GalaxyFlyer wrote:The answer is within the SFRA document
c. Any person operating an aircraft under VFR within the DC SFRA/FRZ who becomes aware of an inability to comply with the requirement to maintain radio contact with ATC shall immediately change the transponder code to 7600 and exit the DC SFRA/FRZ by the most direct lateral route or if the aircraft departure point is closer, return to the departure point by the most direct route. These procedures do not authorize penetration of restricted or prohibited airspace.
d. Any person operating an aircraft under IFR within the DC SFRA who becomes aware of an inability to comply with the requirement to maintain radio contact with ATC shall continue the flight via the two-way radio communications failure procedures found in the FAA Aeronautical Information Manual. These procedures do not authorize penetration of restricted or prohibited airspace.
flipdewaf wrote:I havent flown in a long while (8 years?) but isn't it generally a requirement to have operable 2-way radio in all controlled airspace?
Fred
