wilky
B747-400 Cargo Information
Mon Dec 04, 2000 5:42 pm
Hi there, I was wondering if any of the cargo handlers out there would be able to help me with the weights of the LD-1 containers as used on the 747, and also the approximate fuselage stations of the forward and aft cargo pits, along with approx floor area and weight limits.
Thanks in advance
Wilky
hailstone
RE: B747-400 Cargo Information
Mon Dec 04, 2000 6:20 pm
hi wilky,
do not know so much about the ld-1, but check the jl site for weight limitations on the various positions (they're pretty good):
http://165.76.11.2/jalcargo/english/info3.html
later
olaf
widebodyphotog
Tue Dec 05, 2000 9:27 pm
Here ya go!
LD-1 Container:
Max allowable wgt:1587KG
Tare: 79-170KG
Fwd Containerized Hold:
Length: 497.7 IN
Fwd end STA: 894.75
Aft end STA: 1392.45
Aft Containerized Hold:
Length: 426.5 IN
Fwd end STA: 1913.00
Aft end STA: 1486.50
Floor Limitations:
Fwd Containerized Hold: 150PSF
Aft Containerized Hold: 150PSF
Bulk Compartment: 150PSF
Hope this helps some
-widebodyphotog
If you know what's really going on then you'll know what to do
widebodyphotog
Compartment Weight Limits
Tue Dec 05, 2000 10:00 pm
Sorry forgot to include the compartment limits you asked for.
F1: 7,832KG
F2: 12,412KG
F3: 8,112KG
F4: 10,816KG
BULK: 5,357KG
It is interesting to note that F1 and A1 have only 2 pallet positions and it is very easy to max out those compartments with heavy pallets. You can never load two max weight pallets in either of those compartments.
-widebodyphotog
Users browsing this forum: Baidu [Spider] and 14 guests
