Theoretically, a compressor surge, more commonly referred to as a stall, can occur any time the engine is running. Some engines are more stall prone that others. The
GE CFM56s and CF6s have been known to stall, but it is pretty rare. In comparison, the JT8Ds on the 727s, and especially the No. 2, center, engine or engine on the downwind side when there is a crosswind are known to stall.
The cause of a surge or stall is a disruption of the airflow. The disruption can be caused by crosswinds, injestion of a foreign object, airfoil damage, throttle movements (toc or tod), engine deterioration, system malfunction, aircraft movements. Stalls are usually typified by a loud bang (the bigger the engine, the bigger the bang) and flames from the inlet and tailpipe. Stalls can result in internal damage, usually overtemped turbine blades, or as with the JT8s, no damage usually. It is more likely for a stall to occur at the higher power settings as that is where there is the least surge margin although stalls can occur on off idle accels.
