silverfox
737-400 Cockpit
Fri Jun 11, 2004 6:56 am
Just watched on Discovery flightchannel prog about the 737.
The take off was being videoed!!!!!!!!!!!( and it didnt fall out of the sky)
What i would like to know is
Between the pilots about knee level there appeared to be two wheels with a white stripe on them. These were spinning away merrily . The pilots didnt say what they were
Could a pilot enlighten me please
trekster
RE: 737-400 Cockpit
Fri Jun 11, 2004 6:59 am
I have allways wondered what those were as well.
Spinning happily away, and i have no idea what they are
Where does the time go???
doug_or
RE: 737-400 Cockpit
Fri Jun 11, 2004 7:03 am
trim wheels.
they are usualy operated by a switch on the yoke or through the autopilot, however a handle can be pulled out from the side and in the event of a system failure the pilots can manualy trim the aircraft (VERY hard work).
When in doubt, one B pump off
Jetfixer75
RE: 737-400 Cockpit
Fri Jun 11, 2004 9:53 am
They are also kinda hard on your knees when the handle is out and someone hits the switch on the yoke..OUCH!!!
SlamClick
RE: 737-400 Cockpit
Fri Jun 11, 2004 10:36 am
727 had them as well.
You might be able to wind a self-winding Rolex by hanging it on one of the crank handles and then hitting the trim switches on the yoke.
On the other hand the expanding metal band may stretch out to the point that the Rolex beats itself to pieces on the footrest at the bottom of the panel.
Or I might be making that up.
Last item on the runaway pitch trim checklist is to grab and hold that wheel. The idea scares a lot of pilots-in-training but it should be noted that the power has already been removed from the motor and the electric brake applied.
mandala499
RE: 737-400 Cockpit
Fri Jun 11, 2004 6:55 pm
Aaah, the 737 trim wheel!
Yes, that handle! I've had my knees beaten into pain by them! My fault though...
That runaway trim... it's scary... Only had to do it on the sim... real flight? at the moment I can realistically say that won't have to grab that wheel on a real flight!
LimaFoxTango
RE: 737-400 Cockpit
Fri Jun 25, 2004 12:26 pm
as said above, they are the trim wheels. i think its quite annoying to have them make "click-click-click" sound like that every time it spins. but i guess its like that for a reason. they can be seen clearly in these two pics.
Photo © George Blue
Photo © Juliano Damásio
You are said to be a good pilot when your take-off's equal your landings.
flyingbronco05
RE: 737-400 Cockpit
Fri Jun 25, 2004 12:34 pm
There is some more information on the trim wheel here....
https://www.airliners.net/discussions/tech_ops/read.main/92158/
Never Trust Your Fuel Gauge
RE: 737-400 Cockpit
Sat Jun 26, 2004 3:21 am
Stablizer trim wheels.
The Handles should be used only when manually turning the wheels If not it can strike your knees hard.
Theres a small joke in Maintenance about how would you tell a Commander from a First officer when they leave the aircraft if they were not in uniform.
The Commander [Captain] limped on his right foot while the F/O limped on his left foot.
[courtesy leaving the handles out and electrically operating the Stab trim.
 Smile
regds
HAWK
pilotaydin
RE: 737-400 Cockpit
Mon Jan 23, 2006 4:57 am
i hate the sound that thing makes...
The only time there is too much fuel onboard, is when you're on fire!
2H4
RE: 737-400 Cockpit
Mon Jan 23, 2006 5:12 am
Quoting SlamClick (Reply 4):
I remember playing the "Try to Survive" game in the -700 sim while the instructor introduced random emergencies in an attempt to kill me.
Immediately after take-off from MDW, I got a runaway nose-down trim. I found that I could stop the trim motors by holding constant nose-up trim with the yoke-mounted trim switches.
I ended up holding those switches in place for the rest of the flight while negotiating an engine fire, rudder hardovers (yes, plural), and several other malfunctions before finally winning a bet by landing it at CGX.
I've always wondered if holding the yoke-mounted trim switches would successfully stop runaway trim in the real aircraft, or if it was simply a sim glitch.
2H4
Intentionally Left Blank
RE: 737-400 Cockpit
Mon Jan 23, 2006 11:31 am
Quoting LimaFoxTango (Reply 6):
So that's where the iPod designers got their inspiration Big grin
RE: 737-400 Cockpit
Mon Jan 23, 2006 3:42 pm
This is one Old thread.
Any changes planned on the B739ER on the Stab trim Mechanism.
regds
MEL
DColeMAN
RE: 737-400 Cockpit
Tue Jan 24, 2006 4:29 am
Quoting Silverfox (Thread starter):
It sounds as though you're referring to the Air UK B737-400 documentary (routing LGW-AGP) on Discovery Wings?
If so, the narrator points out the trim wheels shortly after takeoff and briefly explains why they're rotating etc.
Dale
Topless Women Drink 4 Free
RODOL
RE: 737-400 Cockpit
Wed Jan 25, 2006 4:59 am
On a video I have (ITVV Go 733 STN-LIS-STN), the captain says that the left and right trim wheels are made by different manufacturers. He doesn't say why this is the case, but there you go....more useless information!
RE: 737-400 Cockpit
Wed Jan 25, 2006 2:55 pm
Quoting RODOL (Reply 14):
Why would that be the case.Im sure they would be the same.
Any reason.
regds
MEL
Users browsing this forum: Kiwiandrew, Lukas757, N1120A and 37 guests
