ghostboy
Maintenance Coffee Maker and Boiler
Wed Sep 07, 2022 8:38 am
Hello!
I am interested in maintenance of galley equipment, such as Coffee Maker and Boiler.
I have a question: "How does the approved organization do it?"
What does that require?
Maybe someone has a photo of the equipment or any documentation, share pls.
I believe that for this it is necessary to have a stand for the test.. or another equpment...
Pls help.
ReverseFlow
Re: Maintenance Coffee Maker and Boiler
Wed Sep 07, 2022 6:03 pm
ghostboy wrote:
Hello!
Pls help.
You'd repair it with the CMM. But that's proprietary information so nothing that would (should) be floating around the web.
Dalmd88
Wed Sep 07, 2022 9:09 pm
It's just like every other aircraft component. The organization; airline, MRO, repair shop, needs authority from the maker of the said component for repair. The manufacturer then allows the repairer access to the CMM. The CMM typically gives a parts breakdown, wiring diagrams, and any info that is needed for repair and test of the component.
LMP737
Thu Sep 08, 2022 4:54 pm
When I was still working the passenger side of the business I lost count of the number of coffee makers I changed or re-racked.
Lpbri
Thu Sep 08, 2022 5:20 pm
Large airlines usually do coffee make maintenance in-house. They get rotated in and out of service often enough that even some small carriers do the work in-house. Dedicated shops are used, usually employing unlicensed mechanics, with all the test equipment, parts and documentation to do the work.
Wacker1000
Wed Sep 14, 2022 8:49 pm
You run it until it breaks, place it on MEL, and do nothing until the MEL drops dead.
LTU330
Sun Sep 18, 2022 1:08 pm
You MEL it, and then replace it the next day when the part arrives from the Shop. It's a Cat D 120 Day item, but for the Pilots it's more important than literally anything else :)
Users browsing this forum: No registered users and 36 guests
