andrej
A330 - After Landing Procedure
Mon Jun 13, 2022 8:14 am
Hello (especially our resident A330 pilots),
found this nice YT video of Lion Air's A339 landing in Medina. During after-landing procedures and a subsequent checklist crew keeps Flaps at "1" level. They are not retracted at the gate either. I understand that in some instances, one may not fully retract flaps (icing condition). However, is there any specific reason (obvious) or is this rather (possibly) company specific?
https://youtu.be/4Jr8Y-YW68I?t=747
Re: A330 - After Landing Procedure
Mon Jun 13, 2022 8:55 am
They're kept at one if the temperature is aoove 30 degrees. In hot weather, you can get an air leak ECAM warning from overheating detected in the wing bleed air ducts if you retract the slats fully.
andrej
Mon Jun 13, 2022 10:55 am
Thank you! Makes sense. :)
Woodreau
Mon Jun 13, 2022 1:50 pm
Or if your airline paid extra for the modification the bleed leak computer tolerance is increased to +40c before the spurious air bleed leak ECAM.
Mon Jun 13, 2022 11:41 pm
Going back to the "icing conditions" you mentioned. If you suspect contamination is possible, e.g. after landing on a snowy runway, you would not retract the slats/flaps at all until you're at the gate and they can be inspected for contamination. You can then retract them with pressure provided by the electric pumps.
Lukas757
Mon Jun 13, 2022 11:59 pm
One would think that this modification is standard on the A339 in the Video. However, it makes sense to keep the SOP the same within the CEO and NEO.
Users browsing this forum: Google [Bot] and 22 guests
