CRJ200Mechanic
Hamburger Door
Wed Feb 23, 2005 5:47 pm
I have seen some A/C around that have a door below the pilots windscreen and found out that it is called a Hamburger door. Can anyone tell me what it is for? I do not remember what A/C I saw it on. It was a smaller jet about a 30 seater
Always remember the responsibilies you hold with an A&P license
Tiger119
RE: Hamburger Door
Wed Feb 23, 2005 5:59 pm
Quoting CRJ200Mechanic (reply 0):
- I know on the Saab340 they use that hatch to pass paperwork back and forth between the captain and the ground crew (weight estimates, etc). I would imagine it is probably the same for most aircraft. I have never heard it called the Hamburger door. Where did you hear that?
Flying is the second greatest thrill known to mankind, landing is the first!
CRJ200Mechanic
RE: Hamburger Door
Wed Feb 23, 2005 6:01 pm
Quoting Tiger119 (reply 1):
I heard it from a ramp agent. It may have just been what they called it
Mr Spaceman
RE: Hamburger Door
Wed Feb 23, 2005 6:45 pm
Hi guys.
You can see the "Hamburger Door" open a bit under the Captain's left side windscreen in this photo of a Saab 340.
Photo © Warren Williams
"I'd like some large fries with that please!"
Chris  Smile
[Edited 2005-02-23 10:45:39]
CRJ200Mechanic
RE: Hamburger Door
Wed Feb 23, 2005 6:58 pm
Mr. Spaceman
Do you know if its actually called the hamburger door? I'm sure there has to be a technical term for it
Mr Spaceman
RE: Hamburger Door
Wed Feb 23, 2005 7:20 pm
Hello CRJ200Mechanic.
I'm not sure? It could be. Obviously it's just a nickname that's used on the ramp, and different ramps & airlines probably have different nicknames for that little door.
I ask about that little door in a topic I started over a year ago. There were some good replies with different names for that door, and I posted a cool photo of a Captain waving his hand at the camera through that door, but, do you think I can find the thread or photo??? NO!!!  Pissed
Anyhow, as Tiger119 mentioned, the door is for passing last minute paperwork without having to open the main cabin door.
Chris  Smile
CRJ200Mechanic
RE: Hamburger Door
Wed Feb 23, 2005 7:53 pm
Thanks for the help. That's kinda what I figured it was for. Just wanted some reassurance. I did a topic search to see if this had been discussed before and didn't find anything. I hope I don't upset anyone
troubleshooter
RE: Hamburger Door
Wed Feb 23, 2005 8:46 pm
ATR´s have these "hamburger doors", too. I believe they are called document doors. You can see it on the picture below, located between the left side window and the AOA vane.
Photo © Jakub Michalak
This job sucks!!! I love this job!!!
airplay
RE: Hamburger Door
Wed Feb 23, 2005 10:45 pm
On the SAAB 340, that door is often (affectionately) known as the "whiskey" door. It allows the ground crew to pass a bottle up to the pilots....
 Smile
Seriously though, its just a paperwork door. The term "hamburger door" was (again affectionately) used for the mail door on the DC-3.
Photo © Allan Martins Antunes
As you can imagine, anyone climbing out of this door while the engines are running can be quickly converted to hamburger.
I really don't see how the little documents doors can be compared to the original "hamburger door". Unless of course the pilot is hungry!
One other airplane that comes to mind in this dicussion is the Britten Norman Islander.
Photo © Vladimir Kostritsa
The pilot's door becomes a "hamburger door" with the engines running. The magnetos on the left engines are actually deactivated by an interlock on the door so it shuts down if the door is opened.
[Edited 2005-02-23 14:46:40]
FredT
RE: Hamburger Door
Thu Feb 24, 2005 12:39 am
Officially, we call it the "MESSAGE DOOR PILOT-GROUND CREW".
Unofficially it's the whiskey door. 'Hamburger door' must be a take-over attempt by the PC mob.
SlamClick
RE: Hamburger Door
Thu Feb 24, 2005 6:34 am
Well it is just too bad the hamburger door was not around for the DC-9. It would have gone well with the sugar scoop, porkchops and pickle switches.
The MU-2 also had one. Small plug door down by the pilot's elbow.
Photo © Europix
From outside - open. Small opening just below pilot's window.
Couldn't find a shot of it from inside.
XFSUgimpLB41X
RE: Hamburger Door
Thu Feb 24, 2005 7:30 am
Always heard it called the whiskey hatch... I think I kinda like hamburger door better.  Smile
Mesaba used to crank both engines and have them in feather on the saabs while they waited for the load data to be handed through the hatch. There was an incident at an outstation where the paper work got blown out of the rampers hand, she reached for it and (luckily this was all that happened) lost one or two of her fingers in the feathered prop that was rotating. Now you can see where they have #2 operating and wait for the paperwork to be handed through the hatch with the rampers clear of the airplane to fire up #1.
Chicks dig winglets.
avt007
RE: Hamburger Door
Thu Feb 24, 2005 7:37 am
The first one I saw was on the Dornier 328. I thought it was a pretty good idea!
APFPilot1985
RE: Hamburger Door
Thu Feb 24, 2005 10:51 am
AFAIK, the hamburger door has always referred to the DC-3's door right in front of the engine. At least thats what i was always told by maintenance at PBA when i was growing up
Stand Up and Be Counted Visit Site Related to Voice your opinion
CRJ200Mechanic
RE: Hamburger Door
Thu Feb 24, 2005 4:44 pm
Quoting Avt007 (reply 12):
on the Dornier 328
That's what I saw it on! I couldn't think of the name to that damn airplane to save my life
RE: Hamburger Door
Thu Feb 24, 2005 8:32 pm
Hamburger door  Big thumbs up
I wonder what the MM calls it.
regds
MEL
A10WARTHOG
RE: Hamburger Door
Thu Feb 24, 2005 8:47 pm
On the 328 if I recall correctly the AMM calls it is a communication door or document door. I maybe wrong, it has been a while since I have looked at a 328 AMM.
SlamClick
RE: Hamburger Door
Fri Feb 25, 2005 1:18 am
I always heard the one on the DC-3 called a "mail door" as that is where the mail sacks went aboard. There was a compartment between the forward bulkhead of the passenger cabin and the flight deck where they were stored for flight.
Photo © Paul Chandler
undehoulli
RE: Hamburger Door
Fri Feb 25, 2005 2:16 am
I think I remember a Mesaba pilot telling me that it's called the "Whiskey Slot" or something like that. Not too sure, It was a few years ago. Any XJ pilots able to elaborate?
Weather Modification Rocks!!!
MD11Engineer
RE: Hamburger Door
Fri Feb 25, 2005 2:59 am
Ok, it´s years ago since I worked on a DC-3 (actually a C-47). Entering through this mail door, you´ll have the cockpit rear bulkhead to the right (front) and the electrical distribution panel with the C/Bs to the left (aft). Across the aisle is the hydraulics cabinet with the hydraulics resevoir. On our ex-military C-47, going aft you had two small rooms left and right of the aisle, the radio operator´s cabinet on the right, if I remember correctly and the navigator´s cabinet on the other side., the going aft, you´d pass a door in a bulkhead and stand in the passenger/cargo area (our plane was fitted fotparatroopers, with a steel cable for the static lines of the parachutes under the ceiling and folding canvas benches left and right).
Jan
amtrosie
RE: Hamburger Door
Fri Feb 25, 2005 8:27 am
ATR's called it a "document door". When I was working regionals we had this one kid who could always be found sleeping in the left seat around 04:00. I desperately wanted to find one of those "canned" air horns and put it in the window and let it rip..... That would have been worth every bit of damage incured, to witness the aftermath.
PPGMD
RE: Hamburger Door
Fri Feb 25, 2005 10:13 am
Quoting FredT (reply 9):
Well as it was explained to me, by an old guy working to recondition a DC-3, anyone that tried to exit the door would become hamburger by the prop.
*shrugs* Didn't seem like a PC renaming to me, but what do I know?
At worst, you screw up and die.
RE: Hamburger Door
Fri Feb 25, 2005 1:07 pm
Does the ATR-72 have Sliding Cockpit Windows.
If so,Why the "Document" door.
regds
MEL
ThePinnacleKid
RE: Hamburger Door
Fri Feb 25, 2005 2:17 pm
Back in the day when I was at American Eagle, we always referred to them as the "whiskey hatch" and you guys are correct in the fact it is both on the SF340s and ATR's... always would use them to pass our final load counts up to the flight deck so they could do the CG... then pre departure the infamous hand would stick out the side after they gave "remove chock" sign and we would get their final papers back and off they went... Same type of thing went on at Express Airlines I, (Pinnacle) back when I started in '01 when we still had 30+ SF340s crop dustin' the southern US.
Rumor that went along with the term "whiskey hatch" was that the term came from the early pioneering days of flying with the airlines on the CAM routes.. when getting there was more luck than skill... it went something to the affect that right before they would embark on their flight they would down a quick shot of whiskey, strap in, and go... so, it just kinda stuck...and that's the hatch where that final shot of "whiskey" is passed to the crew right before their departure... (just the rumor mill they told us to explain where term came from, anyone can elaborate or know more go for it)
-Chris
"Sonny, did we land? or were we shot down?"
411A
RE: Hamburger Door
Fri Feb 25, 2005 9:52 pm
Some older piston transport aircraft had various hatches and 'doors' that acquired odd names.
One type in particular comes to mind.
On the Convair 340/440 series, on top on the engine nacelle, was the engine accessory section vent.
This vent had a spring loaded door which, when the respective engine fire pull handle was pulled, among several other actions that occured at the same time, the accessory vent door was quickly closed, due to spring/lever action.
The slang term for this door was...whacker-dacker door.
Strange...but true.
Users browsing this forum: No registered users and 18 guests
