Lephron
A large part of what makes air travel so safe are the conservative engineering methods used to design aircraft and their systems. Change is evolutionary rather than revolutionary. That is why we see many radical designs never progress beyond wind tunnel models or drawings. Think sonic cruiser, Boeing BWB, etc..
Jet transport
AC systems, with the exception of avionics, have changed very little since the 707 and DC-8. Pneumatics, electrical, and hydraulics have seen the least change. The changes in hydraulics will be the most evolutionary. I'm not sure but I think the military already uses some 5000 psi systems and the A-380 will too.
The complete change from pneumatics to electrical for anti-ice, pressurization, back-up hydraulics, engine starting, hydraulic resevoir pressurization, and potable water pressurization is a paradigm change. You are eliminating an entire ATA system chapter and requiring another to take over it's functions as well as perform those it already has. One reason this hasn't been tried already is that having seperate systems share tasks gives you built in redundancy. Reducing the number of systems requires that more redundancy be engineered into the remaining systems.
None of this is impossible. It's just a large departure from standard aircraft design and one that is entirely neccessary to achieve the design efficiency goals that Boeing has for The 7E7.
Dl757md
