bluecrew wrote:In the US the 3 high-lows is for an emergency.
ikolkyo wrote:Did this occur at specific phase of flight
1337Delta764 wrote:I flew on a DL A321 and A330-300 today, and it appears like that they have a unique three-tone cabin chime that I have not heard on any other airlines' Airbus aircraft. As with the hi-lo chime, the red light illuminates over the FA panel.
Is this chime to distinguish FA to FA calls from cockpit calls? I know some airlines use a green light instead of red on their Airbus aircraft to indicate FA to FA calls, reserving red exclusively for calls from the cockpit. I wonder if DL uses a different chime instead.
Oftentimes (at least on my fleet) it is the FA fat fingering the EMER CALL button instead of CALL. The two are right next to each other and there's no guard on the EMER CALL button. Happens every couple of months, so far it's always been an accidental button push.
On the bus, if memory serves, red is from the FD and green is galley-to-galley calling. Light stays on until the call is canceled, then they can call another button or activate the PA.
Probably just an accidental call. Double ding would be for 10k going up and 10k going down.
RetiredNWA wrote:The only and correct answer is this:
Those chimes you heard indicate a specific (incoming call) to the Lead Flight Attendant/Purser.
No need for these lengthy dissertations of irrelevant nonsense that do not accurately answer your question.
Happy Flying
77west wrote:RetiredNWA wrote:The only and correct answer is this:
Happy Flying
No need for your rude response, these forums are full of lengthy dissertations that we all enjoy reading. That's the whole point.
RetiredNWA wrote:77west wrote:RetiredNWA wrote:The only and correct answer is this:
Happy Flying
My response was not “rude” - it was clear, direct, concise and cuts through the irrelevant answers and “noise” created by such erroneous information and nonsense, similar to your response.
1337Delta764 wrote:
Since you came from NWA, it was originally them who specified these chimes to indicate this, and DL continued to use it on post-merger Airbus aircraft.
You are the topic author. You posed a question you already knew the answer to? This thread is so very confusing. First, you asked a question. Then there was a lengthy dissertation about Boeing cabin call chimes and now you intimate you knew the information but still posed the question? And to be clear, I have no knowledge of what NWA and subsequently DAL ordered as call chime preferences on their fleet. My answer was intended to address your original question.
I did not “come” from NWA. I retired during the initial stages of the merger. I never wore a Delta uniform, I never “flew” for Delta. I cannot speak for anything Delta other than what the experience is as a paying passenger.
RetiredNWA wrote:bluecrew wrote:In the US the 3 high-lows is for an emergency.
Are you speaking from a regulatory perspective? There is no such or particular FAR codifying what chime signals to use for any phase of flight. This is an airline specific preference, your generalization is incorrect.
bluecrew wrote:RetiredNWA wrote:bluecrew wrote:In the US the 3 high-lows is for an emergency.
Generally accepted procedure. 3 high lows is an emergency.
I'm sure you'll come up with something that breaks this rule, or maybe you'll tell me how the interphone on the DC-8 works.
No need to be rude.
1337Delta764 wrote:Airbus tends to offer more customization on the chimes and lights than Boeing. Boeing has historically been consistent across aircraft, although on the 787 Boeing expanded the number of chime and light combos.
AC320tech wrote:1337Delta764 wrote:Airbus tends to offer more customization on the chimes and lights than Boeing. Boeing has historically been consistent across aircraft, although on the 787 Boeing expanded the number of chime and light combos.
I can tell you that is not the case. Airbus is very much consistent, here is the aircraft, take it or leave it. Boeing are the ones who produce the most customizable aircraft to the customers tastes. Of course both companies will offer packages and options, like drop down LCD IFE versus CRT screens in the ceiling on late model 320s, chiller galleys etc... But Boeing remains the most customizable aircraft all around, case in point, look at all the different flavours of 767s AC had over the years including the four door 763.
It is unfair to assume that airlines post merger carry over procedures from the merged airline. Certainly during the AC/CP merger, some CP procedures and policies just went away. Forever.
1337Delta764 wrote:AC320tech wrote:1337Delta764 wrote:Airbus tends to offer more customization on the chimes and lights than Boeing. Boeing has historically been consistent across aircraft, although on the 787 Boeing expanded the number of chime and light combos.
I can understand this in some aspects. For example, the 739ERs have an illuminated "Wi-Fi" sign indicating when Wi-Fi is available, the A321s do not.
I’ve always wondered why other airlines don’t adopt this. Although I imagine with gate to gate always on Wi-Fi, there’s less of a need for a light indicating when Wi-Fi is active.
