nudelhirsch
Air Intakes On A330 Engine?
Thu Feb 10, 2005 3:00 pm
As I am sure these have a point...what exactly are those intakes on the pylon for?
Pic:
Photo © Magnus Trippler
Thanks guys...
Putana da Seatbeltz!
troubleshooter
RE: Air Intakes On A330 Engine?
Thu Feb 10, 2005 6:17 pm
It´s just a guess. They look like precooler outlets. Fan air is used to cool down the hot compressor bleed air which is used for cabin pressurisation and air conditioning. The precooler is located inside the engine pylon.
I`m not working on the A330 so don´t kick me if I´m wrong...
This job sucks!!! I love this job!!!
nudelhirsch
Thu Feb 10, 2005 6:27 pm
Dude, I will kick you if this is wrong!
Kidding...
Thanks fellow Deutscher on that info, makes sense to me. I am just a business major who can tell you why operating any AC is too expensive...lol
airplay
Fri Feb 11, 2005 12:18 am
Yep...pre-cooler, cooling air discharge.
http://members.shaw.ca/airplay1/precool.jpg
troubleshooter
Sat Feb 12, 2005 6:36 am
No kick today, mate. Lucky day for me.  Wink/being sarcastic
Sat Feb 12, 2005 6:36 pm
Nice Sketch,Makes understanding easier.
Thanks.
regds
MEL
Santhosh
Sun Feb 13, 2005 1:29 am
Can any one please explain me in detail on how the precooling system works in relation to the sketch?
Thanx
George
Happy Landings :)
SlamClick
Sun Feb 13, 2005 2:01 am
"Bleed" air off the engine is tapped off at some stage into the compressor section. It is obviously "compressed" and therefore hot.
For most pneumatic uses we want the higher pressure of the bleed air but not necessarily the heat. (Exception is anti-icing, but that is a whole other discussion.)
Fan discharge air is just outside air that went into the outer part of the engine air intake and thus, is being ducted around the engine by the first stage fan, in a fan shroud.
Some of this fan discharge air is bled off and ducted to the precooler. This unit is often rather like a car radiator where hot water is passed through thin, finned tubes and cold outside air draws heat away from it. In the precooler, the hot bleed air goes through the "water" part of the radiator and the cold fan discharge air passes through the "air" side of the radiator. This fan air draws heat off the radiator elements that are being heated by the bleed air.
After passing through this element, the fan air simply exhausts overboard. In the case of the A-330, through the louvers you see in the picture. That installation is pretty typical of modern jet transports, by the way.
Santhosh
Sun Feb 13, 2005 3:49 am
SlamClick- Sir thanx very much for the explanation.
BTW The cold air from the fan is drawn from the by pass section of the engine into the precooler. Right?
George
Happy Landings :)
SlamClick
Sun Feb 13, 2005 5:28 am
Right. All air entering the opening - some goes through the engine core, some around the "bypass" which is by way of a fan shroud or duct.
Users browsing this forum: N1120A and 14 guests
