PizzaPolli
Runways And The ---->'s
Mon Jan 07, 2002 1:55 am
Ok, what is the reason that some runways are built with huge run ups i.e. JFK 13R/31L so that when planes take off they use the whole runway but when they land they touch down real far down? I assume that the area of the runway that has just the arrows ---> is not as reinforced as the rest of the runway but what is the point of doing this? What benfit does it have?
Accidentally
RE: Runways And The ---->'s
Mon Jan 07, 2002 2:14 am
I think what you're talking about is the threshhold...as far as I know it's there to help you clear obstacles, but don't quote me on that.
Indianapolis, IN
LY744
Mon Jan 07, 2002 4:19 am
Accidentally is right. It is a relocated threshold. Usually it's purpose is to help landing a/c clear obstacles (is it ever used for noise reduction purposes, i.e. when the approach is over residential areas?) that are close to that end of the runway. AFAIK, the runway construction is the same for the whole runway. The beginning of the actual threshold will be marked with green lights.
LY744.
Mon Jan 07, 2002 4:29 am
The term used in the States is "Displaced Threshold"
ThirtyEcho
Mon Jan 07, 2002 6:03 am
You'll notice that the "touchdown zone" markings are way up the runway. They are two parallel bars, one on each side of the runway, that correspond to the ILS glideslope flare point. The -----> area is also the overrun coming from the other direction. The purpose is obstruction clearance, so it can be used for takeoffs but not landings.
Mr Spaceman
Mon Jan 07, 2002 6:47 am
Hi guys.
A picture is worth a thousand words.
Click for large version
Photo © Evan Gillespie
Photo © Daems Guy
Photo © Daems Guy
Check out the size of the Touch Down Zone runway markings at Atlantic City Intl (ACY). I think they're the largest I've ever seen.
Just my 2 cents gentlmen.
Chris  Smile
Ralgha
Mon Jan 07, 2002 7:56 am
The arrows you are all discussing are part of displaced thresholds, NOT overruns. Displaced thresholds are used for obstical clearance and noise abatement on landing as previously stated. Overruns are generally not as strong as the main runway, marked by large yellow chevrons, and intended only for emergency use.
 Big thumbs up
flyf15
Mon Jan 07, 2002 9:07 am
Just to add, the portion of runway before the marked displaced threshold can be used for takeoff, or landing rollout, just not touchdown.
LY744
Mon Jan 07, 2002 9:59 am
Talking about runway markings, can someone please explain the purpose of the big white rechtangles that are painted 1000' from the end ("beginning"?) of the treshold on runways with instrument approaches? I mean, I believe that they are supposed to mark the touchdown point or whatever, but do airplanes really land that far from the treshold? I mean, 1000' could come in handy!  Smile
LY744.
Beefmoney
Mon Jan 07, 2002 11:20 am
LY744,
Those markings are the "touchdown zone" or where the ILS glideslope meets the runway, airlines usually land a ways after that, even though a "perfect" landing would be in the zone. But greasing a landing causes them to land somtimes 1000' after that.
ejaymd11
Mon Jan 07, 2002 11:42 am
Displaced thresholds are also for when the ground is unsuitable for heavy operations. Here in Roanoke runway 24 is displaced because the runway needed to be lengthened but there is a tunnel in the way. So the front end of 24 is actualy above a tunnel.
TAA_Airbus
Tue Jan 08, 2002 10:13 am
Back to the original question.
There are 2 common reasons, one is obstacle clearance on late finals, which everyone has said.
The other is the runway may not be strong enough in that area to arrest the descent of a heavy a/c.
Commonly you find that a runway is built, and then later on they add a displaced threshold, and consequently, it doesnt have the reinforcements that the original runway has.
n4khgirl
Tue Jan 08, 2002 11:01 am
Have they finished construction on rwy 24 in ROA yet? I heard they were gonna start working on 33 soon... or the taxiway leading to it infront of Piedmont
*Camille
ejaymd11
Wed Jan 09, 2002 6:08 am
TAA_Airbus thanks, N4KHGirl hey someone else from Roanoke Cool. As far as 24 I think all the work they where doing, I think is over, and I think they started doing something on 33 at night, but I'm not sure what and if they had finnished.
Ejay
Mr Spaceman
Wed Jan 09, 2002 9:16 am
Hi guys.
Here's a good example of why a runway will have a displaced threshold due to an obstacle on short final. If I flew out of this airport, I'd sneak over to that big tree at night and quickly cut it down! hehehe. Then the final approach path would be much safer.
Photo © Adam Cramer
Chris  Smile
Airbus_A340
Wed Jan 09, 2002 7:36 pm
I think the (closed) Hong Kong Kai Tak runway was also a good example of a displaced threshold because of the buildings located in Kowloon city. Not much could have prevented the noise, even height. Boy was it loud in Kowloon City, I remember every bit of it  Smile
Here's a good photo.
Photo © Samuel Lo
Trevor Slack
MarkTPA
Fri Jan 11, 2002 12:27 am
The arrows indicate a displaced threshold. It is not intended for touchdowns, usually not as strong as the rest of the runway. The other posts are correct, usually a displaced threshold is for obstacle clearance.
Users browsing this forum: No registered users and 19 guests
