x1234
What ETOPS rating does QF have for SYD-JNB/SCL, future GRU/EZE on the 789?
Wed Apr 27, 2022 6:53 pm
I remember reading that Air New Zealand had its B77E sub-fleet equipped with ETOPS 330 for AKL-EZE and LATAMs 789 also equipped with ETOPS 330 for the South America to Oceania crossing SCL-AKL/SYD/MEL. The Oceania to South Africa crossing is similar. Does QF have the ETOPS 330 type rating for crossing the Southern Indian Ocean? What ETOPS rating does SQ have on SIN-JNB? There are probably more diversion spots like the Maldives, Mauritius etc in the Indian Ocean versus the South Pacific with only Easter Island IPC and French Polynesia PPT.
Re: What ETOPS rating does QF have for SYD-JNB/SCL, future GRU/EZE on the 789?
Wed Apr 27, 2022 11:29 pm
The approval is more related to the airline, not the aircraft. Airlines are approved by regulators (CASA in terms of QF) to conduct ETOPS, not specific aircraft tails. It is that regulatory approval which limits the times and routes they can operate.
T54A
Fri Apr 29, 2022 7:20 am
Yes this is true, but different aircraft types and configurations within the same airline will have different ETDO time limits. An 'ABC Airline'' A330 might not have the same EDTO limit as say an A350 from the same airline. Each operator will apply to the regulator for each fleet (assuming all tail numbers have the same configuration) depending on EDTO required. Or no?
77west
Sun May 01, 2022 10:24 am
You are correct, but so is Zeke. It really depends on the regulator, but several regulators do indeed impose specific requirements on the airframe itself, hence why we have ETOPS and non-ETOPS frames of the same type with the same operator. (Several American operators for example will print ETOPS on the nose gear doors to help differentiate. Didn't help much a few years ago when An A321 I believe went to Hawaii and it was not ETOPS approved/equipped)
Sun May 01, 2022 12:46 pm
ETOPS/EDTO approvals are like other add on approvals to an AOC, like LVO, RNP, RVSM, EFBs etc. these really have nothing to do with individual aircraft or individual types, they are granted when the operator has demonstrated they have the necessary procedures, training, maintenance, and operational oversight in place to conduct ETOPS operations under the AOC. How an airline wants to operate different aircraft within their fleet is their prerogative, there is no requirement to have every type within the airline operated as ETDO, no requirement for every aircraft within a type to be operate EDTO. They are commercial decisions that the regulator does not control.
benjjk
Wed May 04, 2022 7:10 am
I believe QF have 330-minute ETOPS. Years back, they were limited to I think 180 so required the 747s for those routes, but those days are gone.
dfwjim1
Thu May 05, 2022 6:08 pm
Do airlines ever put a sign in the cockpit indicating whether or not an aircraft is equipped for ETOPS?
T54A
Thu May 05, 2022 8:38 pm
Not in the airline I operated. All the airframes of each same type were equally ETOPS/EDTO ‘rated’. Since we operated A340-300, A340-600, A330-200, A330-300 and A350-900 as a multi-fleet (pilots flew all types), we would just check the Computerised Flight Plan had the correct ETOPS (actually EDTO) values for that type. As an example, the A346 has slight different cargo hold fire suppression numbers to the A343. This would have minor effects on very long over water flight where fire suppression was the limiting factor. There are several different EDTO limits. The most limiting factor on each particular flight will determine the EDTO value for that flight.
Thu May 05, 2022 9:39 pm
The aircraft technical log will indicate if there is any reduction in the capability of the aircraft.
77west
Thu May 05, 2022 11:45 pm
SAA or LH by any chance?
T54A
Fri May 06, 2022 7:04 am
SAA
77west
Sat May 07, 2022 8:29 pm
T54A wrote:
SAA
Thats what I was leaning towards, not many operators with that exact fleet mix.
Sun May 08, 2022 1:42 am
The actual EDTO value itself is essentially immaterial. They will use the correct figure for the aircraft when generating the flight plan, and when we flying the sector we apply the same procedures for the EDTO entry/exit points, critical points etc as annotated on the flight plan.
Qantas744er
Tue May 17, 2022 1:58 am
Qantas B789 are approved for EDTO 330 (2169NM)
Users browsing this forum: bohica and 15 guests
