Thrusty69 wrote:Do you not tow or “pushback” regardless? Or do you move the bridge out of the way and make hard turn and taxi out? (Rare in the USA)
Starlionblue wrote:Thrusty69 wrote:Do you not tow or “pushback” regardless? Or do you move the bridge out of the way and make hard turn and taxi out? (Rare in the USA)
You have to move the bridge off the aircraft first. No way you'd push back with it still in place. Too much risk of damage.
FGITD wrote:Starlionblue wrote:Thrusty69 wrote:Do you not tow or “pushback” regardless? Or do you move the bridge out of the way and make hard turn and taxi out? (Rare in the USA)
If you can pull the canopy back, it’s possible though be it not a great option. I’ve done it a few times. As soon as you start the push you angle towards (pushing nose away) from the jetbridge, and then once you’re clear just ease it back into a straight push.
One of those things the jetbridge maintenance and port authority folks would tell us is possible, but they aren’t liable.
So what would their approved method be.
Hosdog wrote:We work hard to repair the bridges but sometimes towing back is the only option. Airlines won't push back without the bridge off.
I'm really curious if anyone has come up with a quick method ( preferably manual ) to move a bridge ?
Their solution is to wait until the bridge is fixed and can be moved away on its own power. Which is fine, except when you’ve got a schedule to keep
AirKevin wrote:FGITD wrote:AirKevin wrote:So what would their approved method be.
And how long can that take.
Vendor is going to ship those parts in 3 weeks, if everything works as planned.
AirKevin wrote:kalvado wrote:AirKevin wrote:And how long can that take.
Oh, dear. That sounds like quite the kerfuffle. I don't know that the airlines would like having a plane stuck there for that long, and depending on the airport, I'm guessing the airport authorities won't like that, either.
strfyr51 wrote:Starlionblue wrote:Thrusty69 wrote:Do you not tow or “pushback” regardless? Or do you move the bridge out of the way and make hard turn and taxi out? (Rare in the USA)
you can move the airplane with the jetway disabled as long as you can safely close the main cabin door. you woud then have to turn the nose wheels in the direction of the jetway and push in the opposite direction making sure you straighten the nose wheel when you're 2-3 ft away from the jetway so as not to damage any airplane on an adjacent gate. I've done it an supervised it at least 3 times in my 33 years at United,
How do you turn the nose wheel with the plane at the gate. I guess with the tiller?
Starlionblue wrote:AirKevin wrote:strfyr51 wrote:you can move the airplane with the jetway disabled as long as you can safely close the main cabin door. you woud then have to turn the nose wheels in the direction of the jetway and push in the opposite direction making sure you straighten the nose wheel when you're 2-3 ft away from the jetway so as not to damage any airplane on an adjacent gate. I've done it an supervised it at least 3 times in my 33 years at United,
You could. Or the pedals. But as FGITD says it would have to be done by the tug. The steering lockout pin would be inserted so that the steering is disabled, just like with any pushback.
I see a problem though. The nose gear would be in the neutral position when connecting the tug. The tug needs to move before the nosewheel can be turned. By then, you've already scraped the fuselage alone the jetbridge.
AirKevin wrote:Starlionblue wrote:AirKevin wrote:How do you turn the nose wheel with the plane at the gate. I guess with the tiller?
Yeah, hence my befuddlement. I wasn't seeing how the tug would be able to turn the nose wheel in that position.
You angle the pushback. The towbar of course has to be attached straight to the aircraft, but you can angle the pushback when you attach it to the towbar. That way, at the first push you already have the nose gear and towbar turning in the direction you need. It’s definitely a slower, more delicate process but a halfway decent tug driver with some guidance can do it relatively easily.
phatfarmlines wrote:An interesting topic. One thing is for sure - here in the U.S., airlines will be insistent on using a jetway even if it is not functioning properly. Power to the jetway lost as the plane pulls into the gate for arrival? Passengers remain on the plane as the jetway is fixed instead of bringing out airstairs to connect to the rear of the plane.
