Starlionblue wrote:You're comparing with Dublin. But....the average temperature in Lucknow is a tad higher than in Dublin, by about 15 degrees. This has quite an impact on performance.
FligtReporter wrote:I guess may be it is a determining factor on what aircraft type could or couldnt be used.
gloom wrote:FligtReporter wrote:I guess may be it is a determining factor on what aircraft type could or couldnt be used.
It probably is.
For a quick overview on how the temperature restricts performance, check ACAPS document:
https://www.boeing.com/resources/boeing ... 2lr3er.pdf
What you're looking for, is the difference for a given conditions for ISA, and ISA+15. Say, pages 52 and 53.
These are not the Lucknow data, just a reference to show a difference between standard and increased temperature (15 degrees Celcius difference).
ISA is standardized atmosphere conditions (29.92 in Hg, 1013.25 hPa; +14deg C, 57deg F at sea level).
If you want to calculate Lucknow required distance, you need to adjust for pressure, and temperature. There are more factors to put in for accurate calculations, but for a "more or less accurate" you should be fine with airport data and ACAPS.
Adam
N1120A wrote:At the temperatures you are getting this week, the 77W could take off with somewhere around 670000 pounds. That's probably doable on such a relatively short flight to JED, but why would Saudia do that? Lucknow is likely a rather low yielding destination, perfect for the regional configuration their A330s have. They don't need the 77W's added range, so they're better off using that those where it makes more sense to use the extra capacity (on the regional configured ones) and/or range. I'd imagine the need to carry cargo also figures into where they send the 77W, which essentially functions as a combi aircraft, given how much cargo it holds.
I'd bet you see a 787-10 before a 77W.
FligtReporter wrote:N1120A wrote:At the temperatures you are getting this week, the 77W could take off with somewhere around 670000 pounds. That's probably doable on such a relatively short flight to JED, but why would Saudia do that? Lucknow is likely a rather low yielding destination, perfect for the regional configuration their A330s have. They don't need the 77W's added range, so they're better off using that those where it makes more sense to use the extra capacity (on the regional configured ones) and/or range. I'd imagine the need to carry cargo also figures into where they send the 77W, which essentially functions as a combi aircraft, given how much cargo it holds.
I hope we do some other Widebody than the normal 333s..I guess a 789 would be good too though would our Runway be enough for a fully loaded 787-9 or 787-10 if not the ultra long 777ER ?
gloom wrote:FligtReporter wrote:ISA is standardized atmosphere conditions (29.92 in Hg, 1013.25 hPa; +14deg C, 57deg F at sea level).
Yikes! wrote:I can see no reason for a 777 not to fly into VILK/LKO unless PCN (Pavement Classification Number) is an issue. ( https://en.wikipedia.org/wiki/ACN-PCN_method )
N1120A wrote:FligtReporter wrote:N1120A wrote:At the temperatures you are getting this week, the 77W could take off with somewhere around 670000 pounds. That's probably doable on such a relatively short flight to JED, but why would Saudia do that? Lucknow is likely a rather low yielding destination, perfect for the regional configuration their A330s have. They don't need the 77W's added range, so they're better off using that those where it makes more sense to use the extra capacity (on the regional configured ones) and/or range. I'd imagine the need to carry cargo also figures into where they send the 77W, which essentially functions as a combi aircraft, given how much cargo it holds.
Again, I don't think the 77W would necessarily have an issue departing, given the short flight distance. I think the primary issue would just be having 100 more seats in the regional configuration and being way too premium on the long haul configuration.
The 789 probably isn't dense enough, but would have absolutely no performance issues.
Yikes! wrote:gloom wrote:FligtReporter wrote:ISA is standardized atmosphere conditions (29.92 in Hg, 1013.25 hPa; +14deg C, 57deg F at sea level).
Hi FlightReporter: I think you meant to say +15C/59F: ( https://www.universalweather.com/blog/i ... he-basics/ )
Lucknow can be found on SkyVector https://skyvector.com/airport/VILK/Chau ... gh-Airport
I can see no reason for a 777 not to fly into VILK/LKO unless PCN (Pavement Classification Number) is an issue. ( https://en.wikipedia.org/wiki/ACN-PCN_method ) LKO is only ~400' ASL. Temperarture would certainly be a factor as FlightReporter suggested. But many operators will operate in the wee hours of the morning when temperatures are at their coolest. One other constraint might be terrain but Google Earth Pro seems to indicate LKO is outside mountainous areas in the "near in obstacle" criteria.
Notwithstanding all of the above, the DGCA (Indian Aviation Authority) works in mysterious ways!
Yikes! wrote:I think you meant to say +15C/59F
AirKevin wrote:Yikes! wrote:I can see no reason for a 777 not to fly into VILK/LKO unless PCN (Pavement Classification Number) is an issue. ( https://en.wikipedia.org/wiki/ACN-PCN_method )
I was about to mention that, but he did say one did a fly-by, so I don't know that they would have attempted an approach if that was an issue.
