joejohn wrote:they say if an airplane experiences double engine failure, it won't just fall out of the sky (I find this hard to believe)
they say because the airplane is gliding through the air
if the airplane won't crash and will just glide through the air, then why do we hear on the news airplanes crash?
N1120A wrote:The two primary reasons aircraft crash are CFIT and loss of control. And by crash, I don't mean make forced landings, but where there is loss of life and/or the the aircraft is written off. The vast majority of SINGLE engine engine failure incidents lead to no loss of life, no injury and repairable damage. In lighter aircraft, twins actually have a higher incidence of accidents because of loss of control on the loss of a single engine. Think about that.
Airplanes are made to fly, not to drop.
ACDC8 wrote:Aircraft have a glide ratio, meaning a specific distance it can travel (with no power) for every specific amount of altitude it looses. Its been a while, but IIRC in a C172 its something like 9:1, so for every 1000 feet of altitude you lose, you can travel 9000 feet of distance - of course, other factors always play into the situation. Airliners are no different.
Why do we hear about airplanes crashing, well, thats because there are a hundred different reasons why an aircraft crashes, not just loss of power. As for loosing power, that is something that is trained for by the pilots and as pointed out above, is perfectly possible to safely land an aircraft that has lost all power.
And no, aircraft don't just "fall out of the sky", in just about every accident, there is a chain of events that lead to the accident.
Starlionblue wrote:I'll add that the glide ratio of an airliner is way better than a Cessna 172. More like 1:15-20. For every 10000 feet, you can expect to glide 30 nautical miles at best glide speed. Plenty of time to try to restart the engines and look for landing options.
ACDC8 wrote:Starlionblue wrote:I'll add that the glide ratio of an airliner is way better than a Cessna 172. More like 1:15-20. For every 10000 feet, you can expect to glide 30 nautical miles at best glide speed. Plenty of time to try to restart the engines and look for landing options.
Oh for sure, gliding characteristics of modern airliners is incredible, and with the the altitude they fly, gives them a big advantage over a single engine prop.
BoeingGuy wrote:The 787 glide ratio is supposedly so high it’s proprietary information. I don’t know the exact number. I assume Airbus models are equally efficient.
The only light single that probably glides worse than a 172 is a Cirrus. A Mooney will do 11:1 (maybe more). A DA40 will do 13:1. As noted, most modern airliners do 20:1 or more. And they're doing it from up high.
Bob Pearson had to slip C-GAUN into Gimli, and did it successfully.
Woodreau wrote:not an airliner, but here is a recent video of a plane last month that lost all engine power and made a forced landing. The pilot managed his energy really well and even taxied off the runway using residual energy.
Try a PA28-201: the plane falls from the sky like a stone as soon as you go idle.
phugoid1982 wrote:If anyone cares, a simple formula to calculate max gliding range is Range=(L/D)*height. L/D max is the same as CL/CD and this occurs when the zero lift drag coefficient is equal to the induced drag coefficient. The speed for this flat glad varies with the square root of (1/density) so as you descend you will slow down incrementally.
flipdewaf wrote:phugoid1982 wrote:If anyone cares, a simple formula to calculate max gliding range is Range=(L/D)*height. L/D max is the same as CL/CD and this occurs when the zero lift drag coefficient is equal to the induced drag coefficient. The speed for this flat glad varies with the square root of (1/density) so as you descend you will slow down incrementally.
I’m having an argument with myself whether this is correct or not. In flight the point where zero lift drag and lift induced drag are equal is where you get max endurance (minimum drag) but this isn’t maximum specific range, this is when UL/D is at its maximum or at the speed when the tangent from the drag slope intersects the origin.
Now the bit that I’m wrestling with is does the energy source change (from fuel to gravity) change the aerodynamic equation? Will gliding at max L/D give you max time aloft and gliding at max UL/D still give you the greatest glide distance?
I feel I can convince myself either way and therefore neither way.
Fred
Sent from my iPad using Tapatalk
Fred
phugoid1982 wrote:flipdewaf wrote:phugoid1982 wrote:If anyone cares, a simple formula to calculate max gliding range is Range=(L/D)*height. L/D max is the same as CL/CD and this occurs when the zero lift drag coefficient is equal to the induced drag coefficient. The speed for this flat glad varies with the square root of (1/density) so as you descend you will slow down incrementally.
Fred
It's easier for me to explain mathematically. I'm not sure where you got that max endurance occurs at L/D max which is Cd0=Cdi which is incorrect.
phugoid1982 wrote:As for U*(L/D) I think you got that from the breguet range equation for horizontal flight which when you use the small angle approximation, Wcos(theta)=L so W=L so that approximation applies for gliding flight.
phugoid1982 wrote:Remember U (assuming you meant velocity) is a function of Weight also so the force balance gives U=sqrt(2W/rho*S*Cl). Hence U (L/D) when you multiple through is proportional to sqrt(L)/D not L/D and this is for steady powered flight.
phugoid1982 wrote:As for gliding flight, the easiest way to derive this is to draw a force balance diagram. (I apologize in advance because i'm sure you know this but i'm doing for the benefit of the non engineers on this forum so please don't feel like i'm being a condescending jerk.)
phugoid1982 wrote:The force balance setting thrust to 0 yields Wsin (theta)=D and Wcos(theta)=L. So dividing through D/L=tan (theta). If you draw a triangle of the descent phase you'll also see that tan (theta)=height/horizontal distance covered (Range). Therefore (D/L)=H/R or rather (L/D)H=R which is the same as (CL/CD)*H=R. To find the relationship between CD0 and CDi for L/Dmax take the derivative of (CL/CD) with respect to CL and set to zero keeping in mind that CD=CD0+CDi and you will get that exactly CD0=CDi.
phugoid1982 wrote:
Now wrt to endurance, remember range is about minimizing loss of height per unit distance. Endurance is about minimizing sink rate. Therefore the sink rate is given by Vsin(theta) which is V(Theta) for small angles and equal to DV/W from the force balance. Substituting V=sqrt(2W/rho*SCL)) you'll get that sink rate is minimized when CD/CL^(3/2) is smallest. Again, taking the derivative of this quantity wrt to CL you you will get that this occurs when 3Cd0=Cdi. At the end of the day the Velocity for max endurance is slightly smaller than that for max range. That's why when sailplane pilots encounter thermals they fly slower to maximize time in the updraft and then once it dies accelerate to Vmax range to cover the most ground and find another thermal.
Hope I make sense,
Vik
flipdewaf wrote:phugoid1982 wrote:flipdewaf wrote:No problem, youarent being condescending at all, this is exactly what I love about this place and you highlight the piece I hadn't thought about correctly.
Starlionblue wrote:A common problem with jets is not being able to get down fast enough on approach. In a propeller plane, you can use the props to get you down, or even slip if you're in a light aircraft. In an airliner, descent requires advance planning. A typical descent starts 120 nautical miles from the runway, and much of it will be at idle power. If you get a significant shortcut when already on approach, it's time to go full speedbrake.
The saying is that "you can go down or slow down, but not both".
I appreciate that. I too enjoy these mathematical digressions. I didn't want to cheat and go to my aircraft performance books and pull out a formula. It was quite fun working it out on my own. One thing my late father who was a brilliant engineer always taught me to heart is always derive everything from first principles and don't just memorize equations which is good advice. Considering i've been in industry so long I wanted to see if my brain cells are still functional. It's also tough to explain without visuals so I found this pdf from Princeton which might be helpful.
http://www.stengel.mycpanel.princeton.e ... cture9.pdf
BoeingGuy wrote:
Modern jetliners like the 777 have at least a 20:1 glide ratio. The 787 glide ratio is supposedly so high it’s proprietary information. I don’t know the exact number. I assume Airbus models are equally efficient.
The rule of thumb that I’ve heard is 2 miles gliding for every 1000 of altitude loss, but the Air Transat A330 well exceeded that.
I would be very surprised if Boeing does not published numbers for the 777/787 in the checklist for all engine flameout, the A330 they say 100nm from FL400 (15:1), and with gear and flap down 9:1.
BoeingGuy wrote:Be surprised. The Boeing Dual Eng Fail/Stall checklists do not give any kind of gliding guidance to the crew. The checklist assumes you get at least one engine started and have a nice day. There is no branch of the checklist for what to do in case you don't get an engine started.
MPadhi wrote:Starlionblue wrote:A common problem with jets is not being able to get down fast enough on approach. In a propeller plane, you can use the props to get you down, or even slip if you're in a light aircraft. In an airliner, descent requires advance planning. A typical descent starts 120 nautical miles from the runway, and much of it will be at idle power. If you get a significant shortcut when already on approach, it's time to go full speedbrake.
It's a bit of a tangent, but this got me thinking - are there any ways to slow down and go down in an emergency. Let's say there's an in flight fire - would the best strategy be to go as fast and close to your destination. Let's say 550kts, out to 100 miles out. Then slow down enough to extend flaps, gear, and speedbrakes, then put the aircraft in a 90 degree roll so you're dumping all lift whilst having all drag devices out.
Is this feasible in an emergency, or would it create further issues?
zeke wrote:BoeingGuy wrote:Be surprised. The Boeing Dual Eng Fail/Stall checklists do not give any kind of gliding guidance to the crew. The checklist assumes you get at least one engine started and have a nice day. There is no branch of the checklist for what to do in case you don't get an engine started.
Interesting, not something that is impossible to happen, aware of 3 dual engine failure/dual thrust loss events on the 787, Jetstar, ANA, Royal Brunei.
Starlionblue wrote:MPadhi wrote:Starlionblue wrote:A common problem with jets is not being able to get down fast enough on approach. In a propeller plane, you can use the props to get you down, or even slip if you're in a light aircraft. In an airliner, descent requires advance planning. A typical descent starts 120 nautical miles from the runway, and much of it will be at idle power. If you get a significant shortcut when already on approach, it's time to go full speedbrake.
As mentioned you would not be doing 550 knots, at least not with the aircraft in one piece. At most something like 330 indicated.
There's no need to slow down in an emergency descent. The goal is to get down to a safe altitude ASAP.
To get down fast you need to fly fast*. Accelerate to Vmo (in practice just under for a bit of margin), speedbrakes out, idle thrust. If you have the gear down you'd descend slower since the gear limit speed is well below Vmo (250kts on the A330).
Descent rates in excess of 6000fpm are typical. In case of suspected structural damage, you'd keep the speed where it was, and consequently descend slower.
90 degree roll is not recommended. Besides, not possible on the 'bus in Normal Law. It would definitely create "further issues".
Another case is uncontrollable fire. Keep your speed as high as possible until you're about 15nm from the runway and 4000 feet-ish. Then idle thrust, full speedbrake. At gear limiting speed, gear out, then flaps out in stages at the limit speeds. This gives you the fastest possible approach. Do give yourself a bit of margin because if you leave it too late you'll be going too fast to land and have to go around, which would be unideal in this situation. Again though, you're not going down and slowing down at the same time. You go down, then slow down.
* This also applies to normal approaches. If you're high on profile keeping your speed up lets you descend faster. If you are instructed to "descend to 10000 and slow to 210," but are currently fast and high, the best strategy is often to descend fast to 10000, then slow. Don't try to do both at once.
BoeingGuy wrote:ACDC8 wrote:Starlionblue wrote:I'll add that the glide ratio of an airliner is way better than a Cessna 172. More like 1:15-20. For every 10000 feet, you can expect to glide 30 nautical miles at best glide speed. Plenty of time to try to restart the engines and look for landing options.
zeke wrote:At what speed ? In what configuration?
Sounds like something I should try if I have some spare time in the sim
thepinkmachine wrote:BoeingGuy wrote:ACDC8 wrote:Oh for sure, gliding characteristics of modern airliners is incredible, and with the the altitude they fly, gives them a big advantage over a single engine prop.
Haven’t seen the numbers either, but the 787 is capable of flying a 3 degree ILS with both engines out… On autopilot and with autoland! (At least in the simulator)
