Well,
CVG777 there are a couple of sides to the answer for your question. As noted in posts above, airliners have a Minimum Equipment List (
MEL) for components which specifies how many are installed, how many must be operative for a (passenger)(ferry)(unpressurized)(but not into known icing etc.) flight, depending on what is broken. It also defines how long they have to make repairs (24 hours, three days, ten days, 120 days) what restrictions the condition might impose, and special procedures to be used.
What you will not find in the
MEL is "wing." Two wings are installed, two wings must be operative. On the other hand, if a given fuel tank has two electric fuel pumps, one may be inoperative provided . . .
So, unlike a wing, an APU is a redundant, non-essential component so of course you are more likely to be flying with an APU inoperative. You will never be flying with a wing inoperative. Summing up: Non-essential means it is more likely that it might be inop on any given flight.
Now an APU is a very complex item. It is a small jet engine that runs a generator and either supplies its own bleed air, or runs a compressor for pneumatic service. It has self-test gear, automatic fire supression system and a host of other features. Machines can break at any point and so APUs are, historically somewhat trouble-prone. For example, if a fire detection loop fails, you cannot start the APU even though it works fine. It just could not detect a fire, so we are not permitted to run it.
Long answer, but I hope it explains it for you.
