Boxwing
Horizontal Stabiliser Angle of the Bristol 188
Sun Apr 24, 2022 3:08 pm
Hello,
I was reading about the Concorde and somehow ended up learning about the Bristol 188. While looking at pictures, I realised that the horizontal stabiliser had quite a downward angle. It is quite visible in this pictures:
Would somebody have more information why this is? The forces (as much as drag) generated due to such a design seem counterintuitive to me. Every help is appreciated.
Best,
Boxwing
zanl188
Re: Horizontal Stabiliser Angle of the Bristol 188
Sun Apr 24, 2022 4:55 pm
I don't know much about the 188. However I will suggest to you that the horizontal stab is probably trimmable. Perhaps the angle you see in the pictures is just where the stab was the last time the aircraft was powered down.
Mon Apr 25, 2022 1:01 am
I think the OP might be referring to the significant anhedral, not the pitch angle of the stabiliser. At a guess, that would be to keep it out of the engine exhaust.
Francoflier
Mon Apr 25, 2022 2:10 am
The whole stab was moveable. You can see on the few inflight pictures available online that it didn't have this angle while flying.
This was likely its ground/parked position, or just where it eventually came to a rest when hydraulic pressure was lost.
I suspect the broad supersonic range of speed it was meant to operate at necessitated large pitch authority, especially for things such as Mach tuck and other weird stuff that happens when going that fast with 'primitive' (i.e. pre-supercomputer) aerodynamic designs.
Yikes!
Mon Apr 25, 2022 2:24 am
Starlionblue wrote:
...At a guess, that would be to keep it out of the engine exhaust.
Agree.
DH106
Mon Apr 25, 2022 6:04 am
Just for clarity - the tailplane is mounted high on top of the fin as a 'T' tail and has no (discernible) anhedral. Is it possible you're looking at the main gear struts here (like I did initially! :? )?
Buyantukhaa
Mon Apr 25, 2022 9:31 am
Indeed:
Mon Apr 25, 2022 9:58 am
Aaaah!
Yes I see it now!
Extra shame points for me since I have actually seen this exhibit in real life... :rotfl: :rotfl: :rotfl:
kalvado
Mon Apr 25, 2022 11:30 am
Isn't tail mounted stabilizer supposed to have negative AoA in level flight in all planes? It is due to stability considerations, what would happen if wing stalls at high AoA, center of gravity vs center of lift, and wing stalls first or stabilizer stalls first, etc.
Nose mounted stabilizer may be lifting one, but that opens can of worms with stability.
