eksath
Crew
Any Plane Incidents Due To Oxygen Tank Explosions?
Thu Aug 12, 2004 11:40 am
Hi guys and gals,
Am doing some research and looking specifically for aircraft written off or inflight incidents due specifically to the rupture of oxygen tanks (either being carried as cargo or as onboard equipment etc) I would appreciate some pointers to such incidents ( if you guys are aware of any). I did some searches on the web but am hoping for some local knowledge or pointers from the members.
thanks in advance
Eksath
World Wide Aerospace Photography
OPNLguy
RE: Any Plane Incidents Due To Oxygen Tank Explosions?
Thu Aug 12, 2004 11:51 am
The only ones that come immediately to mind are the Valujet 592 accident back in the 1990s (improperly labeled/shipped oxygen generators) with an in-flight fire and subsequent crash, and a more obscure one, a Delta 727-200 that burned up on the gate in SLC back in the 1980s due to (IIRC) an oxygen leak. There was also an ATA DC-10-30 that burned up while on the remote stand at ORD, after a seat was being worked on and the oxygen generator was triggered. That one was also in the 1980s...
I'm sure there are others. You might check http://www.aviation-safety.net and search for some others...
[Edited 2004-08-12 04:55:05]
SlamClick
Thu Aug 12, 2004 12:28 pm
Think I remember a P-51 burning to the ground after an accident while servicing the O2 tank. Might have been N2251D?
OPNLguy
Thu Aug 12, 2004 1:58 pm
Here's the ATA DC-10-30 incident at ORD from 1986:
http://aviation-safety.net/database/1986/860810-0.htm
Here's the Delta 727-200 incident at SLC from 1989:
http://aviation-safety.net/database/1989/891014-2.htm
Here's the Valujet DC-9 accident near MIA from 1996:
http://aviation-safety.net/database/1996/960511-0.htm
pilotpip
Thu Aug 12, 2004 2:40 pm
I don't know if you'll find any, but look up incidents with air ambulances. We have to have a fire truck standing by when we refuel with a patient on board becuase of the bad little thing that happens when O2 and Petroleum products mix. I think this rule was put in place becuase of past experience but I can't recall any specific incidents.
You may have to wade through a ton of stuff on the NTSB site if you include part 135 operations in your search but may come up with some good stuff.
DMI
eksath
Crew
Thu Aug 12, 2004 10:28 pm
Thank you all for your input. I am interested in dangers in Trauma evacuation situations with O2 tanks in aircraft...hence my search. thanks Pilotpip for the tip on NTSB.
Users browsing this forum: 1011Fan, adipasqu, aftx91, extender and 46 guests
