BAorAB wrote:Just noticed on Flightradar that UA 79 -EWR to NRT was operated by a 787X - N14001. The route is typicaly flown by a 789. Does anyone know if this was a passenger flight? Load factor? Cargo?
In any case 13:59 flight time for a 787X is impressive. Given how often we hear from Airbus fans on here that it's range is insufficient for long haul. I know UA operate TLV to EWR with a 787X daily which is often a 11:30hr flight. But 13:59 is a whole new level.
I see there was almost 1hr of taxi time in total for both sides, but still 13hrs in the air is impressive given it's specs.
CriticalPoint wrote:The 787-10 Carry’s the same amount of fuel as the -9 and -8. Therefore, yes it can roughly fly the same distance.
flipdewaf wrote:The 781 is capable of 6400nm at full pax according to Boeing, why would it be surprising that it can complete a mission lower than this when it subs for an aircraft with a lower pax load. Why are we not excited when other aircraft perform within their capabilities?
Fred
Sent from my iPad using Tapatalk
BAorAB wrote:flipdewaf wrote:The 781 is capable of 6400nm at full pax according to Boeing, why would it be surprising that it can complete a mission lower than this when it subs for an aircraft with a lower pax load. Why are we not excited when other aircraft perform within their capabilities?
Fred
Because so many on this forum labeled it as a medium haul east coast to europe aircraft with a sweet spot pf 6-8hr flight times.
Fred
BAorAB wrote:Because so many on this forum labeled it as a medium haul east coast to europe aircraft with a sweet spot pf 6-8hr flight times.
Fred
ElroyJetson wrote:No aircraft can be all things but many dubious claims about the 787-10 having poor payload/range performance relative to its competitors
that have been made over the years have probably been overblown.
ElroyJetson wrote:Not sure anyone has said the 787-10 has to equal the specs of the A35J. Kind of a straw man argument imho. I believe the point of the thread is the 787-10 is more capable than many originally indicated.
ElroyJetson wrote:
To this point neither the A35J or the 787-10 has sold particularly well relative to their smaller brethren. Is this a reflection on both not being as good, or is it a reflection of where each aircraft is in the replacement cycle of older, less efficient aircraft?
I guess time will tell.
flipdewaf wrote:ElroyJetson wrote:Not sure anyone has said the 787-10 has to equal the specs of the A35J. Kind of a straw man argument imho. I believe the point of the thread is the 787-10 is more capable than many originally indicated.
Indeed, they are in a totally different range spectrum. Even with the additional MTOW the A35K has over 2knm more range at the same payload.ElroyJetson wrote:
I think it’s none of these things.
This is me thinking out loud so please excuse if it makes not a lot of sense.
A 781/A35K can stand in for a 789/A359 respectively but the other way can only occur if the larger (more expensive) sibling wasn’t needed in the first place…of course there can be efficiencies between siblings (maintenance, pilot pool etc) but the larger more expensive model needs to be able to justify a network (and associated efficiencies) by itself above and beyond what the smaller (cheaper/less risky) sibling brings to that same network.
Fred
MileHFL400 wrote:I think there are a number of quite long haul flights that B78X’s do. Just because it doesn’t have the legs of the B772ER, A359 or B789 does, does not relegate the B78X to medium haul flights only!
