Quoting MD-90 (reply 13): 2H4, the same designer who did the control system for the Cirrus planes also did it for the T303 and Caravan, two of the most well-regarded airplanes for handling. I've never even flown in a Cirrus, but Aviation Consumer, AOPA, Flying, etc all consider it to be a very nice flying plane, darn near the equal of a Bonanza. |
That's a good point,
MD-90. The Cirrus
does handle well, and is very stable. The point I was trying to make has to do with tactle feedback from the flight controls. Compared to most other
GA planes I've flown, I found it to isolate me a little
too well from the control surfaces. As a result, it felt numb...almost as if you were operating the aircraft remotely. In the crosswind conditions I flew in, I also felt as if I was running out of aileron authority. The sidestick seemed to hit the stops too soon relative to their effectiveness at the time. This, by the way, had absolutely nothing to do with the sidestick itself. I found it to be very intuitive and ergonomic.
I also believe primary trainers should not have a rudder/aileron interconnect. When the 172 came out (with it's Friese ailerons), instructors complained that students no longer had to think about using the rudder to make coordinated turns. Glider pilots know what I'm talking about. Well, to me, the Cirrus, with it's interconnect, seemed to be a step of the same magnitude in the same direction.
Quoting FlyMKG (reply 15): Getting planes on the cutting edge of design for almost free is something my school can't pass up. |
That's what they said about the Extras...at well over $200/hr,
I never saw the cost savings.
Do you have any idea what will be done to address partial-panel work?
2H4
[Edited 2005-02-18 17:43:04]
