HowardDGA
APU Thrust?
Wed Aug 10, 2022 5:59 pm
I could not find a topic about this, please redirect me if it has already been discussed.
Can APUs produce any meaningful thrust? And would it have any effect on an aircraft’s ETOPS certification?
nws2002
Re: APU Thrust?
Wed Aug 10, 2022 6:05 pm
The only ETOPS effect I can think of is as another power source. No meaningful thrust to keep an aircraft aloft.
StereoTechque
Re: APU Thrust?
Wed Aug 10, 2022 6:34 pm
Any little bit of thrust APU will produce is practically meaningless.
kalvado
Re: APU Thrust?
Wed Aug 10, 2022 6:40 pm
pretty long discussion: viewtopic.php?t=776251
Like always, there are some odd examples
Re: APU Thrust?
Thu Aug 11, 2022 7:54 am
Short answer is the APU will not produce propulsive thrust to move the aircraft forward, however the APU bleed can be used to drive the packs, this can provide more available thrust from the engines.
HowardDGA
Re: APU Thrust?
Thu Aug 11, 2022 8:02 am
Thank you, that is an interesting thread.
Natflyer
Re: APU Thrust?
Thu Aug 11, 2022 10:52 pm
I heard that question asked by a colleague years ago in ground school.
About 3 knots. Per year. Was the instructors reply.
Re: APU Thrust?
Fri Aug 12, 2022 5:19 am
Does the Trident Three's fourth engine count? 8-)
Also... Insert joke about the BAe-146/Avro RJ, whose engines are derived from an APU.
Re: APU Thrust?
Fri Aug 12, 2022 10:22 am
That was a takeoff engine, the RB162, gave about 5000 lb of thrust for takeoff and shutdown after 5 minutes.
The APU on that aircraft is located above the “trident” above the engine 2 intake
hitower3
Re: APU Thrust?
Fri Aug 12, 2022 12:03 pm
I vaguely remember having seen a concept of an enlarged APU being able to provide a limited amount of additional thrust for a twin engine jet.
The idea was to slightly bump the MTOW under consideration of a failure of one main engine.
Hendric
Re: APU Thrust?
Fri Aug 12, 2022 12:14 pm
I know. I know.
But one should never forgo the opportunity to mention British aircraft design weirdness, no matter how tenuous the connection. :biggrin:
26point2
Re: APU Thrust?
Fri Aug 12, 2022 12:50 pm
The GLEX actually has a performance penalty with APU running due the the retractable APU inlet door which creates some drag.
Classa64
Re: APU Thrust?
Sat Aug 13, 2022 8:29 pm
The first time in months I visit the Tech/Ops section and the same question I asked 6 years ago is in the top 5.
Funny
Natflyer
Re: APU Thrust?
Sun Aug 14, 2022 2:38 pm
I know. I know.
Very true!
