Martinlest
Yaw Damper: On or Off?
Sat Dec 03, 2022 5:52 pm
Hi - another little question which Mr. Google hasn't really managed to answer properly for me! Can anyone here kindly help?
What I understand in regard to the Yaw Damper is this:
1. In some aircraft, the pilots switch on the YD before takeoff and turn it off after landing. I have read that some modern a/c do not engage the YD, even though it is switched on on the OH panel, until a certain altitude is reached, and it is automatically turned off again on descent at a certain altitude, even though the YD switch is still in the 'on' position.
2. Otherwise, the YD is only engaged along with the Autopilot and disengaged by the pilots as the AP is turned off. This makes sense (to me!), as I imagine that having the YD active when hand flying the plane is hardly helpful!
3. In some planes (e.g. the Dash8) the YD acts as the third axis of the autopilot. Not sure how that works in practice but must mean the pilots don't have a lot of manual control over the rudder?
What would be most useful to know is, assuming statements 1 & 2 are broadly true, to which type of aircraft each case applies.... in which a/c types do pilots manually engage/disengage the YD at the same time as the AP, and in which is it turned on before TO and left on until taxiing to the gate?
Any info (not too 'techie' please!) appreciated.
Thanks, as ever.
GalaxyFlyer
Re: Yaw Damper: On or Off?
Sat Dec 03, 2022 6:30 pm
On the jets I’ve flown, the YD is on all the time, unless selected off for a procedural reason—failure. It didn’t inhibit pilot inputs, it just responds to transient yaw such as turbulence or a slip or skid during banking and turns. Mostly invisible unless it’s inop and the design is susceptible to Dutch roll.
Loads of planes have them from a Cirrus to a 747, so lots of variations in application and use.
N1120A
Sat Dec 03, 2022 6:41 pm
In smaller airplanes, the yaw damper is off for taxi, takeoff and landing. Even in many business jets, you depart without it on, but put it on at V2 or whatever. Many autopilots will leave yaw damp on if you turn off the autopilot with the trim interrupt and only the red button will turn it off.
GalaxyFlyer
Sat Dec 03, 2022 7:44 pm
Been a long time, but the original Citation damper was like that—off until airborne, off for landing.
Flow2706
Sat Dec 03, 2022 10:50 pm
In most jet the yaw damper would be on whenever it is not failed. On the A320, the Yaw Damper function is integrated into/is a function of the Flight Augmentation Computer (FAC), therefore it is "always" on whenever it or the FAC is not failed. As both FACs are able to provide the yaw damping function, the yaw damping function will still be available through the other FAC in case of a single failure (one yaw damper/one FAC). The complete loss of yaw damper function (i.e. when both are failed) on the A320 results in the loss of both Autopilots and a degradation of the flight controls to alternate law. The Yaw Damper ist actually quite helpful in case of an engine failure as the yaw damper will provide an initial rudder input, which is not fully sufficient to counter the engine failure (further rudder input, either manually or through an engaged autopilot will still be necessary), but results in a stable flight path (in case of no pilot input during an engine failure after takeoff the airplane will slowly climb with a side slip, but it will not enter a dangerous attitude).
Martinlest
Sat Dec 03, 2022 11:14 pm
Thank you.
So as a rule of thumb (even if it is a generalisation), Boeings, Airbuses, Embraer jets and the like will have the YD on from (say) taxi out to taxi in. I would have to make a judgment as to what constitutes a 'smaller plane': I suppose, ATRs, Dash8, Emb110, Cessna Citation and so forth.
ArcticFlyer
Sun Dec 04, 2022 6:36 am
In my experience, jet airliners always fly with the YD on and failure in flight is considered a non-normal procedure. For smaller airplanes like business jets and turboprops YD use runs the gamut; some use it all the time, some have limitations and in others it is completely optional.
The Dash 8 was interesting - if our takeoff weight was below 31,750 lbs (I'm amazed I remember that years later) or if we were using flaps 15 (required for tailwinds over 10 kts) the YD had to be off for takeoff. This was due to the fact that the YD reduced rudder effectiveness to the point that, at such a low VR, VR would be less than VMC. With the YD off VMC was reduced several knots and this was no longer a problem. I will say from experience that the airplane was squirrely as heck with the YD off, particulaly in strong tailwinds, and that limitation was often "forgotten" by crews.
Martinlest
Sun Dec 04, 2022 3:15 pm
Right, thanks. I think I have had my question answered. Since this is obviously for flightsim use, I am tending towards a rough generalisation of when to have the YD engaged in any particular aircraft type, some of which of course have this feature better modelled than others (the Dash8 (payware addon) in X-Plane is a bit of a gem, in fact!).
CarlosSi
Sun Dec 04, 2022 11:20 pm
Would it be on for a crosswind landing? Does yaw damper only dampen external yawing and not pilot induced?
Sun Dec 04, 2022 11:41 pm
I can only speak for Airbus but we can't actually turn the yaw damper off as it is an integral part of the flight control system. Large swept wing jets tend to require a yaw damper on at all times due to the aerodynamic characteristics of the designs. We never touch the rudder except on the ground, on landing, and with an engine out.
Yes, it is on for a crosswind landing. Yaw damping dampens "external yawing", e.g. Dutch Roll, and also coordinates turns, that is inputs rudder in a turn so the tail doesn't "drag".
In a crosswind landing we purposefully uncoordinate the turn, so to speak. Hence why we need to add rudder input in order to straighten out the aircraft.
Martinlest
Mon Dec 05, 2022 2:08 am
Yes, when I wrote that, I should not of course have included Airbus in the list :-)
Max Q
Mon Dec 05, 2022 4:03 am
727 / MD80, 757 and 767 yaw dampers were always on and operation was automatic, no pilot action required
There were significant altitude and speed restrictions for the 727 with the failure of one of the two yaw dampers or dispatching with one inoperative
Without any yaw dampers at altitude the 727 would experience a severe Dutch roll that was not easy to suppress with control inputs
You had to carefully time your aileron movements to make very positive opposite inputs as these uncommanded rolls happened
If you didn’t do it properly it was easy to end up inverted, this was only practiced in the simulator
Best remedy was full speed brake (which helped to alleviate the problem) and an immediate descent to lower altitude where it wasn’t a significant issue
So glad to see no one call it a yaw ‘dampener’
seat55a
Mon Dec 05, 2022 4:18 am
For the usage in smaller jets refer to some well known YouTube channels. One of the pilots really struggles with 'dampener'. He obviously knows it's wrong but still says it about half the time. It's a checklist item.
Mon Dec 05, 2022 4:36 am
Why not? Airbus has definitely has yaw damping. It just isn't a discrete logic unit. However, the older A330s have a dedicated yaw damper servo, whilst the newer A330s and the A350 do not.
I doubt it is a discrete logic unit on modern Boeings either! :)
N1120A
Mon Dec 05, 2022 4:49 am
Steve definitely uses that term a lot. You can fly a TBM without putting on the yaw damper, which is off for takeoff and landing, but your right leg would be getting a major workout with 850 HP spinning the prop.
Max Q
Mon Dec 05, 2022 10:24 am
Just another example of our language being mangled !
tb727
Fri Dec 09, 2022 2:44 am
I almost broke the sim getting the plane to Dutch Roll for my sim partner once lol
Learjet 20/30 series it was off for takeoff and landing. It was hard to use the rudder pedals swiftly if it was on.
BoeingGuy
Mon Dec 12, 2022 3:02 am
The 737 Max has a Yaw Damper/Stabilizer Module. It is a discrete unit on the 767, IIRC. Yaw Damping functionality is part of the Primary Flight Computers on the 777 and 787.
Unclekoru
Sat Dec 17, 2022 1:00 am
Was that on the Dash 8-100? I don't remember that limitation from my time on the Q300.
ArcticFlyer
Sat Dec 17, 2022 3:14 am
Yes that was on the -100 which is the only variant I have experience on.
Unclekoru
Sat Dec 17, 2022 8:49 pm
The -100 always looked like it'd be a great aircraft to fly.
And yes, I remember the Q300 being unpleasant to fly without the yaw damper, very "squirrely". Also meant we didn't have an autopilot available.
ArcticFlyer
Sun Dec 18, 2022 1:27 am
It was the most fun I've ever had in a "big" airplane. Flew like a giant 182.
bhill
Thu Mar 23, 2023 8:06 pm
Huh, I just learned that with the 737, the yaw dampener is linked such that pilots do not need to input rudder when turning, the yaw damper manages the rudder and the pilot manages the spoilers and ailerons. Smoooth turns.
23463245613
Thu Mar 23, 2023 8:24 pm
I’ve not flown a single transport category jet where you touch the rudder in a turn. Feet “off” the rudders after rotate, and back “on” when you de crab in the flare. It’s not a Cessna.
SaveFerris
Fri Mar 24, 2023 1:08 am
On the ERJ-145 we had to takeoff and land with the Yaw Dampener off. I don’t remember the minimum engagement height but on approach at 100’ AGL we verified and called out “Yaw Dampener Off.” As others have mentioned above, on all the other transport category aircraft I’ve flown (737, 747 and 767) it stays on the entire flight unless an abnormal checklist directs you to turn it off.
Max Q
Fri Mar 24, 2023 2:40 am
No such thing as a yaw dampener
It’s called a yaw damper
Trimeresurus
Sat Mar 25, 2023 12:02 am
Kind of an unrelated question, but is this also the reason why the autopilot is on like 99% of the time in big jets? Easy to put in unrecoverable situations, but unlike a Cessna 152 they are fast enough to be able to leave you behind the situation easily, but also much more underpowered per kg of weight compared to fighter jets or even business jets, so you can't as easily power yourself out of a stall.
ArcticFlyer
Sat Mar 25, 2023 12:06 am
The manual may make that claim but it is not entirely true in practice. At high altitude, sure, but the yaw damper's authority is too limited to fully coordinate 20-30 degree bank turns at low altitude/airspeed.
ArcticFlyer
Sat Mar 25, 2023 12:23 am
A couple of misconceptions here.
First, other than being faster and "slipperier" (no prop drag) jets fly just like other airplanes. The autopilot is on the majority of the time because (1) the majority of flight time is during boring cruise flight and I'd rather be talking or reading than hand-flying for 5 hours, (2) cruise flight at high altitude requires a very high level of precision, especially in RVSM airspace (an autopilot is required for RVSM although nothing actually says we have to use it), and (3) in busy terminal airspace the autopilot allow me to focus less on flying the airplane and more on situational awareness, responding to ATC, etc. I usually hand-fly below 18,000 unless the weather is really bad or I'm tired, but most of my colleagues in the airline industry are pretty lazy. Laziness, however, is in no way related to limitations of large jets.
At heavy weights and high altitudes jets do need to be managed thoughtfully to avoid getting into an unstable low-energy state (see Pinnacle Airlines 3701 for an example) but prompt action can still effect a recovery from these situations although it may involve a significant loss of altitude. At low altitudes it is entirely possible to power out of a stall with very little altitude loss although that's not how we're trained.
GalaxyFlyer
Sat Mar 25, 2023 12:25 am
All of modern planes in transport category hand fly fine and not prone to upsets or stalls with attentive handling. A CE-150 has a much narrower range between stall and Vne than a jet. That said, at cruise, near optimum level. a jet transport operates in a well understood but limited range of Mach numbers, wider than earlier designs like the B727.
Autopilots are used due to work load, RVSM requirements, fuel savings due to more accurate level capture. Prior to RVSM,myself and two other pilots hand flew a couple Atlantic crossings—a workout at 2am.
Trimeresurus
Sat Mar 25, 2023 1:03 am
I actually meant like below 15k feet rather than RVSM or coffin corner altitudes. For example a complicated RNAV arrival with lots of waypoints, which you need to fly through at 210-240 knots GS as opposed to something like 75 in a single engine small prop. So a moment of preoccupation in a 777 costs you around 3 times more than a Cessna. Also the ramifications of a stall in a 777 at the same altitude as a 152 would be a lot more dramatic both because of the altitude needed to recover and the stress that such a recovery maneuver may introduce to the fuselage
GalaxyFlyer
Sat Mar 25, 2023 2:15 am
A stall won’t dramatically damage the airliner, they’re tested for it. An approach to stall where the shaker sounds at low altitude doesn’t require much altitude loss. The RNAV arrival, in your example is all managed by the FMS, displayed on the PFD and FD cues and can be hand flow, more accurately possibly by the autopilot but the crew must be able to fly it. There’s no preoccupation, you must be ahead of the plane.
N1120A
Sat Mar 25, 2023 3:40 am
The speeds on STARS are IAS, not GS.
Trimeresurus
Sat Mar 25, 2023 11:06 am
As restrictions on the plates yes, I just said what they'd correspond to GS on top of my head, assuming a 1500 FPM descent
Users browsing this forum: No registered users and 43 guests
