exFWAOONW wrote:Many variables in play here.
Is ETOPS required for freight? I don't think it is, but I might be all wet. It might be a local requirement for certain freighters.
The A/C that kept ETOPS during conversion may be subject to leasing terms, where the residual value of the A/C is less without the ETOPS certification still current.
Different conversion facilities have different procedures for converting A/C that are certified by the local or end-use governmental authority. They cannot deviate from the certified procedure for just a plane or two.
Starlionblue wrote:exFWAOONW wrote:Many variables in play here.
Yes, ETOPS/EDTO is required for freight. Why would it not be?
14 CFR § 135.364 Maximum flying time outside the United States.
After August 13, 2008, no certificate holder may operate an airplane, other than an all-cargo airplane with more than two engines, on a planned route that exceeds 180 minutes flying time (at the one-engine-inoperative cruise speed under standard conditions in still air) from an Adequate Airport outside the continental United States unless the operation is approved by the FAA in accordance with Appendix G of this part, Extended Operations (ETOPS).
aeronavegar wrote:I've read that the Boeing 737-800BCF and IAI's 737-800BDSF are not ETOPS certified, but AEI's 737-800SF is... Curious to understand why this is the case.
1) Does an aircraft that is type-certified, from a design/configuration perspective (such as a passenger 737-800, approved for 180 minutes ETOPS), lose its ETOPS certification if it's later converted to a freighter?
2) If that's the case, is it because of the Class E Main Deck Cargo Compartment installed as part of the P2F conversion, which doesn't have a fire suppression system, or for another reason? The assumption here being (please confirm) that all cargo compartments need to be Class C (with a fire suppression system) in ETOPS-certified aircraft (?).
Starlionblue wrote:As I understand it, ETOPS/EDTO limits are very much dependent on cargo fire suppression capability.
All-cargo aircraft are not required to have fire suppression, even for ETOPS operations
ArcticFlyer wrote:Starlionblue wrote:As I understand it, ETOPS/EDTO limits are very much dependent on cargo fire suppression capability.
Why would they? There are plenty of MD-11Fs and 747Fs flying around with no fire suppression systems and without any regard to ETOPS requirements.
Starlionblue wrote:Yeah, but as mentioned above, they can go 180 minutes before they need ETOPS, meaning they don't need it at all, so it's a bit of a moot point.
If they needed to go beyond 180 minutes, e.g. ETOPS207, the limiting factor might well be cargo fire suppression capability, just as with twins.
121.161 - Airplane limitations: Type of Route
(a) Except as provided in paragraph (e) of this section, unless approved by the Administrator in accordance with Appendix P of this part and authorized in the certificate holder's operations specifications, no certificate holder may operate a turbine-engine-powered airplane over a route that contains a point -
(1) Farther than a flying time from an Adequate Airport (at a one-engine-inoperative cruise speed in still air) of 60 minutes for a two-engine airplane or 180 minutes for a passenger-carrying airplane with more than two engines;
(2)Within the North Polar Area; or
(3)Within the South Polar Area
aeronavegar wrote:Ok, but I'm still curious as to why would a Freighter conversion that doesn't otherwise modify ETOPS-approved systems (i.e. Propulsion, etc.) invalidate the aircraft's ETOPS type certification?
ArcticFlyer wrote:Starlionblue wrote:Yeah, but as mentioned above, they can go 180 minutes before they need ETOPS, meaning they don't need it at all, so it's a bit of a moot point.
Not so for cargo airplanes. See below:121.161 - Airplane limitations: Type of Route
So, unless flying in the North or South Polar Areas (which few operators do; you have to go north of 78 degrees north to be in the North Polar Area), cargo airplanes with more than two engines do not require ETOPS at all.
Dalmd88 wrote:ETOPS is a costly status to maintain if you don't really need it. There is a lot of training and record keeping. Many of the aircraft's components require specific maintenance, which is an added cost. These components are in just about every system that would cause a plane to divert. Yes that includes the engines, but also the electrical, fuel, and hydraulic systems.
When those items need a shop visit, it's to ETOPS standards. Those components can only be changed by an ETOPS trained AMT. For may things you need two ETOPS trained AMT's for the job. Just servicing engine oil, requires one AMT per engine. So even simple tasks, like a through flight check, requires multiple trained people.
Starlionblue wrote:ArcticFlyer wrote:Starlionblue wrote:Yeah, but as mentioned above, they can go 180 minutes before they need ETOPS, meaning they don't need it at all, so it's a bit of a moot point.
I'll nitpick. In the regulation quoted, it says that ETOPS is required above 180 minutes for airplanes with more than two engines. Granted, going beyond 180 minutes for a cargo operator is of little practical use, but the regulation is there.
Also, this is jurisdiction-dependent. Not all jurisdictions have the same regulations.
ArcticFlyer wrote:Dalmd88 wrote:ETOPS is a costly status to maintain if you don't really need it. There is a lot of training and record keeping. Many of the aircraft's components require specific maintenance, which is an added cost. These components are in just about every system that would cause a plane to divert. Yes that includes the engines, but also the electrical, fuel, and hydraulic systems.
All points are absolutely true, but they would weigh more on an operator's decision on whether or not to seek ETOPS approval rather than a manufacturer or the owner of a STC conversion.
Dalmd88 wrote:ArcticFlyer wrote:Dalmd88 wrote:ETOPS is a costly status to maintain if you don't really need it. There is a lot of training and record keeping. Many of the aircraft's components require specific maintenance, which is an added cost. These components are in just about every system that would cause a plane to divert. Yes that includes the engines, but also the electrical, fuel, and hydraulic systems.
But the cost of ETOPS capable would have to be baked into the STC. The proof of that capability lies with the owner of the STC process. If few of your customers are expected to need ETOPS, then it doesn't make sense to go through the process of certifying your STC as ETOPS capable.
ArcticFlyer wrote:aeronavegar wrote:On a remotely similar note, my company learned (the hard way as usual) that Boeing removes the factory fire suppression system for the lower cargo compartments on its 767-300BCFs, making them Class E compartments along with the main deck (of course, unlike the main deck, the lower compartments are not accessible locations). I'm told it was because they are afraid of being held liable if there is a mishap involving hazardous materials. Perhaps a similar thought process can explain the lack of ETOPS approval for the 737-800BCF
Natflyer wrote:I have flown several converted ETOPS 757-200, the all kept the ETOPS status and Class C lower holds, whereas the B757-200PFs I flew were non-ETOPS with Class E holds.
