Hosdog
Airbridge / Jet bridge failure
Mon Aug 15, 2022 11:36 am
Hi,
Anyone on here have experience in towing off Airbridges ? Where I work if a bridge completely fails ( whilst docked ) we have to tow it off using a winch and vehicles as anchor points. I'm intrigued as to what methods / equipment are used at other airports across the world ?
Thrusty69
Re: Airbridge / Jet bridge failure
Tue Aug 16, 2022 1:11 am
Do you not tow or “pushback” regardless? Or do you move the bridge out of the way and make hard turn and taxi out? (Rare in the USA)
Hosdog
Tue Aug 16, 2022 9:26 am
Hi , sorry maybe our terminolgy is slightly different. The aircraft are always pushed back. I am asking about towing or dragging a failed bridge off of the plane.
Tue Aug 16, 2022 11:21 am
You have to move the bridge off the aircraft first. No way you'd push back with it still in place. Too much risk of damage.
FGITD
Tue Aug 16, 2022 3:10 pm
If you can pull the canopy back, it’s possible though be it not a great option. I’ve done it a few times. As soon as you start the push you angle towards (pushing nose away) from the jetbridge, and then once you’re clear just ease it back into a straight push.
One of those things the jetbridge maintenance and port authority folks would tell us is possible, but they aren’t liable.
AirKevin
Wed Aug 17, 2022 1:41 am
So what would their approved method be.
FGITD
Wed Aug 17, 2022 1:57 am
Their solution is to wait until the bridge is fixed and can be moved away on its own power. Which is fine, except when you’ve got a schedule to keep
Hosdog
Wed Aug 17, 2022 2:10 pm
We work hard to repair the bridges but sometimes towing back is the only option. Airlines won't push back without the bridge off.
I'm really curious if anyone has come up with a quick method ( preferably manual ) to move a bridge ?
Okcflyer
Wed Aug 17, 2022 7:35 pm
Pick it up with a SuperTUG? :santahat:
AirKevin
Wed Aug 17, 2022 10:19 pm
And how long can that take.
kalvado
Thu Aug 18, 2022 12:28 am
Vendor is going to ship those parts in 3 weeks, if everything works as planned.
AirKevin
Thu Aug 18, 2022 12:31 am
Oh, dear. That sounds like quite the kerfuffle. I don't know that the airlines would like having a plane stuck there for that long, and depending on the airport, I'm guessing the airport authorities won't like that, either.
kalvado
Thu Aug 18, 2022 12:38 am
Probably everyone who is involved in repairs had such "wut ze..." situations- on lead time or availability or pricing, aviation or not.
That's when we need Joe Patroni....
strfyr51
Thu Aug 18, 2022 6:19 am
you can move the airplane with the jetway disabled as long as you can safely close the main cabin door. you woud then have to turn the nose wheels in the direction of the jetway and push in the opposite direction making sure you straighten the nose wheel when you're 2-3 ft away from the jetway so as not to damage any airplane on an adjacent gate. I've done it an supervised it at least 3 times in my 33 years at United,
AirKevin
Thu Aug 18, 2022 7:57 am
How do you turn the nose wheel with the plane at the gate. I guess with the tiller?
FGITD
Fri Aug 19, 2022 12:25 am
You turn using the pushback, not the aircraft nose wheel.
Fri Aug 19, 2022 1:16 am
You could. Or the pedals. But as FGITD says it would have to be done by the tug. The steering lockout pin would be inserted so that the steering is disabled, just like with any pushback.
I see a problem though. The nose gear would be in the neutral position when connecting the tug. The tug needs to move before the nosewheel can be turned. By then, you've already scraped the fuselage alone the jetbridge.
AirKevin
Fri Aug 19, 2022 6:14 pm
Yeah, hence my befuddlement. I wasn't seeing how the tug would be able to turn the nose wheel in that position.
Thrusty69
Fri Aug 19, 2022 6:33 pm
I see what you mean now. I’ve never seen a disabled jet bridge forcibly moved away from the aircraft. It’s usually fixed by the airport authority relatively quickly or like others have said, you can always easily push back with the jet way on- just have to be careful.
Narrowbody you can put the tow bar on and physically move the nose gear by hand to as far as you got room to hook the tug up. Than the pushback will be away and back from the broken jet bridge. It gets done from time to time. Widebody you could still do if you got a couple strong folks…
FGITD
Fri Aug 19, 2022 9:47 pm
You angle the pushback. The towbar of course has to be attached straight to the aircraft, but you can angle the pushback when you attach it to the towbar. That way, at the first push you already have the nose gear and towbar turning in the direction you need. It’s definitely a slower, more delicate process but a halfway decent tug driver with some guidance can do it relatively easily.
Sat Aug 20, 2022 2:40 am
Cool. I guess I see what you mean now.
phatfarmlines
Sat Aug 20, 2022 9:33 pm
An interesting topic. One thing is for sure - here in the U.S., airlines will be insistent on using a jetway even if it is not functioning properly. Power to the jetway lost as the plane pulls into the gate for arrival? Passengers remain on the plane as the jetway is fixed instead of bringing out airstairs to connect to the rear of the plane.
AirKevin
Sun Aug 21, 2022 12:04 am
Hopefully it doesn't take weeks to fix it, then.
shamrock137
Sun Aug 21, 2022 10:46 am
Not that I know of. I've seen chains connected to a pushback tug used to pull the bridge off, but it still takes time for the chains to be found, tug placed in position, connected etc etc. I know on some older jet bridges if the power is lost, the wheels will lock as a safety measure, but this means that the bridge cant be moved until the wheel brakes are manually released.
