T54A wrote:You will be limited to about 257 000kg using todays METAR of 240/5, 25Deg C, QNH 30.03, Rwy 25:
RTOW: 257 000kg (MTOW 275 000kg)
RZFW: 167 000kg (MZFW 181 000kg)
FUEL: 90 000kg (SJO-MUC + 8000kg Alt Fuel)
Nicoeddf wrote:T54A wrote:You will be limited to about 257 000kg using todays METAR of 240/5, 25Deg C, QNH 30.03, Rwy 25:
Thanks much, T54A.
So with a full pax load of about 28t does that leave any room for cargo payload? Unfortunately I am unable to find good numbers for a realistic OEW.
T54A wrote:Nicoeddf wrote:T54A wrote:You will be limited to about 257 000kg using todays METAR of 240/5, 25Deg C, QNH 30.03, Rwy 25:
Thanks much, T54A.
I can’t find an actual OEW for a specific MSN airframe, but 131 000kg should be in the ballpark. So with 28 000kg pax load you should be able to take about 11 000kg belly payload.
ACMIdriver wrote:I can give you an actual airframe OEW for reference of 135,240KG if it helps.
