Oh wait, there's more...I just couldn't resist:
The Cessna Caravan, which is actually a 208 (the 206 was recip powered and had a none reversible propeller) has the following
AD issued against it:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgad.nsf/0/A9625AACF07A80EA86256A4F004542AC?OpenDocument
That's
AD 97-25-04, which contains the following statement:
"SUMMARY: This amendment adopts a new airworthiness directive (AD) that applies to all Cessna Aircraft Company (Cessna) Models 208, 208A, 208B, 425, and 441 airplanes. This
AD requires amending the Limitations Section of the airplane flight manual (AFM) to prohibit the positioning of the power levers below the flight idle stop while the airplane is in flight. This AFM amendment will include a statement of consequences if the limitation is not followed. This
AD results from numerous incidents and five documented accidents involving airplanes equipped with turboprop engines where the propeller beta was improperly utilized during flight. The actions specified by this
AD are intended to prevent loss of airplane control or engine overspeed with consequent loss of engine power caused by the power levers being positioned below the flight idle stop while the airplane is in flight."
Sound familiar? Are you starting to get the idea that someone thinks this whole in flight reversing thing is a really bad idea?
In fact, even the mighty Dornier 228 has, yes, you guessed it, another
AD. Try
AD 97-22-09 which has the following statement:
"SUMMARY: This amendment adopts a new airworthiness directive (AD) that applies to all Dornier Luftfahrt GMBH (Dornier) Models 228-100, 228-101, 228-200, 228-201, 228-202, and 228-212 airplanes. This
AD requires amending the Limitations Section of the Dornier 228 Pilot's Operating Handbook (POH) to prohibit the positioning of the power levers below the flight idle stop while the airplane is in flight. This POH amendment will include a statement of consequences if the limitation is not followed. This
AD are intended to prevent loss of airplane control or engine overspeed with consequent loss of engine power caused by the power levers being positioned below the flight idle stop while the airplane is in flight. "
Might want to be careful about who you brag to with this whole reversing the 228 thing, don't you think.
Just food for thought...
