TRENT500
Cruising Altitudes?
Tue Feb 10, 2004 8:00 pm
Probably not the most interesting topic, but just wondering what is the highest cruising alt you have flown and on which flight?
Mine is FL400, on Astreaus 737-700 KOS>LGW.
T500.
MYT332
RE: Cruising Altitudes?
Tue Feb 10, 2004 8:03 pm
FL390 on a Virgin B744 SFO-LHR.
Why do they always stop there?? Crying I'd love to see FL400
Alex
One Life, Live it.
LBA
Tue Feb 10, 2004 8:35 pm
FL410 - EK Manchester to Dubai A330-200.
757KSLC
Tue Feb 10, 2004 8:45 pm
FL400 on US Airways 757-200 PHL-LAX. Getting over a storm in the Denver area.
hammer
Tue Feb 10, 2004 8:51 pm
FL410 from LAS-DTW NWA 757...
POSITIVE RATE
Tue Feb 10, 2004 9:34 pm
FL410 both in an Ansett 767-200 and a Virgin Blue 737-800.
flyingbronco05
Tue Feb 10, 2004 10:39 pm
FL410 ORD-HNL (AA 763)
FL350 HNL-KOA (HA 712)
Never Trust Your Fuel Gauge
sushka
Tue Feb 10, 2004 10:46 pm
I dont really know in an airliner.
But GA 14,400 C30Q
Pershoyu Spravoyu Litaki!
Tue Feb 10, 2004 11:53 pm
757KSLC...
FL400 is not really a legitimate cruising altitude here in the States at this time, but it will become one a year from now. Currently, the standard IFR cruising altitudes are based on the hemispherical rules. At FL290 and above, aircraft are given 2000' separation. For example, on easterly courses, your altitude assignments would normally be FL190, FL210, FL230, FL250, FL270, FL290, FL330, FL370, FL410, FL450, or FL490. For westerly courses, you would get FL180, FL200, FL220, FL240, FL260, FL280, FL310, FL350, FL390, FL430, FL470 or FL510. Actually, the rules extended up to FL600, but I know of no currently operational civil aircraft with a certified ceiling greater than 51,000' - so it's basically a moot point. These altitudes are known as "hard altitudes" - I'll explain more later.
Like everything else, there are exceptions to just about every rule. It is not at all uncommon to be able to get "wrong way for direction of flight" altitude assignments - for example, say you want FL410 instead of FL390 on a west bound leg. ATC is usually quite accomodating, especially at altitudes of FL410 and above.
Is there a way for you to have actually been cruising at FL400 on your west bound flight? Yes. What the captain probably requested is a "block altitude" assignment. For example, s/he probably requested a block altitude of FL390 through FL430; if ATC grants this, you could legally pick any altitude between 39000' and 43000' to cruise at. Block atitude assignments aren't quite so common, but they're not unusual either.
Just about everything that I mentioned previously is about to change next January when ATC impliments DRVSM (Domestic Reduced Vertical Separation Minimums) here in the States. (These have been gradually introduced world-wide for a few years now.) Basically, these new rules require special aircraft and flight crew certification in able to operate in the airspace between FL290 through FL410. When the new rules are enacted, there will be 1000' separation up through FL410 instead of the current FL290. The easterly altitudes will become FL290, FL310, FL330, FL350, FL370, FL390, and FL410. Westerly altitudes will be FL300, FL320, FL340, FL360, FL380, and FL400. You can see that these changes will double the capacity in those altitudes where the vast majority of jets hang out.
Now, to answer the original question...
In my case, I spend most of my time at FL390 and above. Typically, we flight plan initial crusing altitudes of FL390 or FL410. We go to FL430 on nearly every coast to coast trip regardless of direction and FL450 isn't unusual either.
Jetguy
USAFHummer
Wed Feb 11, 2004 12:37 am
AFAIK I've never hit the FL400 mark...I guess FL390 a bunch of times is the best for me...and GA-wise my highest is 11,500' in a Cessna 172
Greg
ArmitageShanks
Wed Feb 11, 2004 12:51 am
That would be 41k for me.
VSGirl
Wed Feb 11, 2004 4:43 am
I have just returned from Miami and on the outward flight we cruise for two hours at FL410...
Kimberly.
skytrain
Wed Feb 11, 2004 6:13 am
My best is FL420 in a BA 744 from YUL-YYZ in April 2003. Was really strange! All the way up just to come right back down! Big grin
Cheers - Skytrain.
david b.
Wed Feb 11, 2004 6:27 am
ATA 101 going from LGA to LAX via Indi. Pilot announced that we were at FL390.
Comming back on ATA 102 from LAX to LGA via Indi. not sure but we were pretty damn high. Anyone have further info would be great.
Teenage-know-it-alls should be shot on sight
Mr.BA
Wed Feb 11, 2004 9:43 am
FL400... Singapore to Bangkok on the A345.
Boeing747 万岁!
N243NW
Wed Feb 11, 2004 9:47 am
Mr Spaceman
Wed Feb 11, 2004 10:19 am
Hi guys.
I've flown at FL 390 several times. The last time I was at 39,000 feet was from Miami (MIA) back home to Toronto (YYZ) on an American Airlines Fokker 100.
I made it up to FL 410 once on a flight from Ft. Lauderdale (FLL) to Toronto (YYZ) on an Air Canada 767.
Photo © Bruce Leibowitz
Photo © Joe Fernandez - Aviation Photography of Miami
It's to bad nobody will be making it up to 58,000 feet anymore (at least for a while) on a commercial flight!  Sad
Photo © Sam Chui
Chris  Smile
socalatc
Wed Feb 11, 2004 12:45 pm
FL490 on an Cit750.. FL450 on a G4SP
mandala499
Thu Feb 12, 2004 12:38 am
FL410 CGK-SYD VH-EAA 747-SP Big grin Yeeehaaa!
Mandala499
barney captain
Thu Feb 12, 2004 3:54 am
Reading these posts got me curios; I realize the bizjets can easily get in the upper 40's and even up above FL510, but aren't most airliners (Concorde excluded) limited to FL410? The 737NG is capped there and I think all Boeing's are as well, anyone know for sure? Any Airbus drivers out there?
Southeast Of Disorder
david b.
Thu Feb 12, 2004 7:30 am
For the most part it has to do with the pressure system on commercial jets.
Most biz jets are designed to fly high to avoid commercial traffic.
Also, what is currently the most highest flying biz jet on the market?
Thu Feb 12, 2004 12:25 pm
David...
There's a whole gaggle of bizjets certified to FL510 - it's not really all that unusual at this point. The certification requirements change above FL510 so I doubt that you will ever see anything certified above FL510 unless there's a new SST or SSBJ.
Jetguy
IndianGuy
Thu Feb 12, 2004 4:54 pm
AND
Hmmm. I had thought that the 737NG's had a ceiling of FL390?
ANd arent the "Motor Fokkers" restricted to FL350?
-Roy
Thu Feb 19, 2004 10:38 am
All models of 747 are certificated to FL 451 (45,100 feet) -
707s and 727s are certificated to FL 410 (41,000 feet) -
xxx
These altitudes are rarely achieved on regular flights.
At full takeoff gross weight, we barely can climb to FL280-290...
When flying with the 747s, we are generally at FL 370-390 at end of cruise.
The weight of the aircraft (payload) prevents us to climb any higher.
I have been very rarely at FL 450 with a 747.
One exception, with the 747SP, we were often at FL410-430...
xxx
Happy contrails  Smile
(s) Skipper
cv640
Thu Feb 19, 2004 10:53 pm
FL410 from CHS to DTW on a CRJ with a very light load.
Georg
Fri Feb 20, 2004 6:19 am
My highest was on Learjet 60 Zurich Kloten - Tallinn on FL410. Pretty cool.
NO URLS in signature
rducky
Sat Feb 21, 2004 8:31 am
Is there anybody who has flown on the concorde, I think they would hold the record?
rducky
Up Up and Away
warren747sp
Sat Feb 21, 2004 9:47 am
FL440
Pan AM 747SP JFK-NRT in the early eighties.
very interesting trip, you actually feel kind of high.
warren
Now the 400 never go over 39,000.
747SP
mu2
Sat Feb 21, 2004 10:17 am
Indianguy, service ceiling is not how high a plane is legal to fly. Service ceiling is the maximum density altitude at which the airplane can climb at 100 feet per minute, and varies with weight and temp. So it still may be possible.
QF747
Sat Feb 21, 2004 8:00 pm
Highest I been at is FL420 Korean air 744 enroute SEL-ORD.
However domestically within Australia FL390 and the highest on a turbo prop Dash 8 is FL210
Prana
Always fly QF!
Always fly QF!
Jkw777
Sat Feb 21, 2004 8:15 pm
LGW-MCO Virgin 742/744, probably between FL350 and FL400 not too sure?!
LGW-MAN British Airways 734, we hit around FL190 and FL250
LOL  Laugh out loud
Justin  Big grin
[email protected] or +447751242989
dc-10 levo
Sat Feb 21, 2004 8:35 pm
I've been from MAN-MCO with VS at FL380.
DC-10
Users browsing this forum: Flyingdevil737, PERA346 and 38 guests
