It won't help that much. Its an expensive way of increasing capacity. Why doesn't
ATL and Delta Airlines instead work on ways of depeaking arrivals and departures instead of having all flights come in at one time.
When I evacuated for Hurricane Frances up to Atlanta, I stayed at the Ramada across from
ATL and watched the operation there. Delta would fly a ton of planes in at once, so whoever gets put in the back of the line is an hour late. One after another the planes would come in, then about a half hour/hour later hardly anything would come in, then a few minutes later there would be a ton of take offs, then hardly any take offs...
Look at this schedule I took from flytecomm.com from today, the first is Delta arrivals between 6:30 and 7, the second part is Delta arrivals from 7:30-8
Mexico City Delta Air Lines 522 06:30
PM In Flight
Cleveland,
OH Delta Air Lines 1861 06:31
PM In Flight
Santa Ana,
CA Delta Air Lines 850 06:32
PM In Flight
Saint Louis,
MO Delta Air Lines 878 06:34
PM In Flight
Manchester,
NH Delta Air Lines 881 06:37
PM In Flight
Salt Lake City, UT Delta Air Lines 1592 06:37
PM In Flight
Memphis,
TN Delta Air Lines 9819 06:39
PM Planned
Phoenix,
AZ Delta Air Lines 348 06:40
PM In Flight
Austin,
TX Delta Air Lines 1406 06:41
PM In Flight
San Salvador Delta Air Lines 380 06:42
PM In Flight
Miami,
FL Delta Air Lines 1203 06:43
PM In Flight
Portland,
OR Delta Air Lines 1276 06:43
PM In Flight
Fort Myers,
FL Delta Air Lines 488 06:44
PM In Flight
Tallahassee,
FL Delta Air Lines 1230 06:44
PM Scheduled
Columbia,
SC Delta Air Lines 714 06:47
PM Scheduled
New Orleans,
LA Delta Air Lines 1068 06:48
PM Scheduled
San Diego,
CA Delta Air Lines 730 06:49
PM In Flight
Los Angeles,
CA Delta Air Lines 182 06:49
PM In Flight
Dallas,
TX Delta Air Lines 382 06:50
PM In Flight
Washington, DC Delta Air Lines 1696 06:50
PM Scheduled
Baltimore,
MD Delta Air Lines 9811 06:50
PM Planned
San Juan,
PR Delta Air Lines 300 06:51
PM In Flight
Orlando,
FL Delta Air Lines 966 06:52
PM Scheduled
Washington, DC Delta Air Lines 209 06:53
PM In Flight
Tulsa,
OK Delta Air Lines 628 06:53
PM Scheduled
Charlotte,
NC Delta Air Lines 1182 06:53
PM Scheduled
West Palm Beach,
FL Delta Air Lines 798 06:54
PM Scheduled
Tampa,
FL Delta Air Lines 898 06:55
PM Scheduled
Houston,
TX Delta Air Lines 1547 06:56
PM Scheduled
Seattle,
WA Delta Air Lines 528 06:56
PM In Flight
Jacksonville,
FL Delta Air Lines 700 06:57
PM Scheduled
Birmingham,
AL Delta Air Lines 1659 06:57
PM Scheduled
Philadelphia, PA Delta Air Lines 1677 06:58
PM In Flight
Sacramento,
CA Delta Air Lines 598 06:58
PM In Flight
Kansas City,
MO Delta Air Lines 770 06:59
PM Scheduled
Pittsburgh, PA Delta Air Lines 601 07:30
PM Scheduled
Baltimore,
MD Delta Air Lines 607 07:34
PM Scheduled
New York, NY Delta Air Lines 1431 07:39
PM In Flight
Newark,
NJ Delta Air Lines 1565 07:45
PM Scheduled
San Diego,
CA Delta Air Lines 9820 07:48
PM In Flight
Boston,
MA Delta Air Lines 494 07:50
PM In Flight
Mexico City Delta Air Lines 388 07:50
PM In Flight
Denver,
CO Delta Air Lines 1650 07:51
PM Scheduled
Houston,
TX Delta Air Lines 863 07:52
PM Scheduled
Washington, DC Delta Air Lines 918 07:56
PM Scheduled
San Antonio,
TX Delta Air Lines 1624 07:56
PM Scheduled
New York, NY Delta Air Lines 193 08:00
PM Scheduled
Notice the difference?? With ASA there is about the same difference too between 6:30-7 and 7:30-8.
Why can't Delta change its schedule around a little so that there are less crowded times. Its called depeaking. American Airlines is already doing that at other airports. A runway is designed to handle about 30-40 arrivals in good conditions and 60 departures in good conditions. In IFR conditions its much less. I am not sure about the separation between the nearest parallel runways at
ATL, but they can land two aircraft simultaneously on the outer runways and depart simultaneously on the inner runways in good conditions. I know the nearest parallels are less than 4300' apart so they get shut down in IFR conditions and
ATL is down to two runways. The third runway does help in IFR conditions, but in good conditions the four runways can be used without problems.
Now back to Delta, being that they have two departure runways that can handle 60 departures an hour each (ideally), Delta thinks it can schedule 120 flights to leave at once, but doesn't factor in that Air Tran and other carriers are using that runway too.
I watched
ATL operations and at times there would be hardly anything moving out there, then everything comes in or everything goes out. Delta needs to adjust its schedule and they would find out that they wouldn't have all of these delays and
ATL wouldn't need this new runway.
Want to talk about delays? This new runway! Ever see how far out it is going to be. We're talking a 15 minute taxi time at least.
