phxtravelboy
Taking off without slats/flaps set; possible?
Wed Jul 20, 2022 2:04 am
I travel frequently and always take a window seat. Not only to enjoy the view while flying, but also to ensure that the flaps/slats are set for takeoff. There were a few accidents in the 80s/90s where the crew were distracted and didn't set them properly and ended up crashing during take off. Those accidents are always in the back of my mind when I fly. My question is this. With all of the technology available today, is it even possible for this to happen today on a modern airliner? What I mean is, are the cockpit crew even "allowed" to apply take off power to the engines if the slats/flaps aren't set for takeoff? To me, it would make sense to have the planes programmed to NOT allow takeoff power to be applied, unless it has been specifically overwritten, say for an engine test or something similar. So if an engine needed to be tested, the cockpit crew would select a certain setting, and THEN could apply takeoff power to test the engine without the flaps/slats being properly deployed. If today's modern airliners are not programmed like this, I think they should be as to me, it seems like a very simple, life saving thing. So, does anyone have an answer to this? Thanks.
leleko747
Re: Taking off without slats/flaps set; possible?
Wed Jul 20, 2022 2:14 am
If I remember well, the Fokker 100 (maybe the F70 aswell) can takeoff normally without any usage of flaps/slats, depending on the conditions.
Not so sure about other aircraft... specially MD-80 series! Northwest and Spanair crashes come to mind
dcajet
Wed Jul 20, 2022 2:17 am
Some aircraft can routinely take off without flaps by design under certain parameters; F28s and F100s come to mind.
AirKevin
Wed Jul 20, 2022 2:27 am
You can certainly apply take-off power without having the flaps or slats set. You would also get the take-off configuration warning in the process.
ILUV767
Wed Jul 20, 2022 2:33 am
All transport category aircraft have some form of a take off configuration check/take off configuration warning to alert the crew should the airplane not be properly configured for take off.
Many airlines are making the setting of flaps a requirement prior to beginning the taxi.
orlandocfi
Most modern commercial aircraft have a takeoff configuration warning, but that does not ensure that the flaps are in the correct setting, only that the flaps are within the takeoff setting range. Flap settings are typically reviewed on at least two checklists prior to takeoff, but this varies by airline.
AngelsDecay
Wed Jul 20, 2022 2:39 am
Boeing 767-200 and even Airbus A300-600R are made to take off with only LE devices and no TE at all, depending on present weight and meteo.
Here at my airport, Faro, south of Portugal, along the years as well the F100 &70, i've seen lots of 762's (Britannia, Excel) and AB6's(Lufti) doing T/O with only leading edge devices(slats), and no trailing edge (flaps) at all.
IIRC also the oldies DC9s were capable to do the same.
https://www.airliners.net/photo/US-Airw ... /1000447/L
FlyingMSY
Wed Jul 20, 2022 2:44 am
Commenting on AngelsDecay, the original DC-9, the -10 series, did not have leading edge slats. They were added from the -30 series onward to improve performance (ex. the -20 is a -10 fuselage with -30 wings).
a340crew
Wed Jul 20, 2022 2:59 am
Not true, I can tell you from personal experience the 737 and 767 (flown both) do not have any warning system. We do have a before take off checklist which does have both pilots verify the flap/slat setting for take off.
Slats can be MEL'd but you take a huge take off penalty.
GalaxyFlyer
Wed Jul 20, 2022 3:13 am
Interesting, the EA B727 had take-off configuration warning system.
AirKevin
Wed Jul 20, 2022 3:22 am
Which 737 was this. Only asking because as far as I know, it has a take-off configuration warning. In fact, this caused some befuddlement with the crew of Helios 522 because they couldn't figure out why they had a take-off configuration warning in flight. Unbeknownst to them, it was actually the cabin altitude warning, but use the same warning sound as the take-off configuration warning.
Wed Jul 20, 2022 3:29 am
On the 'bus, once everything is set for takeoff you need to press the "TO CONFIG" button. This will run a systems check. At this point, ECAM MEMO items will show "no blue", meaning all good.
Also, if you try to set takeoff thrust with the wrong configuration, e.g. the parking brake set or flaps at zero, you'll get the config warning.
Northwest Airlines 255 famously crashed due to not having set high lift devices for takeoff. If memory serves, and please correct me if I am wrong, the configuration warning would sound at rather a low thrust setting, so you'd get "nuisance warnings" during taxi since the high lift devices were not extended yet, as was the procedure at the time.
The "procedure", definitely not approved but constatnly used, was to reach back and pull the appropriate circuit breaker by feel, deactivating the warning. When one of the crash investigators looked at another tail in the fleet, he saw that the breaker was all greasy and shiny due to being constantly pulled and reseated.
In the case of flight 255, the crew was distracted by a long taxi and some delays. So they both forgot to reseat the breaker and to set the high lift devices correctly.
After the crash, checklists through the industry were overhauled, making them clearer and with "section breaks" so that you would not have long sequences where you could easily lose your place.
The MD-80 configuration warning was also reworked to avoid the nuisance warnings.
DualQual
Wed Jul 20, 2022 5:08 am
The 737s and 767s I’ve flown do.
Wed Jul 20, 2022 5:53 am
Do I remember an accident in Spain on a MD80 series with no devices deployed, not sure if they had a config warning.
Wed Jul 20, 2022 7:01 am
The Spanair 5022 crash. Seems the takeoff warning system did not work properly.
https://en.wikipedia.org/wiki/Spanair_Flight_5022
Wed Jul 20, 2022 8:39 am
Thanks the hamsters in the wheel are in COS18, don’t remember as much ;)
phxtravelboy
Wed Jul 20, 2022 10:13 pm
Thank you all for your posts. So it sounds like there is at least a warning that would alert the crew if the plane wasn't configured properly. THAT was my main question as to me it makes sense they'd be alerted.
As another poster stated, yes, I've noticed that most airlines deploy the flaps/slats before even beginning to taxi.
RetiredWeasel
Wed Jul 20, 2022 10:45 pm
Here's a quote from the NTSB on the NW Detroit DC-9 crash that killed 156 people:
"The National Transportation Safety Board determines that the probable cause of the accident was the flightcrew’s failure to use the taxi checklist to ensure that the flaps and slats were extended for takeoff. Contributing to the accident was the absence of electrical power to the airplane takeoff warning system which thus did not warn the flightcrew that the airplane was not configured properly for takeoff. The reason for the absence of electrical power could not be determined."
BoeingGuy
Thu Jul 21, 2022 5:43 am
That’s not correct. The 767 most certainly does have a takeoff configuration warning system in EICAS. The 737 has a takeoff configuration horn.
BoeingGuy
Thu Jul 21, 2022 5:51 am
On Boeing non-737 models, the Autothrottle will not engage for takeoff if the Flaps are not in a valid takeoff setting. On the 777-9, the Autothrottle won’t engage in TO/GA for any takeoff configuration issue.
Boeing looked at preventing takeoff power or automatically retarding thrust levers or thrust on the 777-9 if you set takeoff thrust and the Folding Wingtips are not down and locked. This was not feasible. The failure modes are too hazardous. It wouldn’t be certifiable. For example, what if the system malfunctioned right at rotation and automatically cut thrust to idle. That would be catastrophic.
It’s not currently feasible from a failure hazard standpoint to implement a system that prevents setting takeoff power or automatically retards it for an out of configuration issue.
Max Q
Thu Jul 21, 2022 6:52 am
I don’t believe the F100 has slats even installed, like the F28
Thu Jul 21, 2022 6:55 am
Makes sense. I'd much rather have the thrust on than "maybe off" in that situation. Once you're past 100 knots you really want to "go" in almost all cases. Even if the parking brake is on.
bhill
Thu Jul 21, 2022 10:45 pm
Ick..Horizon used to have these...like riding on a piece of plywood over the Rockies...
BoeingGuy
Sat Jul 23, 2022 12:37 am
As others noted, the 767-200 and 757-200 are certified for FLAPS 1 takeoff, which is slats only with no flaps. The 767-300, 767-400, and KC-46 are not certified for FLAPS 1 takeoff, however.
DualQual
Sat Jul 23, 2022 4:52 am
Flaps 1 is slats only on the 767. The 757 is slats and 1 degree of trailing edge flaps.
seven47
Sat Jul 23, 2022 11:31 am
I'm a 757/-200 and 767-300ER Captain, Instructor, Check Airman, Aircrew Program Designee (TRI/TRE). I can say without a doubt that the 767-300ER has a Takeoff Configuration Warning System. It monitors the status of the high lift devices, horizontal stabilizer trim, and parking brake. Although I coild be wrong, I'd be surprised if any Ttansport Category aircraft does not have a TOCWS.
GalaxyFlyer
Sat Jul 23, 2022 12:37 pm
I can’t think of a modern Part 25 bizjet that doesn’t have a TO CONFIG warning system.
Velocirapture
Sun Jul 24, 2022 4:47 pm
IIRC, the Take Off Configuration Warning System at my carrier was added by the airline after operating the type for several years. Also IIRC, the first batch of 737NGs were also delivered without such a system, but later deliveries came from Boeing equipped that way.
exFWAOONW
Thu Aug 04, 2022 2:00 pm
It probably wasn't SOP or done very often, but I talked with several pilots back in the day who said when lightly loaded, they could adjust the stab setting on the T/O roll until the nose started to rise in the baby (-10) 9s.
Fri Aug 05, 2022 2:36 am
Ah yes. The wild west days of aviation. :rotfl: :shock: :o
GalaxyFlyer
Fri Aug 05, 2022 3:15 am
Indeed, the early jet days were filled with horror stories.
Aircellist
Fri Aug 05, 2022 4:00 pm
I remember being very surprised to take-off in a KL A310 AMS-CDG without flaps extended, twice… Didn't seem to mean much to the airplane, though.
Second time I kinda remembered the first time (not the same year).
Can't tell about LE devices, I was seated after the wing.
DualQual
Fri Aug 05, 2022 5:15 pm
Are you talking about a switch that on the panel that is installed that would theoretically make the warning sound, say, at the gate when the airplane is parked with flaps/slats up and the parking brake on and shouldn’t sound at all if pressed just before takeoff with brakes released and flaps/slats in a takeoff position? Only a few carriers have that option installed but I can assure you that the underlying system is still there from day 1 when the airplane is delivered and functions. The switch is just one more safety net to test the system works by simulating that the airplane is at takeoff. If not in a safe config the system alerts. If in a safe config the system doesn’t.
BoeingGuy
Wed Aug 10, 2022 7:02 am
Continental took that switch option that you refer too. All Boeing models have a Takeoff Configuration Warning System. It wasn’t added after the first batch of 737NGs.
Semaex
Wed Aug 10, 2022 8:31 am
On the Cessna Citation you are in fact NOT ALLOWED to take off with flaps if you have de/anti-icing fluid on the wings.
Pretty sure other small jets have the same restrictions.
GalaxyFlyer
Wed Aug 10, 2022 12:20 pm
I have 2500 hours in Citations, never heard of that one. There’s not even no flap data.
DualQual
Wed Aug 10, 2022 3:31 pm
That’s what I was driving at. Perhaps Velocirapture is confusing the switch option with the actual TCWS and we have a simple misunderstanding.
bigb
Fri Aug 12, 2022 1:55 pm
CRJ-100s and 200s do not have LE Devices or slats…
atav
Sat Aug 13, 2022 2:40 am
Based on that statement I refuse to believe you fly / flew those aircraft. 767s certainly do and always have had takeoff configuration warning systems.
Semaex
Sat Aug 13, 2022 4:24 pm
If I knew a way to send you a PDF here...
Just read again the Flightsafety Intl Pilot Training Manual for the CJ2 (which with regards to flight controls is the same for the +/3/4), and I quote...
"takeoff is limited to flaps up (0) position when Type II, Type III or Type IV anti-ice fluid is on the airplane".
I know it says the exact same in the POH, but I'm unable to find it being only on my phone right now.
GalaxyFlyer
Sat Aug 13, 2022 6:17 pm
Oops, CJ models, my time was in the originals, sorry.
qcpilotxf
Mon Aug 15, 2022 6:51 pm
The 500 series its basically the same thing. We can take off flaps zero in normal conditions but you will really never see it
Semaex
Sat Aug 20, 2022 9:44 am
True, you can also just generally use Flaps 0 for takeoff on the C525, but as practically all departures are noise-abatement, you never use it. Unless as said with Icing Fluid on the wings, in which case safety trumps noise.
IFlyVeryLittle
Thu Aug 25, 2022 12:43 pm
As a non-pilot, why is this?
CALTECH
Thu Aug 25, 2022 2:43 pm
https://www.faa.gov/documentLibrary/med ... _703-1.pdf
Subject: TAKEOFF CONFIGURATION WARNING SYSTEMS
Date: 3/17 /93
AC No: 25. 703-1
5. DISCUSSION.
a. Regulatory Basis.
(1) Section 25.703 of the FAR, "Takeoff warning system," makes it
mandatory for a takeoff configuration warning system to be installed in
transport airplanes.
Slats CAN NOT be MEL'd, but their indication can. Don't know how up to date this MEL is, but sounds right....They have to work. Only penalty is a speed restriction....
"(M)(O) Indication lights on forward panel, and in addition, indication lights for one leading edge slat, except for slats 3, 4, 5 and 6, on overhead annunciator panel may be inoperative provided:
a) Normal operation is verified by flight crew before each takeoff and landing,
b) Maximum speed is limited to 300 KIAS at/below FL 200 or .65 Mach above FL 200,
c) All remaining indications on overhead annunciator panel operate normally, and
d) Stall warning operation of both systems is verified to operate normally."
CALTECH
Thu Aug 25, 2022 3:05 pm
Yup.
U.S. DEPARTMENT OF TRANSPORTATION
MASTER MINIMUM EQUIPMENT LIST
FEDERAL AVIATION ADMINISTRATION
AIRCRAFT: B-767
REVISION NO: 36
DATE: 08/08/2013
PAGE: 31-3
SYSTEM &
SEQUENCE
NUMBERS
ITEM
31 INDICATING/RECORDING SYSTEMS
Takeoff Configuration Check (T/O CHK) Switch
May be inoperative provided procedures do not require its use.
Fri Aug 26, 2022 1:39 am
More flap gives you a shorter takeoff run and a higher initial climb gradient. If you use no flap you might not make the required climb gradient for noise abatement.
Conversely, less flap gives you a lower initial climb gradient, but a higher second segment climb gradient. This can be useful if there are obstacles in the departure path.
qcpilotxf
Fri Aug 26, 2022 2:04 am
Or in the case listed above about the Citation... getting us fast enough to actually get the anti-ice fluid off the wings on the takeoff roll
JBoy
Fri Aug 26, 2022 6:31 pm
Horizon had the F28, not the F100 or F70. No leading edge slats on the F28. I loved that airplane, fun to fly!
atav
Tue Aug 30, 2022 3:46 pm
Yup.
AIRCRAFT: B-767
REVISION NO: 36
DATE: 08/08/2013
PAGE: 31-3
SYSTEM &
SEQUENCE
NUMBERS
ITEM
This isn’t a good example. This is for the takeoff configuration check SWITCH. This is irrelevant to the conversation as we were discussing takeoff config systems being mandatory, not takeoff config tests. Do you know what an MEL is? It tells what components can be temporarily inoperative. This is why the system isn’t on any MEL. I’m still convinced you’re posing as a pilot, as all pilots are trained on how an MEL works.
Users browsing this forum: No registered users and 26 guests
