Jacobrhassell
Beacon Light Question
Thu Aug 18, 2022 5:47 pm
Hi,
I’ve had a question lingering in my head since I was 8 years old and saw planes at night.
Why do some planes have a blinking beacon light (<.1 sec flash) and others have a steady on and off (>.5 sec flash. For example, look at a short video of an A321 beacon: https://youtube.com/shorts/Igtk8WaCoKU?feature=share
vs
E75L beacon: https://youtube.com/shorts/1zxn5Us5DD4?feature=share
I know some people may not be able to tell, but I’d appreciate an answer.
So far I’ve seen the blinking beacon on:
- A320 and A320N family
- A350
- A330-2/300 AND -8/900
- A380
- B737 classic & NG
- B747-400 & -8
- B757
- B767
- B777-2/300
- All CRJs
- E75S
And the longer blink with:
- A220
- 737 MAX
- B777x
- B787
- E135/40/45 family
- E75L
Is it just more advanced lights? If so, why is there a need for the flash to be longer? It appears to be in the newer aircraft, and almost none of Airbus’ aircraft.
Thanks for the help,
Jake
atlamt
Re: Beacon Light Question
Thu Aug 18, 2022 5:54 pm
Led vs. strobe light. The strobes flash as the capacitors in the light discharge. Very bright but a short duration. The led's have a driver that controls the length of time the led is on. The slightly longer duration is more visible while still having the strobe effect.
rjsampson
Thu Aug 18, 2022 8:27 pm
Jake
As atlamt said, the longer flash is the newer LED light, which is more advanced. There is a need for the LED flash to be longer. The older flashlamps (strobe) lights as atlamt said, discharge a large amount of energy instantaneously, creating an extremely intense burst of light. So intense, that if the amount of light emitted from the burst were continuous, it would be blinding (well, not literally), but its extremely short duration has the intended effect of high visibility.
An LED beacon by contrast doesn't operate with sudden capacitive discharge. Its brightness (which can certainly be quite high), needs more "on time" to have the achieve a similar level to that of a flashlamp.
Jacobrhassell
Fri Aug 19, 2022 1:42 am
Jake
So why does Airbus refuse to implement this advanced light? Even on the new A350 and A330-900, it’s still the “strobe” light.
Thanks for the help!
Jacobrhassell
Strobe & Beacon Light Question
Fri Aug 19, 2022 2:12 am
Hello,
I’ve noticed that on some E145s, the beacon light pattern is: Bottom, Top, Strobe, Bottom, Top, Strobe. However, some others I’ve seen (Even for the SAME airline!), the lights go BOTH, Strobe, BOTH, Strobe.
Why are there 2 different patterns for the same aircraft in the same airline?
Fri Aug 19, 2022 3:29 am
Jake
I don't think it is a questions of "refusing". :D
There are probably multiple reasons involving costs and tooling.
kabq737
Fri Aug 19, 2022 5:17 am
Jake
I could be wrong but if I were to guess I bet it’s a customer option.
kalvado
Fri Aug 19, 2022 11:24 am
Could also be a difference in led design for longer ir shorter pulse.
At the very least, from the OP list - 320 has an external all- LED retrofit option for 320ceo from Collins, including beacons.
dennypayne
Re: Strobe & Beacon Light Question
Fri Aug 19, 2022 3:40 pm
Not to mention you can’t just decide to change a part of a certified design without at least some additional certification effort.
kalvado
Fri Aug 19, 2022 4:08 pm
I am not sure if Collins is the sole supplier of those lights for Airbus, but they have some interesting brochures.
At least for A350 Collins doesn't offer any strobes in their brochure:
https://www.collinsaerospace.com/-/medi ... 825e869998
A320: https://www.collinsaerospace.com/-/medi ... d885f0df56
Both LED and Xe options for CEO, LED only for sharklets.
https://www.collinsaerospace.com/-/medi ... a766246a52
A380 - LED beacon coming soon.
https://www.collinsaerospace.com/-/medi ... a21d4a2791
330/340 have only Xe option
IFlyVeryLittle
Fri Aug 19, 2022 6:29 pm
These were all rotating flashing lights back in the old days, right?
greg85
Fri Aug 19, 2022 7:21 pm
 https://youtu.be/02yLHYM7Wew
Here’s how to kick it old skool.
Sat Aug 20, 2022 2:09 am
A picture is worth a 1000 words, Nuff said
rjsampson
Sat Aug 20, 2022 9:55 pm
Certainly many.. but flashlamps ("strobes") go well back into the old days as well.
kalvado
Sun Aug 21, 2022 11:16 am
Where are the flashing beacons in this photo?
shamrock137
Sun Aug 21, 2022 11:17 am
Airbus still uses LED's, they just choose to program theirs with a fast flash pattern. Any A320/321 with sharklets has LED wing tip strobes, same with the 350. Boeing just chooses to use a slower pulse type flash pattern.
Hello,
In my experience the E145 flashes totally randomly. The lights aren't synched so when they are all switched on, they appear to flash at the same time, but slowly fall out of sync. What I've seen for the E145 at some airlines is that the beacons are being replaced by LED's as they burn out. So you will have an aircraft with the top beacon as a strobe, and the bottom beacon as LED. The CRJ series has a distinct top bottom flash for the red beacon.
Airbus has the most distinct and consistent flash pattern. The top and bottom strobe are synched, as well as the wing and tail strobes. The red beacons will flash at the same time. When the white wing and tail strobes are turned on, they will flash opposite the beacons, so you'll always see Red, White, Red, White on an Airbus. Additionally the wingtip strobes will flash twice, while the tail strobe flashes once. I'm not sure how accurate this is, but I was told its supposed to be easier to determine if an aircraft is facing towards or away from you at a greater distance then the nav lights are visible. the MD-11 had the same pattern. Exception to the rule is the A220, which was designed by Bombardier. Quirk to this aircraft is that the weight on wheels sensor changes the brightness of the red beacon. When the aircraft takes off, the beacon gets brighter.
LaunchDetected
Mon Aug 22, 2022 8:27 am
A350 strobe lights (and almost all the other exterior lights) are supplied by Safran.
First MSN were fitted with HID technology then LED was introduced (around MSN 300), both technologies are not interchangeable.
Jacobrhassell
Mon Aug 22, 2022 2:01 pm
Thanks for everyone’s help!
GalaxyFlyer
Mon Aug 22, 2022 9:44 pm
The requirement for anti-collision beacons was promulgated in August, 1971. Lots of military planes didn’t get them for a few years on. The F-100 had beacons installed as they went thru depot work. If you were flying one with a beacon, the rest of formation would’ve scoff at the “fire truck”.
Yes, a variety of rotating beacons until strobes became widespread in the ‘80s. Cessnas had just a flashing light early on. The KC-135 had a huge one with various colors for signaling.
KatanaDV20
Wed Aug 31, 2022 10:53 pm
I much prefer the rapid flashing strobes vs. the sleepy pulses. The double flash strobe on the Airbuses specially.
The aggressive WHAP-WHAP really gets noticed, not to mention it looks cool too! =)
Redbellyguppy
Thu Sep 15, 2022 1:40 pm
You know who prefers the LED long flash though? Despite how cool it looks? Pilots in line for takeoff at night. They aren’t nearly as blinding as the xenon strobes.
Users browsing this forum: aballack50 and 32 guests
