indcd
Curious: BA Takeoff Procedures - Gear Retraction
Mon Apr 04, 2022 10:49 pm
Just curious: twice recently I’ve seen a BA 787-900 takeoff near my house (6 miles off Rwy 30 at KIAD) - at 2,500-3,000 feet they still have the gear down. No other plane has the gear down this long. In fact, a Lufthansa 747-800 just took off - a bit lower than the BA was - and it was in a clean config.
Just wondering if this is BA SOP or why they keep the gear down so long. Thx!
MalevTU134
Re: Curious: BA Takeoff Procedures - Gear Retraction
Mon Apr 04, 2022 11:01 pm
At BA, the flight crew are always served a lovely kidney pie followed by a delightful spotted dick by the flight attendants just as they line up on the runway. So the pilot flying has to finish his meal and order a vodka martini, shaken, not stirred, before he can retract the gear. Other than that, when you see gears down for longer than normal, it's to cool the brakes down after heavy braking on arrival and a relatively short turn-around, so they don't have time to cool off on the ground. Nothing specific to BA, nor to the 787, as far as I know.
And it's Boeing 747-8, not -800 :)
SL1200MK2
Mon Apr 04, 2022 11:10 pm
That’s very interesting regarding the short turn times. Anyone have any info on how long breaks typically take to cool down? Let’s say on a 70 degree day?
WayexTDI
Mon Apr 04, 2022 11:45 pm
And Boeing 787-9, not -900.
indcd
Mon Apr 04, 2022 11:46 pm
Oh well - so my nomenclature was off - guess I was reverting back to the 737 names. Thanks for the clarity.
indcd
Mon Apr 04, 2022 11:52 pm
Today was a 3 1/2 hour turn. That’s seems like a fairly long time. And it’s 55 degrees today.
AA757223
Tue Apr 05, 2022 12:00 am
Only reason I can think of is to cool the brakes. Short turn times coupled with sitting in a long taxi line repeatedly using the brakes. Did it a few times in the E145 but never as long as you’re describing
Boof02671
Tue Apr 05, 2022 12:06 am
It’s to cool the brakes. I’ve seen Airbus narrow bodies do it also and they even cooling fans that are used in the ground.
zuckie13
Tue Apr 05, 2022 1:52 am
Could also be an inop brake. They leave the gear down until the wheels stop spinning. Normally the brakes are used to stop the wheels before retraction. Avoids stresses on the gear components. Think that experiment you did in school where you hold the spinning bike wheel thing on the spinning chair.
Tue Apr 05, 2022 4:34 am
Brake fans are an option on the A330. I think the same on the A32x.
Flow2706
Tue Apr 05, 2022 5:36 am
I can confirm that. My company doesn’t have brake fans on A320/321s but still does short (35-40 minutes) turnarounds even on airports with a very short, 1700m runway, however there are a few things you can do to keep brake temperatures under control. One of them is using flap full and maximum reverse for landing (using full reverse is not a very economic option as it generates additional costs, however it’s preferable over a delay to cool the brakes). If a long taxi after landing is expected single engine taxi also helps to reduce the amount of energy that has to be absorbed by the brakes (not always an option, especially if there is a big upslope on a taxiway somewhere). A proper braking technique also helps - the one recommended by Airbus to let the aircraft accelerate to 30kts and then using brakes to bring is back to 10kts to let it accelerate again works quite well to reduce the number of brake applications and also helps to keep the temperatures down. Once the chocks are confirmed in place after parking, releasing the parking enables faster brake cooling. Therefore brake cooling is usually not a big issue if proper techniques are applied.
Even on aircraft that are equipped with brake fans there can be MEL items that result in longer cooling times (either the fans themselves or the brake temperature indication system).
Tue Apr 05, 2022 7:31 am
On the A330 I can have the brakes at 400 deg C 40 minutes before push and it will be okay for a 20 minute taxi, they will drop around 5 degC per minute. It is preferable to have the carbon brakes warm rather than cold anyway, they perform better when warm with less wear. Takeoff can be commenced with brakes temperature up to 300 deg C. If you know the brakes are warm from the previous sector and you know you have a short turn around, nothing wrong with putting the gear down early to cool them.
The OAT has little effect on cooling time, airflow over the brakes is what cools them best. Portable brake fans do that exactly.
Normally the reason for leaving the gear down is not brake cooling, it is for brake related MEL procedure, and we wait for whatever time is specified in the MEL for the gear to stop spinning before retracting.
For example on the 787 if any of the following are inoperative the MEL requires the gear to left down
Antiskid control system - leave gear down for 2 minutes after departure
Nose gear spin down brake - leave gear down for 2 minutes after departure
Wheel brake system - leave gear down for 2 minutes after departure
eta unknown
Tue Apr 05, 2022 1:32 pm
I also recall being on a BA TriStar LHR-JFK and there was an air con problem- the pilot said the gear doors world remain open longer than normal in order to get some cooler air into the cabin. Whether this explanation was true or not I don't know, but it worked- the cabin was unpleasantly warm on departure and after a few minutes airborne the temperature was normal.
ReverseFlow
Tue Apr 05, 2022 8:40 pm
How short would your sector have to be to still have warm brakes on landing?
I once saw the aftermath of a wet and then frozen brake which seized at landing - it obviously had to be rejected.
But granted the brake temp at take-off was under 190°C after a short tax and a couple hours flight and the water wasn't fully gone out of the brake at take-off.
Incidentally it takes months to make a carbon brake.
https://www.meggitt.com/insights/how-do ... on-brakes/
indcd
Tue Apr 05, 2022 10:55 pm
Super helpful and insightful. Thanks, zeke.
Tue Apr 05, 2022 11:29 pm
60-90 min, also depends how heavy you are landing each time
ReverseFlow
Wed Apr 06, 2022 5:25 am
Thanks.
Short flight for an A330.
Where's the A330R when you need it
Wed Apr 06, 2022 6:44 am
ReverseFlow wrote:
Thanks.
Short compared to the design range, I suppose, but not really a short sector for an A330 in East and Southeast Asia. Widebodies routinely do 1-3 hour flights.
77west
Thu Apr 07, 2022 1:31 am
Starlionblue wrote:
ReverseFlow wrote:
Thanks.
Same here in NZ/AUS. We have plenty of A330, B777, B787 all on the 2.5-3.5 hour trans Tasman flights. Heck, we used to have EK A380s as well!
BoeingGuy
Thu Apr 07, 2022 2:48 am
That’s interesting. Boeing hasn’t offered brake fans on any model, to my knowledge, for over 20 years. I think they were offered as an option on the 777 pre-2000.
Thu Apr 07, 2022 5:19 am
Anecdotally, it seems to be one of those philosophy differences between Boeing and Airbus. As I understand it, Airbus saves some weight by having less beefy brakes, but this often leads to hotter brakes.
Aircraft design compromise, like many others.
LH707330
Thu Apr 07, 2022 12:19 pm
Related question: to what extent does deceleration rate affect brake heating? Doesn't the same amount of energy need to get dissipated either way? The only thing I can think of that would make a big difference is using more TR or spoilers on a longer runway and thus having to do less braking.
ReverseFlow
Thu Apr 07, 2022 1:48 pm
Airbus has a brake-to-vacate (BTV) system that allows the pilot to choose a taxiway they want to exit the runway on. This then calculates the deceleration required and applies the brakes accordingly. At the end, the aircraft reaches a certain speed at the taxiway.
Apparently this saves from brake wear. So to answer your question, it's probably better than using max autobrake all the time (and avoids everyone being slammed into their safety belts all the time!).
https://www.flightglobal.com/easa-clear ... 32.article
Thu Apr 07, 2022 3:51 pm
Max auto brake is a takeoff setting, not used for landing
thepinkmachine
Thu Apr 07, 2022 9:00 pm
The deceleration rate does affect the brake heating significantly. The way auto brakes work is that they aim to achieve a constant deceleration rate of the a/c and the energy dissipation is shared between brakes, thrust reverser and aerodynamic drag.
The higher the auto brake setting, the higher share of the total energy is absorbed by the brakes.
On the 787, The lowest auto brake setting results in 50-65% of the energy absorbed by the brakes, as compared to max manual braking.
Thrust reversers also reduce energy absorbed by the brakes and the amount depends on auto brake setting. When the deceleration is high (ie. max auto), the share of energy absorbed by reversers is small.
At low auto brake setting the reversers have time to work and may reduce brake energy by up to ~60%
We can take it even further - it takes approximately 2700-3000m of runway to slow down the airplane to taxi speed with aerodynamic drag and idle reverse thrust only, without touching the brakes*. So on very long runways the brake energy may effectively be zero.
Another issue all together is whether it makes sense to ‘save’ the brakes by keeping them cool. It might have had sense with steel brakes, which are less common these days. OTOH carbon brakes don’t care as much about temperature - in fact, they operate most efficiently when (moderately) hot. Actually, according to some sources, the highest wear occurs during taxi out, when the brakes at cool, rather than on landing…
* disclaimer: I don’t advocate this technique- do whatever your FCOM/FCTM/SOP says.
Yikes!
Fri Apr 08, 2022 2:22 am
Not to mention, minimum turnaround times are determined by brake energy efficiency on a subsequent rejected takeoff. For instance, if a takeoff and subsequent RTO occurs without sufficient brake cooling from a previous landing, brake efficiency is reduced, increasing the RTO stopping distance.
I'm surprised this hasn't entered into the discussion.
e38
Fri Apr 08, 2022 3:05 am
It is my understanding that as long as we honor the "maximum brake temperature limit for takeoff," (300 degrees C A320) the takeoff data--including the stopping distance--will be valid.
We really don't consider turn time as long as we respect the specified max temperature limit before initiating takeoff.
e38
Fri Apr 08, 2022 3:58 am
Correct for Airbus
BoeingGuy
Fri Apr 08, 2022 5:25 am
Actually Boeing has a Max autobrake setting for landing. The takeoff setting is RTO.
LH707330
Sun Apr 10, 2022 4:47 pm
Thanks all, that makes sense.
trent768
Tue Apr 12, 2022 12:16 pm
400°C?! Jesus christ! When I heard people here talking about hot brakes, I thought it was around 150°C!
Tue Apr 12, 2022 12:45 pm
400 is not uncommon, 150 on the A330 is very low after landing. It is okay for them to absorb energy.
Wed Apr 13, 2022 1:08 am
You're stopping a 200-tonne aircraft that is doing 140 knots in a few thousand feet. That's a LOT of energy. :D
Doing the walkaround on a short turn, you can definitely feel the heat coming off the brakes when you check the tyres and brake wear indicators.
celestar345
Fri Apr 15, 2022 3:19 am
as Zeke mentioned, unlike the brakes on your car (which mostly are iron brake discs) these brakes are carbon-carbon which works better with temperature, and as a reference on the 777 the BTMS (brake temperature monitoring system) the displayable range is from 38°C to 1038°C, with BRAKE TEMP advisory if above 538°C. So 400°C is really just normal operation.
77west
Sat Apr 16, 2022 10:01 pm
I am picking at 1038 °C you have other issues other than just hot brakes!!
celestar345
Mon Apr 18, 2022 2:40 am
If the pilots decides to ignore all the EICAS messages and get to that point without good reason, then I would say they brought it upon themselves....
scbriml
Fri Apr 22, 2022 8:04 pm
Saw a similar thing with this Air India 787 out of Heathrow recently. The gear was still down as it passed 4,000ft.
atcdan
Sat Apr 30, 2022 11:10 pm
Often times pilots will advise the tower controller if they need to keep the gear down for an extended period.
bigb
Thu May 05, 2022 12:17 am
It is for Boeing. There is a RTO setting for Boeing. I can’t comment on Airbus.
Vimanav
Tue May 10, 2022 7:45 am
I recall Thai Airways operating A300s a very long time ago into CCU (my then home airport). The aircraft used to have a 1:15 ground time. Whenever they braked hard on landing and the landing gear units heated up, a ground a/c unit with vent directed towards them was used to cool them off. Mostly worked and normal gear retraction was achieved. The only crazy guys ive seen (and regularly) were Aeroflot who used to douse the landing gear of their IL86s with buckets of water...
Oh those Russians (with due respects to Boney M).
cheers//Vimanav
Users browsing this forum: ryanna924 and 16 guests
