N730AS and
CP744 in posts #11 and #20 you suggested that clamshell reversers would be a reason for using the 732 on short runways.
Not exactly. Takeoff will always be the limiting factor in short field operations with jet airliners, never landing distance. If you think about it, you would not want to land a multimillion dollar aircraft anywhere you could not take off from. Every jetliner I've flown (eight types) would land and stop in a distance it could not possibly take off from without the use of any reverse thrust. I'll guarantee you've never experienced maximum effort braking.
Takeoff and landing performance is never limited by what the plane will actually do at ultimate performance. It will be limited by what it can be demonstrated to do, safely, under defined conditons. Therefore, thrust reversers are not used in
takeoff or
landing performance calculations. They
may be, per the FARs, but then the proper operation of the thrust reversers would become a no-go item on the
MEL. In actual operation, thrust reversers are mostly used just to reduce brake wear.
I believe that the real reasons for the 732's popularity up north has been pretty well described in the posts regarding cargo/combi configurations.
In my opinion, the rough-field kits installed are less important than they used to be. Correct me if I'm wrong, but I believe that
AS only has authority for one gravel strip, Red Dog Mine, and does not have any scheduled flights in to that location.
