Jacobrhassell wrote:Is it just more advanced lights? If so, why is there a need for the flash to be longer?
Jake
rjsampson wrote:Jacobrhassell wrote:Is it just more advanced lights? If so, why is there a need for the flash to be longer?
Jake
As atlamt said, the longer flash is the newer LED light, which is more advanced. There is a need for the LED flash to be longer. The older flashlamps (strobe) lights as atlamt said, discharge a large amount of energy instantaneously, creating an extremely intense burst of light. So intense, that if the amount of light emitted from the burst were continuous, it would be blinding (well, not literally), but its extremely short duration has the intended effect of high visibility.
An LED beacon by contrast doesn't operate with sudden capacitive discharge. Its brightness (which can certainly be quite high), needs more "on time" to have the achieve a similar level to that of a flashlamp.
Jacobrhassell wrote:rjsampson wrote:Jacobrhassell wrote:Is it just more advanced lights? If so, why is there a need for the flash to be longer?
Jake
So why does Airbus refuse to implement this advanced light? Even on the new A350 and A330-900, it’s still the “strobe” light.
Thanks for the help!
Jake
Starlionblue wrote:Jacobrhassell wrote:So why does Airbus refuse to implement this advanced light? Even on the new A350 and A330-900, it’s still the “strobe” light.
I don't think it is a questions of "refusing".![]()
There are probably multiple reasons involving costs and tooling.
IFlyVeryLittle wrote:These were all rotating flashing lights back in the old days, right?
Jacobrhassell wrote:Hello,
I’ve noticed that on some E145s, the beacon light pattern is: Bottom, Top, Strobe, Bottom, Top, Strobe. However, some others I’ve seen (Even for the SAME airline!), the lights go BOTH, Strobe, BOTH, Strobe.
Why are there 2 different patterns for the same aircraft in the same airline?
kalvado wrote:I am not sure if Collins is the sole supplier of those lights for Airbus, but they have some interesting brochures.
At least for A350 Collins doesn't offer any strobes in their brochure:
https://www.collinsaerospace.com/-/medi ... 825e869998
