TDAero777 wrote:Hello All,
Quick question when it came to the design of turbo prop airliners EMB120, ATR, DASH, King Airs....etc when these aircraft were/are designed was the failure of a blade and potential for it to enter the cabin considered from a design perspective when it comes to strengthening to any degree possible those areas of the fuselage were the blades are nearest? Or is that calculated out as such a low probability that more consideration is given to ensure the blades themselves are within tight manufacturing tolerances to mitigate the chance of such a think happening? I know that turboprops have lost blades before with varying degrees of issues but have always wondered if that is something that is considered in the design phase of the aircraft?
T prop wrote:The area of the fuselage in the prop arc has strengthened cabin windows and ice shields. They're only to protect from ice coming off the prop blades. If a blade is slung off the hub towards the fuselage it will penetrate the cabin like a hot knife through butter.
rjsampson wrote:I suspect this is the primary reason that RJs (while less fuel efficient than turboprops) are on their way out. They've been entirely phased out in the US. Looking out the window on to a massive, and massively powerfully spinning propeller, is disconcerting to much of the flying public.
Shedding a blade? No cowling to contain it. Now: Such an event happening is so unlikely these days but, yeah. A given passenger, looking out the window 2 meters away at (in the public's mind) a blender-speed blade with the potential to rip through the fuselage. Not a great look.
I don't think turboprops have much life left in them, so long as 3-5 rows can visually see the massive torque of the output of these engines.
Happy Halloween!
StereoTechque wrote:Regulation mandates modern Turbofan engines to have a containment duct which encloses the Fan cowling area of the engine.
Shouldn't the ice shield also designed as a protection device in case of prop blade liberation.?
Yikes! wrote:T prop wrote:The area of the fuselage in the prop arc has strengthened cabin windows and ice shields. They're only to protect from ice coming off the prop blades. If a blade is slung off the hub towards the fuselage it will penetrate the cabin like a hot knife through butter.
Exactly. Those "shields" on the fuselage are to reduce paint damage from ice discarded by the propellers. EXTREMELY RARE are propeller blade separations. Can't quote statistics but maybe one blade separation every 2 or 3 years, worldwide???
CowAnon wrote:Not necessarily, since the "strike zone" of a shedded blade onto the fuselage is forward of the propeller's rotational plane. The forces that act on the blades are forward (thrust) because the blades are pushing air backwards.
Happy Halloween!
StereoTechque wrote:CowAnon wrote:Not necessarily, since the "strike zone" of a shedded blade onto the fuselage is forward of the propeller's rotational plane. The forces that act on the blades are forward (thrust) because the blades are pushing air backwards.
Hi, are you sure about this? Wouldn't the high rpm of the Propeller have a greater effect than the forward force in case of blade separation?
flipdewaf wrote:StereoTechque wrote:CowAnon wrote:Not necessarily, since the "strike zone" of a shedded blade onto the fuselage is forward of the propeller's rotational plane. The forces that act on the blades are forward (thrust) because the blades are pushing air backwards.
Maybe it is greater but as the forward force still exists the resultant force still has a forward component and as such will accelerate forward.
Fred
Sent from my iPad using Tapatalk
flipdewaf wrote:when there is a separation event there is only 1 force remaining and that’s the thrust as the centripetal force disappears, it is now just a velocity. Ignoring drag of course..
77west wrote:TDAero777 wrote:Hello All,
They normally have a strengthened area around the prop - if you have a look at some ATR and Q400 pics you can clearly see it. It is not a common occurrence though to lose a prop unless combined with other factors (ground strike/crash)
StereoTechque wrote:flipdewaf wrote:when there is a separation event there is only 1 force remaining and that’s the thrust as the centripetal force disappears, it is now just a velocity. Ignoring drag of course..
Centrifugal force is the most prominent though...
Happy Halloween!
KingOrGod wrote:Here you go... Back home a Jetstream 41 hit a big assed bird on final approach and shed a prop into the cabin...
http://avherald.com/h?article=4f2a35e6&opt=256
