indcd wrote:Just curious: twice recently I’ve seen a BA 787-900 takeoff near my house (6 miles off Rwy 30 at KIAD) - at 2,500-3,000 feet they still have the gear down. No other plane has the gear down this long. In fact, a Lufthansa 747-800 just took off - a bit lower than the BA was - and it was in a clean config.
Just wondering if this is BA SOP or why they keep the gear down so long. Thx!
MalevTU134 wrote:indcd wrote:Just curious: twice recently I’ve seen a BA 787-900 takeoff near my house (6 miles off Rwy 30 at KIAD) - at 2,500-3,000 feet they still have the gear down. No other plane has the gear down this long. In fact, a Lufthansa 747-800 just took off - a bit lower than the BA was - and it was in a clean config.
At BA, the flight crew are always served a lovely kidney pie followed by a delightful spotted dick by the flight attendants just as they line up on the runway. So the pilot flying has to finish his meal and order a vodka martini, shaken, not stirred, before he can retract the gear. Other than that, when you see gears down for longer than normal, it's to cool the brakes down after heavy braking on arrival and a relatively short turn-around, so they don't have time to cool off on the ground. Nothing specific to BA, nor to the 787, as far as I know.
And it's Boeing 747-8, not -800
SL1200MK2 wrote:That’s very interesting regarding the short turn times. Anyone have any info on how long breaks typically take to cool down? Let’s say on a 70 degree day?
Boof02671 wrote:It’s to cool the brakes. I’ve seen Airbus narrow bodies do it also and they even cooling fans that are used in the ground.
Starlionblue wrote:Boof02671 wrote:It’s to cool the brakes. I’ve seen Airbus narrow bodies do it also and they even cooling fans that are used in the ground.
Brake fans are an option on the A330. I think the same on the A32x.
zeke wrote:How short would your sector have to be to still have warm brakes on landing?SL1200MK2 wrote:That’s very interesting regarding the short turn times. Anyone have any info on how long breaks typically take to cool down? Let’s say on a 70 degree day?
On the A330 I can have the brakes at 400 deg C 40 minutes before push and it will be okay for a 20 minute taxi, they will drop around 5 degC per minute. It is preferable to have the carbon brakes warm rather than cold anyway, they perform better when warm with less wear. Takeoff can be commenced with brakes temperature up to 300 deg C. If you know the brakes are warm from the previous sector and you know you have a short turn around, nothing wrong with putting the gear down early to cool them.
The OAT has little effect on cooling time, airflow over the brakes is what cools them best. Portable brake fans do that exactly.
Normally the reason for leaving the gear down is not brake cooling, it is for brake related MEL procedure, and we wait for whatever time is specified in the MEL for the gear to stop spinning before retracting.
For example on the 787 if any of the following are inoperative the MEL requires the gear to left down
Antiskid control system - leave gear down for 2 minutes after departure
Nose gear spin down brake - leave gear down for 2 minutes after departure
Wheel brake system - leave gear down for 2 minutes after departure
zeke wrote:Normally the reason for leaving the gear down is not brake cooling, it is for brake related MEL procedure, and we wait for whatever time is specified in the MEL for the gear to stop spinning before retracting.
ReverseFlow wrote:How short would your sector have to be to still have warm brakes on landing?
zeke wrote:Thanks.ReverseFlow wrote:How short would your sector have to be to still have warm brakes on landing?
60-90 min, also depends how heavy you are landing each time
ReverseFlow wrote:zeke wrote:Thanks.ReverseFlow wrote:How short would your sector have to be to still have warm brakes on landing?
Short flight for an A330.
Where's the A330R when you need it
Starlionblue wrote:ReverseFlow wrote:zeke wrote:Thanks.
Short compared to the design range, I suppose, but not really a short sector for an A330 in East and Southeast Asia. Widebodies routinely do 1-3 hour flights.
BoeingGuy wrote:Starlionblue wrote:Boof02671 wrote:It’s to cool the brakes. I’ve seen Airbus narrow bodies do it also and they even cooling fans that are used in the ground.
That’s interesting. Boeing hasn’t offered brake fans on any model, to my knowledge, for over 20 years. I think they were offered as an option on the 777 pre-2000.
LH707330 wrote:Airbus has a brake-to-vacate (BTV) system that allows the pilot to choose a taxiway they want to exit the runway on. This then calculates the deceleration required and applies the brakes accordingly. At the end, the aircraft reaches a certain speed at the taxiway.Related question: to what extent does deceleration rate affect brake heating? Doesn't the same amount of energy need to get dissipated either way? The only thing I can think of that would make a big difference is using more TR or spoilers on a longer runway and thus having to do less braking.
LH707330 wrote:Related question: to what extent does deceleration rate affect brake heating? Doesn't the same amount of energy need to get dissipated either way? The only thing I can think of that would make a big difference is using more TR or spoilers on a longer runway and thus having to do less braking.
zeke wrote:Max auto brake is a takeoff setting, not used for landing
Yikes! wrote:if a takeoff and subsequent RTO occurs without sufficient brake cooling from a previous landing, brake efficiency is reduced, increasing the RTO stopping distance.
zeke wrote:On the A330 I can have the brakes at 400 deg C 40 minutes before push and it will be okay for a 20 minute taxi, they will drop around 5 degC per minute.
trent768 wrote:zeke wrote:On the A330 I can have the brakes at 400 deg C 40 minutes before push and it will be okay for a 20 minute taxi, they will drop around 5 degC per minute.
400°C?! Jesus christ! When I heard people here talking about hot brakes, I thought it was around 150°C!
celestar345 wrote:trent768 wrote:zeke wrote:On the A330 I can have the brakes at 400 deg C 40 minutes before push and it will be okay for a 20 minute taxi, they will drop around 5 degC per minute.
as Zeke mentioned, unlike the brakes on your car (which mostly are iron brake discs) these brakes are carbon-carbon which works better with temperature, and as a reference on the 777 the BTMS (brake temperature monitoring system) the displayable range is from 38°C to 1038°C, with BRAKE TEMP advisory if above 538°C. So 400°C is really just normal operation.
77west wrote:I am picking at 1038 °C you have other issues other than just hot brakes!!
