JetSaurus
757 P&W Reverse Thruster
Wed May 25, 2005 6:39 am
I've often wondered why on P&W powered B757's what the sound is when the aircraft is put into reverse thrust.
This past weekend I stayed at the ATL Renaissance and watch a few [sic] planes take off. During that time just about every single Delta 757 that landed had this weird sound after the thrusters were deployed. It happens towards the end of the reverse cycle and sounds like a blast of compressed air and it much louder than the thrust itself.
I've flown many DL 757's over the years and most times you can hear from the cabin also so it's nothing new to me. Just curious as to why it happens and happens only on the PW 757.
Jack/GPT
N808NW
RE: 757 P&W Reverse Thruster
Wed May 25, 2005 6:50 am
Yeah... I too have noticed this on NW 757s while spotting at MSP. It sounds as if the engine cowling is coming back into place before the engines are completely idle (almost as if the pilots are hurrying it up). hmmmm.
-Jason  swirl
 spin   hyper  MY 200th POST  hyper   spin
All flights have great IFE...get yourself a window seat, thats something no PTV can beat! flew 808 Pacific an Atlanic
optionscle
Wed May 25, 2005 7:31 am
I remember a post on this a while back. If I recall correctly, the difference in fan speed in the various stages of the engine (N1 and N2 ?) causes a lot of pressure to build up inside the engine when the power is reduced from high to idle such as on landing. The sound you hear is the pressure releasing through a valve. I'm sure someone with more technical expertise can explain it in more detail.
-Andrew
LMP737
Wed May 25, 2005 7:36 am
If memory serves me correctly that's the 12th stage bleed opening up.
dl757md
Wed May 25, 2005 10:49 am
Quoting LMP737 (Reply 3):
Actually it's the 14th stage bleed valve.
Dl757Md
air2gxs
Wed May 25, 2005 11:01 am
Isn't it also the 2.5 bleed ring opening?
Wed May 25, 2005 4:28 pm
Is it diffferent on the RB211s.
regds
MEL
LMP737
Wed May 25, 2005 11:12 pm
Dl757md:
Thanks for clearing out some of cob webs upstairs. It's been over two years since I've worked on a Pratt powered 757.
Users browsing this forum: No registered users and 24 guests
