Keep in mind the belly is the lowest point, and condensation (or fuel) will run downhill until the lowest spot and drop off. Just because a fluid appears at some spot on the airframe, doesn`t mean that`s where the source is. Airflow, gravity, all sorts of things can move fluids around. F-28s often have the left hand side of the fuselage and stubwing covered in oil, making it look like there is a bad leak in the stubwing. But there is no oil in the fuselage or stubwing! It`s all being sprayed there by the breather. More than one apprentice (including myself) has opened up panels trying to figure out where it`s all coming from.
