When an
AC is parked on the ground with the hydraulic systems off the elevators will move in response to wind forces acting upon it. Depending on the wind direction these forces can cause opposite elevators to move in different directions. The elevators on many
GA aircraft are mechanically linked, so they only move in unison. On the Md-80 as well as most transport
AC the elevators are not mechanically linked, they are held in position by hydraulic actuators. The Md-80 elevators have control tabs that create an aerodynamic deflection causing the elevators to move up or down. The control tabs are mechanically linked to the control column (and therefor cannot split) but the elevators themselves are not. On the ground with no hydraulics the position of the elevators has no relation to the control tab position and hence are able to move independantly of the control tabs and each other.
