFlyer
Wed Jan 19, 2022 6:53 pm
KSAN has a pretty good-sized weight penalty for 09, but if TOGW and local ATC allows, yes you could use 09.
mxaxai
Wed Jan 19, 2022 7:17 pm
I wouldn't call it common but it does happen occasionally at smaller airports or during less busy times.
Users browsing this forum: shamrock137 and 17 guests
