Avatar2go
Question on aircraft tires
Wed Aug 03, 2022 1:48 am
Was wondering if spinning up the wheels on an airliner at landing, to match the ground speed on touchdown, would result in longer tire life? Seems like the tires take a beating on landing, as they smoke considerably while they spin up to match ground speed, while the aircraft weight is settling on them.
Not sure if that is a significant factor on tire wear, but if so it wouldn't be that difficult to have a mechanism to spin them to the correct speed. I'm sure others have thought of this before, so just curious if it's been tried, or dismissed for some reason.
Re: Question on aircraft tires
Wed Aug 03, 2022 1:52 am
This is asked with some regularity on this forum.
Simple answer: If it saved money, it would be done. Currently, the cost motor solution seems to be more than the cost of extra tyre wear.
You'd also introduce additional threats to the operation. What if the mains on one side spin up and the other ones don't? Would this introduce a lot of yaw? Would there have to be a quick disconnect? All solvable, of course, but solving such problems costs money.
This doesn't mean it won't ever be done. The cost equation is not static over time. Electric motors are becoming ever smaller, lighter, and more powerful.
Avatar2go
Wed Aug 03, 2022 2:58 am
Ok, thanks for the information. I thought someone here might know the answer. I hadn't thought about the asymmetric spin possibility, seems like that would be a significant concern.
LH707330
Wed Aug 03, 2022 3:36 am
What about landing on a conveyor belt? :P
DH106
Wed Aug 03, 2022 5:44 am
Rather than electrically powered motors, perhaps small vanes on the wheel hubs could use the slipstream to spin the wheels up?
Avatar2go
Wed Aug 03, 2022 6:49 am
Interesting idea, as then the brakes could be used to regulate rotational speed to match ground speed.
ReverseFlow
Wed Aug 03, 2022 8:00 am
IIRC there is a patent to add little scoops on the tires to spin them up from the airflow.
The issue is you would also spin them when you take-off, too.
You'd therefore have to brake them more on retraction and I guess brake wear is more costly than tire wear.
You'd also be adding weight to the gears with motors etc.
Wed Aug 03, 2022 1:58 pm
Brakes are applied prior to retraction anyway so it would not change wear at all. Carbon brakes wear per application, not depending on application force.
I'm really not sure about the asymmetric yaw. We can land with a locked brake and I guess even large wheels aren't much compared to the weight of the airliner itself. Still, it is a failure mode that must be considered.
LH707330
Wed Aug 03, 2022 2:25 pm
Regarding the brake wear, even steel brakes wouldn't have that much incremental wear from the marginal effort of slowing down the rotation.
There are a couple other questions that come to mind with the weathervane tires:
1. I think some types allow a certain number of inop brakes depending on the runway lengths, etc. After takeoff, they wait a few minutes to spin down, and then retract. Weathervanes would take that option away because the wheels would keep spinning. Is that an acceptable penalty?
2. How much of a drag penalty do you pay for the weathervanes? If F=ma, m=~150 kg per wheel (guess), and you need to spin up 10 wheels to 130 kts, how much energy do you need to take from the plane in the form of drag to achieve that? How much of a penalty do you pay on takeoff with OEI?
3. What's the cost of molding those weathervanes into the tires vs retreading?
4. What happens if I get a birdstrike on the tire that knocks half of the weathervanes off?
Francoflier
Wed Aug 03, 2022 2:27 pm
Landing spin-ups are only a fraction of what wears the tires out. A lot of that wear happens during braking, taxying (especially when heavy and in tight turns), heat cycling, rough taxiway/runway surfaces, etc.
Fancy solutions to spin the tires before landing would add weight, complexity and/or drag (which all translate to cost) to solve only a part of the problem.
ReverseFlow
Wed Aug 03, 2022 3:14 pm
Good point.
https://www.boeing.com/commercial/aerom ... _05_1.html
However for brake to vacate it is said that it saves brake wear.
https://www.flightglobal.com/easa-clear ... 32.article
Another thought - scoops would also be extra drag at times you don't want it
Edit: Here's thd patent (German)
https://www.freepatentsonline.com/DE202009001104U1.html
Thrusty69
Thu Aug 04, 2022 6:53 am
I personally haven’t changed many tires for flat spotting in my careeer- If any. I don’t think landings impact tire wear that much. You generally get your money’s worth out of the tire. Makes me think any kind of wheel spin up device is largely irrelevant.
kalvado
Thu Aug 04, 2022 10:15 am
Black rubber marks at touchdown beg to differ.
A good number for discussion would be the cost of tyres in operations. How many cycles do tyres last, and what is the cost per tyre (including labor costs for service)?
If I remember correctly, 1 lb of weight costs something like $0.25 in fuel per cycle on medium haul. Weight of spinup device would be a few lb, and that would add up.
From a few calculations like that I did over time, my main impression is that airborne weight is expensive. If you can cut down on weight, it often makes sense to do so, even if that costs in a long run. Only essential thing should be up there.
ReverseFlow
Thu Aug 04, 2022 11:08 am
Speaking of weight you don't need.
Someone once joked to me that the 3 things airlines don't like are:
- Landing gears
- Windows
- Pilots
There are concepts around where the aircraft sits on a 'chariot' on ground and then somehow lands on one at its destination negating the need for landing gears.
Obviously many issues with that.
The U2 has got its wing wheels that fall off on take-off or the Me 163 Komet during WW2 which had a dolly that it took off from. But doing something like this on an airliner would be another scale!
aeropix
Fri Aug 05, 2022 3:34 pm
Bad Idea for Stopping Distance - One big safety point everyone is missing, is that the drag from the touchdown helps to shorten the stopping distance. Therefore the expensive motor / scoop "solution" to the cost of tire wear will all be made up for when even one hull is lost to overruns not to mention less utility from aircraft that can no longer use shorter runways at high gross weights. Then in the "scoops" case there's less braking effectiveness in the RTO (Rejected Takeoff) case, thereby further reducing the weight carrying capacity of any aircraft with such a system installed. Why would anybody spend money on such a risk-prone "solution" to a problem that doesn't really exist? Tires will wear out from heat and exposure to extreme temperature and pressure variations of the flight cycle anyway. The additional wear and tear from skidding touchdowns is negligible in the grander scheme of things.
kalvado
Fri Aug 05, 2022 3:52 pm
I heavily doubt that touchdown tire wear and spinup would be a big contribution towards braking. There is a reason ABS was developed to allow braking without tire slipping - first introduced on airliners, as far as I remember. Tires spinup would also be a relatively small contribution, probably a fraction of a knot, if not a fraction of 0.1 knot.
Users browsing this forum: 738Pilot and 39 guests
