Thu Jun 17, 2004 10:03 pm
Yes, wings are very flexible. The tip ailerons can generate enough force at high speed so a downwards deflection will bend the wing nose down and the effect of the aileron is cancelled by the twist of the wing or, indeed, reversed.
This is, partially, why the F18, for example, has a large wing twist between root and tip so the tip points downwards. THe angle is reduced in flight simply because the wing lift bends the wing.
Andy
