ejaymd11
Glass Cockpits
Fri Sep 07, 2001 5:13 am
Which aircraft do you thik has the most technologically advaced flight deck: the MD-11,747,757,A320 series or the A340/50.
Ejay MD-11
bio15
RE: Glass Cockpits
Fri Sep 07, 2001 7:50 am
You might want to rephrase your question as a more technical one. Be more precise.
But I do believe the A340 is the most advanced among the ones you mentioned above.
-bio
RE: Glass Cockpits
Fri Sep 07, 2001 1:33 pm
A good friend of mine flew the MD-11 for a couple of years and he said it can do alot of system malfunction stuff automatically which he says is more advanced than the boeings.
seagull
RE: Glass Cockpits
Fri Sep 07, 2001 2:13 pm
In terms of cockpit automation, the MD-11 is the most. In terms of the architecture for the avionics, the MD-10 is the most recent addition, so has the latest and greatest. In terms of flight control software, the 777, I would expect.
So, it really depends on how you want to quantify it.
Metwrench
RE: Glass Cockpits
Fri Sep 07, 2001 4:06 pm
How about a 1948 Cessna 120?
Altimeter
Airspeed
Turn & Bank
Magnetic Compass
DG
Engine Oil Pressure
Engine RPM
Anyone of them goes bad, find a safe place to land.
That's sophisticated.
avionic
RE: Glass Cockpits
Fri Sep 07, 2001 4:53 pm
If i have to be honest, sure the 747-400, and the 340 have nice glascockpitt, but in my opinion, the most advanced now, has got to be the dash 8 q400, although it is having birth problems...I don t personnally work on the q400, but have had several opportunities to check it out in flight as well as on ground.....very advanced!
dash8tech
RE: Glass Cockpits
Fri Sep 07, 2001 10:09 pm
Avonic - It's advanced alright, too advanced. That plane is p****** us off to the extreme at the 'unnamed airline' I work for. Niussance faults they call them at the factory. yeah, well those faults are cancelling/ferrying flights left and right.
Nice plane to fly on, when it flies. Very comfortable and quiet (save for reverse pitch on landing).
Heck, the surrounding neighbours of the airports tihnk it's really quiet. If it ain't flying it ain't making any noise taking off!
Argh, curses!
Cheers!
avionic
RE: Glass Cockpits
Sat Sep 08, 2001 1:35 am
Yeap the airline which i work for has a commuter section, that is struggling with the piece of ****.....nontheless, the concept is ok.....
avionic
Engineering Hell...
Sat Sep 08, 2001 1:44 am
Apparently, there quite a few mechs in here, what a wonderfull surprise...thanks for the response on my other posts.....now i would like to ask you about those places on planes when u work, that are just impossible....safetywiring with your head down using a mirror and no room for your hands....share your favorite places/jobs.....i got some for you: flap transmitter on md80.....brake temp sensor safetywiring on md80 with brakes on.....anything in the pylon of a 767.....centertank boost pumps on a 737ng....etc....what would give you a headache?
dash8tech
RE: Glass Cockpits
Sat Sep 08, 2001 9:44 am
Hi Avionic, Judging by your Denmark location I think I know which airline you mean, mine isn't much secret either.
Closer in proximity to you than me, I hear that Tyrolean have sent their Q400's back!
Cheers.
airplay
RE: Glass Cockpits
Sun Sep 09, 2001 6:08 am
Technologically advanced "aircraft" I would say is the BD700 (Global Express). The clincher is the electronic load management system that replaces tons of circuit breakers.
Now if you said "airliner" I would have to say it's a tie between 777/A330-A340 and Concorde....
 Smile
Metwrench
Ejmd11
Sun Sep 09, 2001 3:59 pm
Doesn't matter what aircraft, the toughest task on the instrument panel is keeping all the instrument lighting working!!!!
avionic
RE: Glass Cockpits
Mon Sep 10, 2001 6:09 am
yeah...too bad....the idea behind the plane is good, too bad they messed up the finish....
