widebodyphotog
T-O Performance On 777-200ER GE90-95 Vs PW4090
Fri May 19, 2000 9:27 pm
I would like to know if some of you knowledgeble folks out there could give me some answers to a few questions I've got.
I would like to know the take-off performance differences between two versions of 777-200ER at MTOW for a 5950nm mission. (Basically the runway requirements) The comparison is between a GE90 Powered 777-200ER at 656,000lb TOW vs PW4090 Powered 777-200ER at 632,500lb TOW. The assumptions are that both are carrying a full pax load of 234 persons and cargo is at maximum limited by fuel required for the mission. Also assuming same wind conditions for both aircraft.
Another question I would like to pose is does Boeing offer PW powered 777-200ER at 656,000lb MTOW, and if they do what is the engine thrust for that version. The information I have received says that 656,000lb MTOW is offered for R-R and GE powered 772ER but not PW.
If there is any other important parameter I left out of my inquiry I am sure someone will fill me in and I will rectify it if I can.
AFa340-300E
What GE90?
Sat May 20, 2000 2:10 am
Hello,
Could you please precise what type of GE90?
Alain
widebodyphotog
RE: What GE90?
Sat May 20, 2000 3:33 am
GE90-92B...
twa747100
RE: T-O Performance On 777-200ER GE90-95 Vs PW4090
Wed May 24, 2000 12:28 pm
Now that is what i call a question
Wed May 24, 2000 1:13 pm
The highest MTOW for a 777-200 IGW with Pratts I've seen is 640,000 using PW4090-3
Thu May 25, 2000 4:12 am
Disregard my post above - its 650,000 Max Taxi weight, 648,000 Max Takeoff, with PW4090B. The detail spec. only states more than 90,000 lbs.
widebodyphotog
Fri May 26, 2000 9:03 am
Thanks for that bit of information! The PW4090B only makes 90,000lbt? And the MTOW allowed with that thrust setting is 648,000lb? Those numbers would make the field length significantly longer than GE90-92/3/5 with 93,000lbt and 656,000lbs I would think, especially considering the GE90's greater propulsive efficiency. I have been able to obtatain a weight and balance and fuel plan simulation for a GE powered 772ER going from CDG to SIN and back but I can't find any such info for a PW powered version. Does anyone operate the PW 772ER on a route of similar length? (ie 6,800sm by the great circle distance)
Tks
widebodyphotog
ConcordeBoy
Wed May 25, 2005 4:17 am
Quoting Widebodyphotog (Thread starter):
Nope, limit is 648K.lb
PW operators didn't seem to mind, because of Pratt's gold-n'-glory promises of the PW4098's future performance. Once that engine not-so-surprisingly turned out to be a complete and utter flop, GE/RR pulled significantly ahead on the higher MTOW 777 sales.
Quoting Widebodyphotog (Reply 6):
Oddly enough, yes. It's certified for 91,790K.lb but no operator ops it over 90K
I recently posted a similar thread to this before reading this one:
https://www.airliners.net/discussions...eneral_aviation/read.main/2130260/
KALB
Wed May 25, 2005 11:29 pm
Most of the time the maximum performance differences between the various engines available to power the 777, probably does not matter. I imagine most operators probably use FMC generated reduced power settings for takeoffs.
widebodyphotog
Thu May 26, 2005 8:32 am
Good God!
I started this thread five years ago and since then I've been privleged enough to get to a position where I can work out the answers to questions like these and apply those answers to real situations on a daily basis.
Thanks all for the responses
-widebodyphotog
gigneil
Thu May 26, 2005 9:16 am
How the hell did this happen, exactly?
N
ConcordeBoy
Thu May 26, 2005 10:35 am
Holy crap!
...I never once noticed the date.  shock  Just did a typical search in the tech forum trying to answer my PW4090 question and this came up.
Users browsing this forum: No registered users and 20 guests
